Question about Sewing Machines
Racing overlocker When powered on runs at full speed with no adjustment on pedal.
  • Sewing Machines Master
  • 1,388 Answers
Make/model ??
Posted on Apr 22, 2014
The foot pedal of the machine don't work, and the machine turned the speed to the top when the plug is on. but was everything working well and passed sometime of using the machine started. what i do?
The foot pedal below uses a small connector. Make sure the connector is fully installed. It is possible that this foot pedal is defective. You need to try borrow another before replacing.
26176461-b03ojqwqtbsecjv14p2f4cy4-2-0.jpg This pedal below with a 110 volt connector controls the speed of the machine directly. If the machine is racing replace the pedal with an exact replacement the problem will be solved.
Apr 26, 2016 | Sewing Machines
My sewing machine has power, but is not turning the gears. What is the problem, and should I bring it into sears for repair
If you can turn the hand crank and the needle moves up and down, then the gears are probably alright.
It could just be the floor pedal is oxidized and not making good contact so isn't allowing electricity to get to the motor. If you know anything about electricity, you can bypass the floor control pedal and just briefly put the full power to the motor and see if it runs full speed, then you know it is just the speed control floor pedal.
Feb 23, 2015 | Kenmore Sewing Machines
My janome 3000 is sewing at full speed..ii have to keep turning the power off to stop it..is it a software problem or the pedal? At times when I have been sewing a lot it does the racing thing so I ke
disconnect pedal from power and from machine, use om-meter and check resistance between poles, it should be ridiculously high between all poles to the xtent to show 0 on all possible connections.
depress pedal about 1/4 way - you should have flow between two pairs but not crossover with some resistance registering, but showing flow between pairs.
now, depress about half way, your resistance should be lower than previous one
depress in full - resistance should be very, very low
this testing will check conductivity of the food pedal and resistor switch attached to it. to make absolutely sure that this is pedal - borrow one from friend or even from the shop (they may ask you for small retainer if you do not know personnel, but usually lend you switch for a day or at least few hours.)
if you have results as described above, you can exclude foot pedal - your motherbord then will be responcible for weird behaviour of the machine, enquire about the repair - but be prepared - if machine is not under warranty - it maybe cheaper to buy new one than repair old one...
hope this little instruction will help you - do not forget to vote if you find advice useful.
Dec 31, 2014 | Janome Sewing Machines
Hesitates then speeds
Short answer, no. None of the overlockers have a speed half speed, most sew at 1500 stitches per minute which does take a little time to get used to.
Apr 25, 2013 | Janome MyLock 634D Mechanical Sewing...
My Huskylock 936 won't sew. I was sewing yesterday, 4 thread overlock. I finished a seam, cut the thread, proceeded to sew another seam. I put my foot on the pedal..and nothing.If I turn the machi
Good evening madam
It sounds like there is something wrong with the electrical system in your sewing machine. You can check the power and connections.
good luck
Kolbrun
Feb 26, 2012 | Husqvarna Huskylock Computerized 936
Huskylock 435 will not stop overlocking
There is a supressor, probably inside the case of the foot control, less likely in the body of the machine, that has burned out.......you may notice an acrid plastic/burnt odour near the source....sniff at the pedal or the rear of the machine to try to ident the location.
It is not actually necessary for the operation of the machine, it only stops interference if sewing while someone else is watching or listening to TV and Radio.
If you do not feel confident to undo, locate and remove this component I strongly suggest a quick trip to the repair shop (phone first, say the supressor is blown and ask for a quote)
You could also have a general service at the same time if it has been a while and is within your budget.
Dec 26, 2008 | Sewing Machines
Foot pedal and thread guide
Same thing happened to my CE-200. It would only stitch one stitch at a time or else it would run full speed. My husband made an adjustment through a small hole on the back of the pedal and it now works much better. The adjustment hole apparently allows you to set the sensitivity of the electronics inside the pedal. He turned it slightly toward the + direction. It took a couple of small adjustments to get it to work nearly normal again.
rbwinter@wbsnet.org
Jan 19, 2008 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
13 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
