Hw701 sentry wireless headphone and transmitter not workin with my LG tv
HW701 sentry headphone and transmitter
SOURCE: logitech wireless headphones
Trying re-syncing the transmitter and the headphones. Hold down the power buttons on both until they alternate red and blue blinking, worked for me and now they work just fine. Got that from the Logitech FAQ website.
Posted on Mar 19, 2008
SOURCE: Sennheiser Wireless Headphone Stops transmitting signal
I had the same problem when I plugged it into a new HDTV. The problem was that the sound on the TV was set too low. The transmitter has a feature that automatically turns off when the signal is off or too low. Try turning up the TV volume to a high/higher level and it should solve your problem. Using the headphone jack with the white input allows you to use the headphones while bypassing the TV speakers.
Posted on May 02, 2009
  • 155 Answers
SOURCE: audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Posted on Jul 07, 2009
SOURCE: install wireless headphones
how to change batterys in sentry ho800 headphones
Posted on Oct 07, 2009
SOURCE: I can't get the Sentry Wireless headphones (HO800)
how to change batterys in sentery ho800 headphones
Sentry HW701 wireless headphones no sound right side when audio cable is plugged into them
try getting a new cable.If that does not work then the problem is the audio input port.
Aug 13, 2016 | Sentry Audio Players & Recorders
Connect headphones to tv
It sounds like you have wireless headphones so maybe its not tv maybe more like transmitter signal between headphones and reciever so hopefully you have a way to test siganal. However the default headphone jack on TV should work fine unless turned off in audio settings in TV. Hope some of this helps you.
Apr 15, 2014 | Panasonic Audio Players & Recorders
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Yup. If the headphones are driven by the TV, then turning down the TV turns down the headphones. Check to see if the TV has an audio output setting where you can select either the TV speakers or the headphone jack. What brand and model TV is it?
Oct 31, 2013 | Televison & Video
I bought wireless headphones, how do i connect them to the TV wirelessly
Normally the wireless headphones have a transmitter that send audio via wireless to the wireless headphones.
The transmitter needs to be plugged into the headphone outlet on the TV. This will switch off the speakers on the TV and sends the audio to the wireless headphones.
Sep 23, 2012 | LG 32LG30 32 in. LCD HDTV
NO AUDIO SENTRY H0900
It works, Its that I just needed to find an Audio out port. (which I currently dont have due to lack of a cable box in my room)
Jan 05, 2010 | Sentry HO900 Headphones
Power pack creates 'hummmm' in wireless headphones.
I don't think the 12V power pack is the problem. Generally there would be a regulator on the plug pack input to the transmitter (as power packs are notoriously bad at voltage regulation).
My guess is it an 'earth leak' between the TV and the transmitter via the audio lead. Does the powerpack have a earth pin. If so, are you able to plug it into an non-earthed power outlet.
If this isn't possible try removing the ground connection from the audio lead.
It could also be a bad audio lead.
Is the TV mono and the transmitter stereo or visa versa? You may need a mono to stereo lead.
Hopefully something in here will help.
Mar 17, 2009 | Electronics - Others
Power pack creates 'hummmm' in headphones.
GKLHKJHKLHKLHKLHKLHKJLHKL
please rate this solution?? hahaha lol here you go
Mar 17, 2009 | 1996 kawasaki ZZR 1100
Sentry HO900 headphones
The H0900 should come with a mini-plug adapter. The headphone jack in my TV was deeply inset, so I kinda reversed it. The adapter plugs into the transmitter, then the Red/White plugs, into that, then the long end of the cord into the TV.
Works fine for me. My problem will be posted seperately.
Mar 09, 2008 | Sentry HO900 Headphones
Install wireless headphones
Oct 27, 2007 | Sony MDR-RF960RK Consumer Headset
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
