Question about Wolff Sunquest 16se Tanning Bed
Wiring diagram for T85 Typ601 timer switch
Need wiring diagram timer for timer switch
Connection diagram for diehl t85 typ 600
1) Copy following links.
http://waterheatertimer.org/images/Deihl-T85-600-wired-for-208-230-Volt.jpg
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#T85
2) 3-pin 5 amp service has 2 hot legs (wires) located across from each other on outlet.
Interrupt one hot wire and circuit turns OFF.
However live power potential still exists on remaining hot leg.
3) To turn off both Hot legs, use DPDT spring-wound timer such as Intermatic 60 minute FF460M or FD460M
http://waterheatertimer.org/pdf/039_FF-series-sell-sheet-with-wiring.pdf
Jan 05, 2013 | Diehl Hardware & Accessories
System scheck failed
adjust the REED switch and speed sensor, test both for open or faulty and replace if necessary+ CLEAN it, tight the plug or connector very well.
see the diagrams attached
God bless you
12_10_2012_9_32_15_pm.gif12_10_2012_9_33_22_pm.gif12_10_2012_9_34_58_pm.gif12_10_2012_9_35_19_pm.gif
Dec 10, 2012 | Tunturi T85 Treadmill
How do i wire diehl t85 type 600
1) Copy following links for wiring Deihl T85 600 timer.
http://waterheatertimer.org/images/Deihl-Type-600-T85-timer.jpg
2) This timer will turn off Hot wire in 120Volt circuit.
3) For 208-230 Volt applications, the timer will operate by turning off 1 hot leg. However other hot leg will still have live power. To turn off both Hot legs, use DPDT spring-wound timer such as Intermatic 60 minute FF460M or FD460M
Feb 28, 2012 | Diehl Hardware & Accessories
I have a paragon 8145-20 defrost timer. do you wire the compressor to the timer? I cant seem to find a wiring diagram on how to wire this correctly
Link below has wiring diagrams and wiring manuals for 240V 8145-20
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
I am not expert installing defrost timers.
According to information from Paragon, 8145 is for hot gas defrosting. 8140 series are time initiated, and pressure-or-temperature terminated.
Wiring diagram does not show compressor wired to timer.
The cycle works like this:
Timer is running but defrost is not switched ON.
Fan is ON.
Timer switches ON and activates defrost cycle.
Fan turns OFF. Hot gas valve turns ON for defrosting.
Cycle limit switch is temperature or pressure sensitive.
Cycle limit switch reaches trip point, timer switches OFF.
Hot gas valve turns OFF. Fan turns ON.
So fan is off during defrost cycle.
Hot gas valve turns ON when timer switches ON.
Timer is switched OFF by pressure-or-temperature limit switch.
Dec 09, 2010 | Paragon 8145-20 Defrost Timer
Need connection diagram Thks
The following diagram is for timers with green, black, white, and red wires:
If your timer is different, add a comment with model number.
Manual says:
Timer-black-wire to Hot; Timer-red-wire to Load (lights)
Timer-white-wire to Neutral.
Here's what to do
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push manual override button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Nov 14, 2010 | Woods 59007 Decora Style 3015105 Minute...
Hi my dry had a broken timer knob and the dryer would work if I pushed the knob I got a replacement part but dont know how to rewire it agen and the part looks different the old one had T80 on it but this...
Your timer switch should come with a wiring diagram.
Check with the supply house you got the timer from and let them make sure you have the right part for your model dryer.
Sometimes the new timer will be different, that is where the wiring diagram comes into play.
I hope this helps
Oct 01, 2009 | Fisher and Paykel Dryers
Diehl Timer 4 pin wiring
well..the timer is used in a variety of dryers. which model is this one going to be installed in?
Oct 15, 2008 | Dryers
Wolff Sunquest 16se Tanning Bed Logo
41 people viewed this question
Top Wolff Health & Beauty Experts
ka4iup
ka4iup
Andrew Taylor
Andrew Taylor
Are you a Wolff Health and Beauty Expert? Answer questions, earn points and help others
