Question about Samsung Televison & Video
High Green Color In Screen
I tried most of the options and procedure. Also differentiate the Cathode (R,G,B) but couldn't fixed. There is last option is to open the Factory Reset Settings. I need a procedure to open the Factory settings. (CS-722 ANT) And I also tried the Display>Menu>Mute to open the Factory Settings from where I can reset the whole Tv settings. But this also not works. Could you please tell me the exact functions to open the Factory Settings Menu. May be it will be helpful.
    Habit-Forming:
    New Friend:
  • 173 Answers
Yes, if you have a chunghop universal remote or equivalent. Tell me the code, Have been through about 23 service mode factory methods on almost all television brands. So i can possibly help. Thanks for using Fixya.
Posted on Mar 23, 2014
techman
  • 3130 Answers
SOURCE: mitsubishi cs-26ex1
If your set has Picture in Picture, I would say your problem is with the PIP module. if it does not have PIP then the problem is most likly in the video switching or the video processor Printed circuit board. if you know anything about solid stae serviceing, there is a modification I will include here for the PIP as the module is no longer available and has to be jumped out of the curcuit.. Good Luck. Follow the picture and instuctions to the "T" PS please do not forget to rate this thread
Posted on Oct 17, 2006
frankmann
  • 47 Answers
SOURCE: How do I reset my tv to default.
They must have them made that way so hotel guests cannot change the settings. Maybe there is a reset button on the back somewhere? I don't know of TV's having these. Some dvd players and recorders have them. It could be a small hole too that you have to press the button with a paperclip.
Thats my best guesses.
Posted on Dec 10, 2007
CO3OV
  • 9 Answers
SOURCE: lg television du-27fb32c reset to factory settings
mute on the remote and menu on tv
service mode and go to factory reset
Posted on Dec 17, 2007
techman
  • 3130 Answers
SOURCE: Lost the Manual & can't tune digital channels, option not available on menu ?
Here is a link where you can down load a free copy of your customer user manual. Good Luck
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS120&LOC=3
Posted on Feb 03, 2008
SOURCE: need to reset my toshiba 32mw7db back to facory settings
Try pressing mute on remote, then press mute again while holding down menu on tv to enter service mode. HTH
Posted on Oct 31, 2008
I want to turn my TV onto high definition for gaming. How do I do that. I have looked in the menu but cant see an option for the high definition. I just bought a Teac LEV32A1HD. Cheers.
Well, that depends on what you are using for your gaming. If you are using something like a Nintendo 3DS, a PS4, an Xbox One, an Xbox 360, or a PS3 there should be RCA connectors (3 - red, white, and yellow) or on the higher end consoles even an HDMI port, simply plug the cables into the corresponding female connectors on the console and on the back of your TEAC. If you have an HDMI output on your console, get an HDMI cable and plug that in (your TEAC has 3HDMI ports).
Once you have done this, take the TV remote and click "Setup." This will take you to the "Source" screen. In the 3rd section down, you should see HDMI1, HDMI2, HDMI3, and PC. The choice you make here depends on which HDMI port you used for gaming. Choose that one and click the "OK" button on your remote. If you hooked it up correctly, you should see something on the screen relating to your gaming console. If you do, then start playing your game!
If you don't want to or can't use the HDMI ports, your other option is to use the RCA ports. These are colored, usually, red, white, and a third color. Plug the red and white connectors into the corresponding connectors and place the last color (yellow, green, etc.) into the last connector. Follow the above Setup procedure except for choosing the Input. In this case, I believe you should choose the YPbPr input.
If you are using a computer for gaming, you must use an HDMI port. The Setup procedure is the same for setting up a gaming console.
Happy gaming!
Oct 17, 2014 | Audio Players & Recorders
High Green Color While Screening
If you can't adjust the green drive and cut-off even by using its service mode, just check all the related component/s at the green output section circuit [at the CRT] board. Replace the Green output transisor. If this do not help you, the main chroma IC might be faulty, Check all the voltages RGB out from it, and verify, if all of it are almost equal.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 21, 2014 | Samsung Televison & Video
Sir I've got problem with my sharp 20" standard rca tv model 20v-J300XB. I need to have a service mode procedure to balance its G-drive for it has strong green screen..but if its still not through the...
