Question about Wolff Sunquest Pro 24RS 220 Volts
I need a wiring diagram for timer switch Diehl T85 typ 601 Ldk.
How can i bypass a diehl 883 timer
Add a switch between the 3 and 5 terminals
http://waterheatertimer.org/images/Deihl-880-wire-350.jpg
Add 2 different switches between 3 and 5 -and- 3 and 4 terminals:
http://waterheatertimer.org/images/Deihl-880-wire-DPST-600.jpg
Override timer with countdown timer:
http://waterheatertimer.org/Override-timer-with-countdown-timer.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 13, 2015 | Diehl Hardware & Accessories
Diehl Timer 4 pin wiring
well..the timer is used in a variety of dryers. which model is this one going to be installed in?
Oct 15, 2008 | Dryers
Connection diagram for diehl t85 typ 600
1) Copy following links.
http://waterheatertimer.org/images/Deihl-T85-600-wired-for-208-230-Volt.jpg
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#T85
2) 3-pin 5 amp service has 2 hot legs (wires) located across from each other on outlet.
Interrupt one hot wire and circuit turns OFF.
However live power potential still exists on remaining hot leg.
3) To turn off both Hot legs, use DPDT spring-wound timer such as Intermatic 60 minute FF460M or FD460M
http://waterheatertimer.org/pdf/039_FF-series-sell-sheet-with-wiring.pdf
Jan 05, 2013 | Diehl Hardware & Accessories
How do i wire diehl t85 type 600
1) Copy following links for wiring Deihl T85 600 timer.
http://waterheatertimer.org/images/Deihl-Type-600-T85-timer.jpg
2) This timer will turn off Hot wire in 120Volt circuit.
3) For 208-230 Volt applications, the timer will operate by turning off 1 hot leg. However other hot leg will still have live power. To turn off both Hot legs, use DPDT spring-wound timer such as Intermatic 60 minute FF460M or FD460M
Feb 28, 2012 | Diehl Hardware & Accessories
Manual for diehl multi-timer typ 181-5
Timer number does not match Diehl timer numbers
1) Diehl timers and manuals appear on following links:
http://www.borggeneral.com/
http://www.borggeneral.com/diehl-control-timers.html
2) Add a comment with in-focus photo of timer posted on flicker for possible identification and more help.
Jul 19, 2011 | Hardware & Accessories
Need wiring diagram SPST power to timer timer to light . two screws marked timer 1 nc 1no 1 com
Here are two possible solutions, since timers are made different ways:
1) Diehl timer has 5 terminals
Drawing below shows wiring for Diehl SPST:
2) Your timer might also be wired as follows:
Two screws marked 'timer' are for 120Volt Hot and Neutral that power the clock motor (in drawing above, these are terminals 1 and 2).
Another Hot wire connects to COM. (in drawing above this hot wire shown connecting to terminal 3)
Load wire connects to terminal NO (in drawing above this wire shown connecting to terminal 4)
3) NO is Normally-Open turns ON when tier turns ON
NC is Normally-closed is ON all the time, EXCEPT when timer turns ON. So NC terminal turns OFF when timer turns ON.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 31, 2010 | Diehl TA-4150 24 Hour Electromechanical...
Need to replace a Diehl Typ 880, T85 120V 60Hz 15Amp timer what is its current model to replace?
The Type 880 is the exact replacement. Still available at most pool supply outlets.
Sep 27, 2010 | Hardware & Accessories
Wolff Sunquest Pro 24RS 220 Volts Logo
60 people viewed this question
Top Wolff Health & Beauty Experts
Steve
NOEL
NOEL
Are you a Wolff Health and Beauty Expert? Answer questions, earn points and help others
