Question about PfaFF Sewing Machines
Thread caught in pfaff 1475 shuttle
Thread is caught in pfaff 1475 shuttle - how do I get it out. Won't pull out
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • PfaFF Expert
  • 300 Answers
Spray a little WD40 on the broken thread, it makes it easier to pull out, also use dental picks to get in there.
Posted on May 14, 2014
SOURCE: Pfaff sewing machine 463
how do you thread a Pfaff sewing machine
Posted on Jun 15, 2008
SOURCE: Thread bunching up on bottom of fabric
Try making sure that the thread is all the way in the tension disk then test it out. I had a similar experience with an old machine.
Posted on Jul 20, 2009
SOURCE: The top thread gets caught in the shuttle hook and
I am having same problem
Posted on Sep 27, 2009
  • 36 Answers
SOURCE: Thread continuously getting ****/caught in shuttle
My first thought would be to check the threading on the top, all though it may look right undo it and redo it its real easy to get the tread behind the tension discs, instead of between them. If all that is right check your upper tension, but not until you have rethreaded it.
Posted on Jun 03, 2010
SOURCE: Toyota RS2000, problems with shuttle hook
my suggestion is to have it checked, sometimes sewing thick fabric on some machines can cause a problem.
Posted on Jul 31, 2010
My pfaff 1475 CD thread is loopy on bottom and breaks on top.
Look very closely at your sample stitching and determine which thread (top or bobbin) is looping and which is breaking. That will narrow down where the problem exists.
A top thread that loops and makes thread "barfs" under the fabric is generally an upper thread tension problem.
Try: Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Set the upper tension to the midway point (probably will need to tweak this tension depending on your machine).
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Understanding Thread Tension Threads
Sewing Machine Tension
Apr 12, 2017 | PfaFF Sewing Machines
Thread jam above the needle...I'm afraid to pull it from the top as I work the needle wheel manually in case it breaks off inside...
This may be helpful:
Pfixing the Pfaff
Most likely there is a worn groove or a rough spot that has caught the thread. I have an older machine that has an issue and have had to cover the spot with duct tape, although there may be other fixes.
If you are concerned about doing it yourself, just take it to a sewing repair shop and see if they can fix it there for you.
Aug 23, 2016 | PfaFF Sewing Machines
Pfaff 1475 manual
Not sure if your model is the creative 1475. The closest I can find at a service website of Pfaff is 1473. Check if this is similar to your model and it shows where the balance wheel goes.
http://new.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Creative_1473-manual-EN.pdf
Also see this Youtube video showing how to insert the bobbin after threading.
Pfaff Creative 1473 CD sewing machine in action
otherwise you will have to buy service manual for eBay
PFAFF CREATIVE 1475CD Sewing Machine Service Manual
Aug 12, 2014 | PfaFF Sewing Machines
How do you remove thread caught in bobbin shuttle
I usually use my seam ripper tip and a tweezer.
Aug 09, 2014 | PfaFF Creative 7570
My pfaff 1475 is looping when sewing a zipper
I have a 1475. I've generally found that this occurs when the needle thread tension is too low; the thread, having looped around the bobbin, isn't getting pulled back up because the tension is low enough that thread can be pulled from the spool more easily than the needle thread can be pulled back up from below the work. In some cases, switching to a larger needle is required; a bigger needle makes a bigger hole, which means it's easier for the thread to be pulled back up. (And if you switched to a heavier thread for the zipper, then you probably needed to go up to a larger needle anyway. Just because the thread will go through the eye, that doesn't mean the needle's the right size.)
May 09, 2012 | Sewing Machines
Thread jamming under fabric
bobbins in backwards
flip it over
Dec 18, 2009 | Kenmore Sewing Machines
The machine keeps locking up. i have cleaned the bobbin and hook area. there was not much lint
if your machine has a front loading bobbin case, remove it and then remove the shuttle which the bobbin case fits into. most often there is thread or lint caught in the shuttle race preventing the shuttle from turning (it only needs a tiny piece of thread).
if you have done this check any gear meshing to ensure no lint or thread has been caught in the teeth of the gears.
if the machine sews ok and locks up after a few stitches then it sounds like needle threading or tension causing the problem. re-thread the machine and ensure there is sufficient needle thread tension to bend the needle a little when presser foot is down and thread is pulled through needle.
goodluck,
scott.
Jul 28, 2009 | Kenmore Sewing Machines
Bobbin tension
Check also this links, hope they can help you:
Pfaff 1475 7570 7560 FAQ
threading a pfaff creative 7570
Aug 10, 2008 | PfaFF Creative 7570
Sewing Machines Logo
157 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
