Question about Euro-Pro Ninja Kitchen System 1100 - Model BL700
How do I dissemble a Ninja Blender container handle?
Food has gotten into the handle assembly on the Ninja Blender container (not the lid) There are 2 screws that loosen the bottom of the handle but it does not seem to want to come off. I would hate to force it an break it. Is there a process?
Ninja blender 1100single server sticks after using hard to loosen
I experienced the blades freezing on a different blender after making smoothies and letting the unit sit for some time. The problem was sugar seeping into bearing interface and solidifying. I soaked the blade assembly in water and they freed up.
I now add water to blender container after each use and operate it until clear water seeps out the bottom of the bearing.
Oct 24, 2014 | NINJA Kitchen System 1100 - As Seen On...
The power light on the Ninja Blender flashes and will not turn on.
Make sure the pitcher lid is assembled properly aligning the arrow on the lid with the arrow on the handle. Press down firmly on the handle until you hear a slight click to ensure it is fully engaged. The Ninja will not run if the lid is not assembled correctly & the handle is not fully engaged.
Sep 28, 2014 | Euro-Pro Ninja Nj600 1000 Watt Xl...
Where do I find lids for the nj600 blender
Ninja Professional Blender . if this link works it will show the lid for the blender. If the link does not work, do a web search " Parts and accessories-Ninja. On the top menu, click on parts and scroll down to Ninja professional blender nj600 and click on it.
Jun 06, 2014 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
How to remove the blender top
http://www.ninjakitchen.com/manual/NJ600_30_IB_ENG_100226.pdf
on page ten it describes how to remove the lid by lifting the handle and pulling straight up, also shows a diagram.
Nov 10, 2013 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
How to remove the top
are you pushing the handle release button on the lid, swinging the handle straight up and pulling on the handle straight up?
see page ten figure 6: http://www.ninjakitchen.com/manual/NJ600_30_IB_ENG_100527.pdf
Ninja lid removal
your pushing the handle release button on the lid, swinging the handle straight up and pulling on the handle straight up?
Nov 10, 2013 | As Seen On TV Ninja Professional Blender
Ninja blender blade wont turn with food in container.
make sure blade is pressed tightly onto shaft... should click into indent. if not then you need a new blade piece.- stripped
Aug 18, 2012 | Blenders
The power button is flashing red in my ninja nj600
Arrow on lid, Arrow on handle. Line them up. I just did it. I knew it was something simple but I didn't think it would be that simple.
May 29, 2012 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
Ninja blender second time we have used it. the power light is blinking when you push it and the blender will not turn on
Put the lid on so the arrows meet up. There is a arrow on the lid and handle put them to gather and blend!
Jul 14, 2011 | Blenders
Euro-Pro Ninja Kitchen System 1100 - Model BL700 Logo
Top Euro-Pro Blenders Experts
spy1309
Tom Chichester
Kolbrun...
Are you an Euro-Pro Blender Expert? Answer questions, earn points and help others
