Question about Berkeley Systems, Inc. You Dont Know Jack
How to turn off alarm on a vw cabrio
Help
Factory alarm for 2001 cabrio, is it part of the radio?
No, it is not part of the radio unit proper. I have been driving my car since it was 3 days old without the factory radio. I could not tell you where the alarm is located, & I would not cut any of the original wires that lead to the radio to the harness, those might have something to do with the alarm, Vw tends to wire things funny
Jul 10, 2014 | 2001 Volkswagen Cabrio
I have a 1997 vw cabrio. i replaced my battery n when i hook up the battery my alarm goes off n my driver side lock cylinder fell out how do i disarm my alarm?
You need to bypass the alarm if you do not have the remote to disable it and the key lock fell out. I have posted multiple times about how to bypass the stock alarm and still have everything work. If you need any help on doing this please feel free to message me.
Mar 07, 2014 | 1997 Volkswagen Jetta
How to shut off the alarm
The vw alarms cannot be disconnected.
Jan 15, 2014 | 1998 Volkswagen Cabrio
How can i disconnect car alarm on a 2000 volkswagon cabrio
On a 2000 VW cabrio, MAKE SURE your alarm system is disengaged (running the car and turning it off is one of the easiest methods to make sure you can remove the alarm and start your vehicle after you remove the control boxes.
look for the fuse box near you left knee, directly above the fuse box panel in a vertical manner, deep in the dash, is the control boxes for the alarm (they are not easy to reach, expect fustration but you can get to them from there). If I correctly remember, a rectangular silver box and a square black box will do the trick. Remove the three harnesses to the boxes and your nightmare is over.
Aug 15, 2012 | 2000 Volkswagen Cabrio
2002 VW Cabrio alarm problem: alarm will not un-set. Door will not lock using the key OR the remote. Hitting "alarm off" button on remote, it unsets, then arms again immediately. With engine...
i have a 2002 vw cabrio and won't start after i took out the battery everbody is telling me that anti-theft is lock mode how do i rest it so i can start my car
Nov 08, 2010 | 2000 Volkswagen Cabrio
2001 VW Cabrio oil light blinks and alarm sounds
Make sure there was enough oil put in and that it is not leaking through the oil drain plug or the oil filter.
Feb 05, 2010 | 2001 Volkswagen Cabrio
My 1998 vw cabrio immediately stalls out after turning over
check your timeing belt frist . then check your fuel pump.and check your fuelter then check your fuese. 9 time out of 10 when a car die on you while driving its your timeing belt
Apr 05, 2009 | 1998 Volkswagen Cabrio
How do I disalarm my 1997 VW Cabrio Alarm?
I have a similiar problem occasionally. In my 97 vw, it usually happens when the battery terminals are loose. I just take them off, clean them and reconnect and the problem goes away for several months.
Apr 01, 2009 | 1997 Volkswagen Cabrio
Alarm system will not go off in a 1999 vw cabrio
hi, if you have the original stereo, this is the problem, disconnect your stereo, the stereo is connected to the alarma.
To remove the stereo you need two thin plate, put the plates in the slots above the buttons power and mix, and pull the stereo.
Mar 14, 2009 | 1999 Volkswagen Cabrio
2002 VW Cabrio Key question...and power lock question.
these cars are known for having switches in the door lock module fail. its an easy repair but an involved and time consuming job to access the unit in the door.
Sep 09, 2008 | 2002 Volkswagen Cabrio
Berkeley Systems, Inc. You Dont Know Jack Logo
64 people viewed this question
Top Berkeley Systems, Inc. Video Game Consoles & Games Experts
James Wishart
Are you a Berkeley Systems, Inc. Video Game Console and Game Expert? Answer questions, earn points and help others
