Canon pc720 I change the cartridge of canon pc720 with a Canon E40 cartridge. It slid in & clicked it. When I turned it on it made a grinding sound, the light bar seems jammed and there is a grinding sound.
jackboy
  • 2985 Answers
SOURCE: cartridge jammed
Cartridges are usually simple click into place.
Refer to your manual.
I suspect none of us here can help further without actually examining your printer.
you could also try - www,fixyourownprinter.com
type your printer model in the field.
Also Canon customer support will may be able to point a way
Posted on Nov 26, 2007
SOURCE: Replacing Canon PC720 Toner cartridge change
Not sure if you found this out yet.
The cartridge just slides out. When you lift the latch you will see the cartridge has lifted too. All you need to do is pull the cartridge toward you. It slides right out.
Posted on Feb 25, 2008
SOURCE: ink cartridge jammed
I just cleaned my rollers and now its working again. I have no idea if its a solution or a fluke but it worked for me
Posted on Mar 18, 2009
SOURCE: Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
Posted on May 25, 2009
michael_grey
  • 365 Answers
SOURCE: change the print cartridge canon mp210
Open the cover and the cartridges will move to the left.
Then pop them out from the top toward you.
Posted on Jun 20, 2009
Canon MX 892 = Printer error has occurred. Turn off power than turn back on. If problem persists see the manual.
The grinding noise would be a clue that something needs to be put right before the reset would work!
Open the cover and check the paper has not jammed or cartridge has not been placed correctly.......remove cartridge and replace! Then turn off power and back on again!
Oct 19, 2014 | Canon PIXMA MX892 multifunction printer
Copier is Canon PC 720 Copier turns on, but makes
You said you unplugged your copier, did you unplug it for 10 to 15 minutes before plugging it back in, plug it into a differed
outlet that you know works and plug it directly into a wall outlet instead of a power strip. Check to see if your copier reaches stand-by mode then make a test sheet.
If this does not work then you have probably have an internal processing component which requires attention.
Apr 02, 2017 | Koutech Systems PC720 (IO-PC720) (IOPC720)...
Canon pc720 makes "crackly" sound, randomly shuts off mid-print, and displays error code E240
Your scan lamp is going bad. It is the flourecent type lamp that lights up under the glass. You can try making a copy with the top cover open and watch it. You will see it flickering before the code comes up.
$75 from precisionroller.com Part#L5180 or the canon # FH7-3272-000
May 01, 2010 | Canon ImageClass D861 Printer
Our pc 940 does solid black copy
There is an open circuit on one of the charging components in the printer cartridge, the Canon E40. Replacing the cartridge should solve the issue. Be sure to use a high quality remanufactured cartridge or an original to try to avoid such issues.
Jan 18, 2010 | Canon PC-940 Black and White Copier
Canon PC720 Gear popped out
hello.
probably its the gear of the register roller near the contacts of he machine .
Oct 22, 2009 | Office Equipment & Supplies
I need a technical manual for a Canon Copier PC720
Scroll Down put in the 4 digit code, click download
http://www.devicemanuals.com/guide/Copier/Canon/Canon-Personal-Copier-PC720-User-Guide-TkRBNU9UYz.html
Oct 20, 2009 | Canon PC150 Personal Copier (PC 150,...
Toner Cartridge
Mine is a single cartridge system. The black cartridge that looks like it holds the ink is the toner cartridge. Replace it with cartridge E40.
Jun 12, 2008 | Canon PC-920 Black and White Copier
Jan 13, 2008 | Office Equipment & Supplies
jasbo
jasbo