Have you checked all the cathode voltages (Rg, Bg & Gg)? If not check it. If the Gg voltage is found much less than the other two cathode voltages, the fault might be to the green video output transistor, or its collector load resistor. In service mode too, there are adjustments. All of it cannot be stated here. anyway, check the above stated voltages first. CRT cathodes are negative biased, that is, if the voltage at the cathode become low, the intensity of color to that cathode too. If you wish to get more details, come over by comment. To get more details, http://electronicshelponline.blogspot.com/
google.com/+GopakumarGopalan
Nov 16, 2013 | Televison & Video
I posted a problem on how to remove panel but I solved it. Now as I mentioned the tv comes on goes green then black no picture just sound. I followed instructions on adjusting G screw but it doesnt work...
Its possible one of two thing have occurred, you have maladjusted the G screen control on the high voltage screens and focus assembly. Turn down (counterclockwise) all three of the screen drivers. Adjust each until a light appears in the each lens, red green and blue. Go slow or lines will appear if set too high. If all three lamps stay lit after this adjustment the look at your screen with color level down to zero using your remote and the picture menu. Adjust the three color drives to get a good black and white balance appearing on the screen. Now adjust the color level from the picture menu back up to normal range.
If you still get green diagonal lines after this adjustment then I would suspect that the green lens has a heater to cathode short in the tube.
Oct 12, 2017 | Televison & Video
My camera is messed up the screen is like a dark green and i dont know how to fix it ?
if its only green in camera mode then look in the camera options then in fun stuff (like picture frames and stamps) there you will see Color mode this is where you change the color tint to green bloe red etc. Change it to defalult or normal and wah-lah that should fix it. Thats the procedure on my SANYO INCOGNITO **** I have learned that its very similar to other phones as well. Good luck and I hope this helps ya.
Aug 15, 2012 | Samsung Reclaim Cell Phone
What causes the picture to have a green tint
there are 3 color cathode in your TV red,green,blue cathode.The red and blue cathode might not working in your set that is why you have a green screen. Open the back cover of your TV you can immediately see the 3 cathode lamp at the back. Clean the lamp first using a clean clothe. Power up you tv and see whether the 3 lamps are lit. If lamps do not light up,check the circuit board where this lamp is connected re-solder all the components in this lamp. There is also an individual screen adjustment for the lamps it is located at the front panel and labeled RGB screen...try this first and let me know how it goes..
Apr 16, 2011 | Zenith E44W46LCD 44" Rear Projection...
Philips 30PW850H 30" TV screen is completely
hi,
normally color crt tvs have three guns such as red green and blue. when the voltage at the cathode any of these guns go to zero that color will lead in the screen.
in ur case the green cathode voltage is low. that's why the is green on all over the screen.
if it suddenly came then there is a possibility of dry soldering in the pcb behind the picture tubes neck. we called it as base board. which consist of three transistor or one ic for cotrolling cathode voltage of the guns .
if u have a soldering iron the open ur tv and try to re-solder components in the base board. mainly the component with three leg ( if transistor). if there is ic it will have more than 6 legs . if you can try to re-solder all the points. Be care-full that dot make short circuit when soldering. after care full soldering power on the tv and watch the scree. you problem Will solved.
if u need any further assistance from me, feel free to contact me through fixya.
ok
Jan 16, 2011 | Philips 30PW850H 30" TV
There no color only red d its plays but all the color is red it was playing last night it brinked then rede came on 18222
Before you go any further you need to press menu on your remote go to picture press select and then go to convergence press select again then a white cross should apear on the screen. Your objective is to converge or line the blue and green crosses up so that they appear as one cross. After you do this look at the directions at the bottom of your screen. Select the prompt that lets you continue. After you press continue several crosses should appear all over the screen do the same for these crosses as you did on the previous screen. This should solve your problem. If this doesnt fix it there is no high going voltage to your green and blue CRT's (cathode ray tubes). This could be caused by a number of things. I would take it to the nearest service tech being that you are dealing with high voltages comming from the tripler so high that if your hand or tool gets to close it could arc and ground through you even if the set is not connected to the power source
Jul 05, 2010 | Akai PTH5498 54" Rear Projection...
Crt monitor video chroma processing
first you check the signal cable continuty by multimeter then correct it if faulty .if ok then give -ve click at red cathode on crt base in on condition if red raster comes on screen then red cathode is ok same thing for green and blue cathode if green cathode do not shows green raster after -ve click then crt is faulty then give -ve click at R point at color raster ic which has heat sink if red color comes then ic is ok same thing for green and blue if ic is faulty then replace it if not then check bipolar capacitor if faulty then replace it
Sep 15, 2008 | AOC CT720G 17" CRT Monitor
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
Televison & Video Logo
52 people viewed this question
Jerry Greenberg
Jerry Greenberg
