Question about Sewing Machines
My sewing machine Riccar 555 SU keeps bunching up
My sewing machine Riccar 555 SU keeps bunching up at the bottom Im used to singer machines Can anyone help I don't have a manual I just need to know the proper nob settings
  • Sewing Machines Master
  • 662 Answers
1. Check the lower bobbin tension. Hang it from your finger and adjust until it will unwind about an inch when you bounce it up and down.
2. Ensure the bobbin carrier is inside the machine properly.
When proper and adjusted right you should notice the thread be pick up and move around the bobbin when you move the wheel with your hand. If it sticks then the small piece of metal w/screw located next to the bobbin carrier will need to be loosened and moved slightly away from the carrier. Another thing to check is the piece that is in the bobbin carrier is a pointed object that moves. Remove it and check the point if it is rough. If it is then use a piece of sandpaper to fix it. Try this test again.
3. Feel your top thread when it moves through the needle plate to see if their is a snag when going through it. If there is then you need to smoothen the hole with a finger nail file. Try this test again.
4. Make sure these all past the test or it sewing will be a problem. These things I've mentioned are really easy so let them sound hard.
Posted on Apr 09, 2014
SOURCE: How to set timming on Singer Touch & Sew 638 Sewing Machine
I have a timing problem with my Touch&Sew Singer model 638.
Jean
rlacasse@ntl.sympatico.ca
Posted on Sep 17, 2008
sew dutch
  • 25 Answers
SOURCE: keeps "birdnesting", besides rethreading, how do I fix?
when you have bunching on the bottom, you have a problem with the top thread: no tension. (and visa versa) Make sure the thread runs through the tension discs, these discs are activated when you put the presser foot down, so you want to thread the machine with the foot up, also feel if there no burrs, hooks, or whatever, so your top thread comes smooth off the spool, no jerking.
Posted on May 26, 2009
  • 1116 Answers
SOURCE: 8280 Mechanical Sewing Machine: i need free manual for singer sewing machine model...
Free download here - http://www.singerco.com/accessories/manuals.html
Posted on May 07, 2010
  • 1788 Answers
SOURCE: Looking for Riccar sewing machine manual
you can get the manual by goggling Riccar 1570 manual for free. It will download, no problem
Posted on Jul 26, 2010
hazelgrace
  • 340 Answers
SOURCE: Need parts/manual for old Riccar sewing machine
Here's a manual for the 551, it should be similar enough for your machine.
http://www.riccar.com/ftp/whitepapers/551-Owners-Manual.pdf
If not look on www.riccar.com/help/manuals for a similar model.
Find out what shank your machine is and you should be able to buy parts for it. I find ebay great for old sewing machine parts.
Hope this helps!
Posted on Sep 14, 2010
Thread keeps bunching on the bottom of thick material
try a different needle
here's a link to a free manual from singer
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
some machine can't handle thick fabric & some can
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
make sure the thread has not come off the thread take up lever
Aug 20, 2012 | Singer Curvy 8770 Electronic Sewing...
Singer 758 model and the thread is bunching up from the bobbin under the material
try changing the needle--flat side goes to the back of machine
rethread the machine top & bobbin--make sure to use every thread guide
make sure bobbin is wound correctly & inserted correctly in the bobbin case
clean under the needle plate & in the bobbin area for lint or loose threads
if you don't have a manual try singer
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number(example 758)
Click search
Apr 10, 2012 | Singer Sewing Machines
I have a singer sewing machine model # 758 touch n sew and I cannot find how to set the bobbin thread tention. The thread bunches up under the bottom plate and adjusting the upper thread tention does not...
Hi, welcome to fixya, maybe I can be of some help
I checked on singer website & they have a free downloadable instruction manual in PDF form just follow the these steps
Go to the home page
At the bottom of the page look for instruction manual--click on it
It will take you to another page
In the box put the model number (example 758 )& click search
the second one is free
Sep 10, 2011 | Singer Sewing Machines
Where do i fix the tension at? i understand there is a top and bottom but i just dont understand. The thread keeps getting bunched up. It sews good for a bit then it just bunches up and i dont know what...
why dont you visit this website and read up some of the general info on sewing machines, should help you get started.
http://sewing.about.com/od/sewingmachineindex/bb/sewingmachines.htm
Usually you should only need to adjust the top tension a little bit for different fabrics but generally it should be fine on 5. Bottom tension is set by a little screw on the bobbin case (if yours is a removable front loading type) or sometimes a little dial if fixed horizontal bobbin case design. If machine has been set up correctly from new then bottom tension should not need to be touched at all.
It sounds more like your machine is not threaded properly, causing the thread bunching up to occur. If you don't have a manual you may find a threading diagram at www.sewusa.com or www.singerco.com, the Singer website has instruction manuals for download free for many models.
It sounds like you may be a beginner sewer, in which case, I highly recommend taking a few classes to learn how to best utilise your machine and save lots of frustration too.
Jul 07, 2011 | Singer 1507
When i try to sew a bunch of thread is balled up on the bottom of the material and im not getting anywhere but wasting a lot of thread do you know what is going on?
Your top threading is not right, double check your manual. If, you don't have one go to singerco.com and download one for free
Sep 08, 2010 | Singer 5050 Mechanical Sewing Machine
Hope this helps!
Jul 18, 2010 | Riccar R552
Bobbin tension problem with kenmore model 385.16231300
If You have a drop in bobbin you will have to remove the hook and adjust the tension, however try adjusting the top tension before you remove the hook.
Jul 17, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Keeps "birdnesting", besides rethreading, how do I fix?
May 24, 2009 | Singer Sewing Machines
Sewing Machines Logo
62 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
