Question about Samsung Televison & Video
High Green Color While Screening
I tried most of the options and procedure. Also differentiate the Cathode (R,G,B) but couldn't fixed. There is last option is to open the Factory Reset Settings. I need a procedure to open the Factory settings. (CS-722 ANT) And I also tried the Display>Menu>Mute to open the Factory Settings from where I can reset the whole Tv settings. But this also not works. Could you please tell me the exact functions to open the Factory Settings Menu. May be it will be helpful.
    Top Expert:
  • Samsung Master
  • 75,591 Answers
If you can't adjust the green drive and cut-off even by using its service mode, just check all the related component/s at the green output section circuit [at the CRT] board. Replace the Green output transisor. If this do not help you, the main chroma IC might be faulty, Check all the voltages RGB out from it, and verify, if all of it are almost equal.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 26, 2014
techman
  • 3130 Answers
SOURCE: mitsubishi cs-26ex1
If your set has Picture in Picture, I would say your problem is with the PIP module. if it does not have PIP then the problem is most likly in the video switching or the video processor Printed circuit board. if you know anything about solid stae serviceing, there is a modification I will include here for the PIP as the module is no longer available and has to be jumped out of the curcuit.. Good Luck. Follow the picture and instuctions to the "T" PS please do not forget to rate this thread
Posted on Oct 17, 2006
frankmann
  • 47 Answers
SOURCE: How do I reset my tv to default.
They must have them made that way so hotel guests cannot change the settings. Maybe there is a reset button on the back somewhere? I don't know of TV's having these. Some dvd players and recorders have them. It could be a small hole too that you have to press the button with a paperclip.
Thats my best guesses.
Posted on Dec 10, 2007
CO3OV
  • 9 Answers
SOURCE: lg television du-27fb32c reset to factory settings
mute on the remote and menu on tv
service mode and go to factory reset
Posted on Dec 17, 2007
techman
  • 3130 Answers
SOURCE: Lost the Manual & can't tune digital channels, option not available on menu ?
Here is a link where you can down load a free copy of your customer user manual. Good Luck
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS120&LOC=3
Posted on Feb 03, 2008
SOURCE: need to reset my toshiba 32mw7db back to facory settings
Try pressing mute on remote, then press mute again while holding down menu on tv to enter service mode. HTH
Posted on Oct 31, 2008
High Green Color In Screen
Yes, if you have a chunghop universal remote or equivalent. Tell me the code, Have been through about 23 service mode factory methods on almost all television brands. So i can possibly help. Thanks for using Fixya.
Mar 21, 2014 | Samsung Televison & Video
Sir I've got problem with my sharp 20" standard rca tv model 20v-J300XB. I need to have a service mode procedure to balance its G-drive for it has strong green screen..but if its still not through the...
Have you checked all the cathode voltages (Rg, Bg & Gg)? If not check it. If the Gg voltage is found much less than the other two cathode voltages, the fault might be to the green video output transistor, or its collector load resistor. In service mode too, there are adjustments. All of it cannot be stated here. anyway, check the above stated voltages first. CRT cathodes are negative biased, that is, if the voltage at the cathode become low, the intensity of color to that cathode too. If you wish to get more details, come over by comment. To get more details, http://electronicshelponline.blogspot.com/
google.com/+GopakumarGopalan
Nov 16, 2013 | Televison & Video
I posted a problem on how to remove panel but I solved it. Now as I mentioned the tv comes on goes green then black no picture just sound. I followed instructions on adjusting G screw but it doesnt work...
Its possible one of two thing have occurred, you have maladjusted the G screen control on the high voltage screens and focus assembly. Turn down (counterclockwise) all three of the screen drivers. Adjust each until a light appears in the each lens, red green and blue. Go slow or lines will appear if set too high. If all three lamps stay lit after this adjustment the look at your screen with color level down to zero using your remote and the picture menu. Adjust the three color drives to get a good black and white balance appearing on the screen. Now adjust the color level from the picture menu back up to normal range.
If you still get green diagonal lines after this adjustment then I would suspect that the green lens has a heater to cathode short in the tube.
Oct 12, 2017 | Televison & Video
Pink color appearence when swith on tv for 1 minutes & wringles form on the screen
Hello
Pink colour denotes the absence of green colour dispay in your picture tube. I hereby gies an approximate voltages at the three cathodes of your picture tube socket solderings, and you just measure the voltages with reference to this. The voltages are approximate, and can chage up to 2% up or down.
Green Cathode = Pin number 9 [161VDC approx]; Blue Cathode = Pin number 8 [162VDC apprpx]; and Red cathode = Pin number 10 [157VDC approx]
If any of these voltage differes, the clolur related to that cahode will also rise or low, thath is if the cathode voltage goes very low, that clour will be prdominent, and if it goes high, that colour will not be there.
In your TVs case, the green cathode voltage now will be high. t may be due to a soldering loose to either to the picture tube base socket or at the terminals of the related transistor or Ic. It is best to resolder the suspected loose soldering points by applying a little more solder, as we in service field also do. It is very difficult to locate the exact loose soldering point and so I advice you to do so. If needs, replace the colour output transistors, of other devices if used. Just look at the voateg at pin number 9 at the picture tube base card. Resolder all the picture tube base socket pins. If you wants any more calrification, contact me through Fixya. Ok.
Nov 25, 2010 | Sony KV-T29CF1 TV
Green haze on picture at all times.
High voltage in your green cathode.maybe loose connection or deffective color transistor driver.
Oct 06, 2010 | Sony KDS-R60XBR2 Television
There no color only red d its plays but all the color is red it was playing last night it brinked then rede came on 18222
Before you go any further you need to press menu on your remote go to picture press select and then go to convergence press select again then a white cross should apear on the screen. Your objective is to converge or line the blue and green crosses up so that they appear as one cross. After you do this look at the directions at the bottom of your screen. Select the prompt that lets you continue. After you press continue several crosses should appear all over the screen do the same for these crosses as you did on the previous screen. This should solve your problem. If this doesnt fix it there is no high going voltage to your green and blue CRT's (cathode ray tubes). This could be caused by a number of things. I would take it to the nearest service tech being that you are dealing with high voltages comming from the tripler so high that if your hand or tool gets to close it could arc and ground through you even if the set is not connected to the power source
Jul 05, 2010 | Akai PTH5498 54" Rear Projection...
Color in corner going bad
U drop this tv before,like CRT yoke in cathode ray tube have big jumbo.Any magnatic around also,Tries moves the the difference directions might help,like northwest,southeast,so on.
Oct 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Crt monitor video chroma processing
first you check the signal cable continuty by multimeter then correct it if faulty .if ok then give -ve click at red cathode on crt base in on condition if red raster comes on screen then red cathode is ok same thing for green and blue cathode if green cathode do not shows green raster after -ve click then crt is faulty then give -ve click at R point at color raster ic which has heat sink if red color comes then ic is ok same thing for green and blue if ic is faulty then replace it if not then check bipolar capacitor if faulty then replace it
Sep 15, 2008 | AOC CT720G 17" CRT Monitor
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
Televison & Video Logo
35 people viewed this question
Jerry Greenberg
Jerry Greenberg
