I have a Westinghouse mastermind 711 It is washing with hot water when it's set to cold wash How do I get to wash with cold water
  • 90 Answers
SOURCE: no hot water to wash
Is the hot water hot that is coming to the washer? Are you using the correct settings on the unit? If yes to both then either the solinoid water valve is bad or the timer switch unit is bad. Try going to a totally hot water setting. While turning on the machine feel of the hot water line at the machine and see if you notice a buzz or feel a click as you turn on the machine. On this setting does water run in and is it hot or cold. If water runs and it is cold try going to a total cold setting and see if you get cold or hot water. Is this a new setup or has it been working and stopped? If new, you could have the hoses connected backward. If you get water in both hot and cold settings but cold both ways then your hot water heater is not working....let me know....
Posted on Feb 10, 2008
  • 1314 Answers
SOURCE: washing machine dosnt spin dry,
remove the front panel and check for obstructions in the drain pump also on some models there is a catch screen in the tub to pump hose if you have a shop vac pull the water out of the drain hose first as there will be water in the unit
Posted on Jun 03, 2008
SOURCE: se error on westinghouse mastermind
SE error is a sensor problem.This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Posted on Dec 12, 2008
  • 6 Answers
SOURCE: I have a Westinghouse mastermind 708 washing
I would check the internal coin trap/drain to make sure it is not blocked with socks or 3-in1 dryer sheets. If the water does not drain it backs up and causes error messages and spin problems. These are normally not listed in the manual so you have to take off a panel to find it. Could be at the bottom or in the back. Unscrew and check the trap and remove any blockage. Prepare for a mess if you can't fit a bucket under the trap!
Posted on Oct 23, 2009
blueextc3221
  • 15935 Answers
SOURCE: Just purchased Kenmore 800 washing machine - no warm water
If you suspect you have a defective Water Inlet valve (also known as a FILL valve or MIXING valve) it can easily be diagnosed by performing the following steps:
- First, make sure the water taps are turned on all the way, and the fill hoses are not kinked in anyway. If everything checks okay, proceed to the next step.
- Now, turn the water taps off, disconnect the fill hoses from the back of the washer and place them in the wash tub. Turn the taps back on and make sure you have proper and forceful water flow (minimum water pressure should be 10-25PSI).
- Check the sediment screens on the Water Inlet valve on the back of the washer. Sometimes these screens will clog with rust or sediment and prevent water flow. Cleaning with some distilled vinegar works well.
If you’ve attempted all the steps above, but still have no luck, more than likely the inlet valve is bad and requires replacement. Please, read all instructions thoroughly BEFORE attempting. This is a simple repair that any “Do-It-Yourselfer” can accomplish. Follow the steps provided:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. The inlet valve is located on the back panel with two or more sets of electrical connectors attached to it. The connectors are usually color-coded to indicate which valve is HOT and which valve is COLD (In the case of a Mixing Valve, you may have additional electrical connectors). Remove the connectors and check the contacts for corrosion. Sometimes a good cleaning can restore a valve solenoid to working order. (You may want to label the connectors, if necessary, to ensure you know how they go back on).
8. Disconnect the small rubber water hose(s) attached to valve with a pair of pliers to release the hose clamps. Inspect the hose(s) for any evidence of cracking.
9. With the water hose(s) removed, loosen the mounting screw(s) and the inlet valve comes off.
10. Re-install new inlet valve following these steps in reverse order. Pay careful attention to make sure you correctly connect the HOT & COLD electrical connections (RED is usually the HOT water side). Make sure all hoses are fitted back in place and the hose clamps are snug.
11. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
12. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
13. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
14. Reinstall console.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Westinghouse mastermind 711 708
Probable bearing failure
Jan 30, 2018 | Washing Machines
I have a Westinghouse Mastermind 711 Front Loader Washing Machine which is flashing OE and the clothes inside are very wet. Can you please let me know what this flashing OE means....Many Thanks, ELena
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Westinghouse Washing Machines
No cold water from washing machine. Hot water is fine.
You have to replace the cold water solenoid valve.
Oct 05, 2009 | Westinghouse Washing Machines
The machine is westinghouse mastermind 708 is there any other part that can seize besides main drum bearing?
Yes the transmission can seize. Check to see if the water inlet is blocked. Shut water off and discount hot and cold water inlets to see if they are blocked. If so then further invesigation is needed to see if something jammed inside the machine like a penny, diamond ring, earring, loose change or something small stopping the spin cycle. If this is the case you might have blown the circuit within the machine. Hope this is helpful
Aug 28, 2009 | Washing Machines
Westinghouse mastermind 700 flashing HE
I just had to lighten the load. I think that HE means heavy. It works fine now.
Aug 24, 2009 | Westinghouse Washing Machines
0E flashing on Westinghouse LF708C Washing Machine
Had the same problem. After checking that all the hoses etc were clear and no blockages, then suspected that the pump (cost $90 Australian dollar) was faulty. The Westinghouse service technician acknowledged that that was probably the problem, which I then confirmed by pulling out the pump, and then carefully connecting 240V across the pump terminals. Certainly was a faulty pump. So I spent the money on a new pump and installed it and now the washing machine (6 to 7 years old) works fantastically.
Apr 10, 2009 | Westinghouse Washing Machines
Se error on westinghouse mastermind 711 any ideas?
Dec 11, 2008 | Washing Machines
Washing machine dosnt spin dry, front loader westinghouse mastermind 708, 7.5 kg
Jun 03, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
