Question about HP zr2740w
Power failure upon start up - HP zr2740w
Toshiba Satellite L505D-S5983 black screen
Hold the power button down until the unit shuts off, wait 10 seconds then turn it on again.
Upon restarting, make sure to choose Start Normally if the startup failure menu comes up.
Apr 13, 2014 | Toshiba Satellite Computers & Internet
Clicking sound upon power up
If it is the hard drive that is clicking, you have a dead hard drive.
Mar 21, 2013 | SimpleTech Hitachi SimpleDrivell 2TB Turbo...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
The PC will not complete power up. After power button is depressed the motor revs up and continues to stay in this state . It does not appear to read the ROM or anything else. It remaines stuck in this...
hard drive failure.. can u get into the bios upon boot up if so, try a boot disk if u have one an see if u can start from their.. if your hard drive is out when u try to go to c:/ after having succesfully booted from a boot disk you will get a prompt saying you are unable to connect to this drive.. if upon power up u are unable to get into the bios or the boot disk does not work you may have a mother board/prossessor out..
Apr 28, 2010 | Sony PCV-RS420 (027242635845) PC Desktop
My compaq evo beeps 1 short 2 long but nothing on screen
This POST (power on self test) error code could be this depending upon the BIOS manufacturer.
one long, two short beeps
  • System board failure
  • Video adapter problem
  • LCD assembly failure
Feb 27, 2010 | Compaq Computers & Internet
Power failure upon pressing shutter button
hi
dear ur battery is not working properly replace the battery
Dec 14, 2009 | Canon EOS 40D Digital Camera
I have 2 GX520's that are buzzing when trying to boot
If your computer beeps during start-up:
  1. Write down the beep code
Code
Cause
1-1-2
Microprocessor register failure
1-1-3
NVRAM read/write failure
1-1-4
ROM BIOS checksum failure
1-2-1
Programmable interval timer failure
1-2-2
DMA initialization failure
1-2-3
DMA page register read/write failure
1-3
Video Memory test failure
1-3-1 through 2-4-4
Memory not being properly identified or used
3-1-1
Slave DMA register failure
3-1-2
Master DMA register failure
3-1-3
Master interrupt mask register failure
3-1-4
Slave interrupt mask register failure
3-2-2
Interrupt vector loading failure
3-2-4
Keyboard Controller test failure
3-3-1
NVRAM power loss
3-3-2
Invalid NVRAM configuration
3-3-4
3-4-1
Screen initialization failure
3-4-2
Screen retrace failure
3-4-3
Search for video ROM failure
4-2-1
No timer tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
Unexpected interrupt in protected mode
4-3-1
Memory failure above address 0FFFFh
4-3-3
Timer-chip counter 2 failure
4-3-4
Time-of-day clock stopped
4-4-1
Serial or parallel port test failure
4-4-2
Failure to decompress code to shadowed memory
4-4-3
Math-coprocessor test failure
4-4-4
Cache test failure
Apr 11, 2009 | Dell OptiPlex GX520 PC Desktop
"Disc Boot Failure" upon powering up the compaq
your harddisk is not detected.
open your cpu case.
then reattch the power code and datacode to hard disk.
Nov 03, 2008 | Compaq Presario S6300NX PC Desktop
Alarms
Hello, find the BIOS Beep Codes at http://www.amptron.com/html/bios.beepcodes.html and try to find your problem. It is not a software or Monitor problem. It could be RAM or Video Card failure
Aug 04, 2007 | Biostar M7VIZ Motherboard
HP zr2740w Logo
Top HP Televison & Video Experts
Tony
Computer Links
vbalag
Level 1 Expert
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
