Washing Machines Logo
L
Lawrence Wolf Posted on Jul 22, 2017
LG WD-1019BD washing machine drain pump will NOT switch off
I recently had a the main PC board fail on this machine and found a replacement. Everything seemed to work but the machine was 'filling' for a very long time. This is because the drain pump is continually running from the start of the cycle and the machine is draining as fast as it is filling so can never reach the required water level. How do i check the water pressure transducer? could this be a faulty PC board?
5 Related Answers
gittos73
peter gittos
  • 247 Answers
  • Posted on Sep 12, 2007
SOURCE: Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Anonymous
  • 57 Answers
  • Posted on Feb 16, 2008
SOURCE: Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Anonymous
  • 725 Answers
  • Posted on Apr 05, 2008
SOURCE: I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Anonymous
  • 1073 Answers
  • Posted on Apr 20, 2008
SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Anonymous
  • Posted on Mar 20, 2009
SOURCE: whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
I have a LG wd 1412rd. Recently it has started leaking from the left had bottom corner. Do I need to replace the machine.
Most likely just a hose issue. Hose from tub to pump or from pump to drain. Easy fix. Pump is located at that area.
My LG WD-10485TP will not spin. The drain pump just keeps pumping even though it is practically empty. I have replaced the pressure switch, cleaned all the internal piping and put it in test mode and it...
It sounds as if the machine's main control board is faulty due to the drain pump running continuosly, as the only real problems causing a no spin scenario is the door latch or the Rotor assembly.
The only way to "reset" the machine is to disconnect the supply lead from the mains supply for a couple of minutes, then try again.
2helpful
2answers
I have LG Washing Machine and the water does not drain whilst the machine is washing. What can be wrong?
problem is with main board MOSFET ,FET or Transistor , that are not switching your drain pump at right time , if your'e pump is fine, , you should check drain pump separately by giving it separate supply. ( see its data sheet for power )
2helpful
Water pump failure?
The water pump drain motor has something stuck in it or it has gone bad like most LG parts.
Remove the drain pump and look for any foreign object to be removed.
Check the drain pump for a failed pump motor.
LG is pretty.
1helpful
Oe message on lg front loader washer model wm2277hb. wont drain or spin. already check the drain filter and hose. what else could be wrong
It is a long drain error and occurs when the washer is not fully drained after 10 minutes of draining. Remove the cabinet cover and check the following:
  1. Drain Pump Connector The connector may be disconnected or disassembled. Reassemble or repair if necessary.
  2. Drain pump coil
    Check pump coil resistance between the terminals using an ohmmeter. Resistance should be between 10-20 ohms. If the resistance is too high or too low, replace the drain pump.
  3. Voltage Check the voltage between the connector in step 1 during spin. The voltage should be 120Vac, else replace the main board assembly
Main board replacement:
  1. Disconnect the power connector and sensor switch assembly.
  2. Remove the main board protective cover.
  3. Disconnect the connectors.
  4. Remove the screw on the back of the main board.
  5. Slide the main board to the right then pull it up.
  6. Replace the main board in reverse order above.
OE Code LG washer - cleaned filter, checked pump still not working. Checked pump for power when should be draining and found no power to it. Pump not being told to drain. Help?
It is a long drain error. The washer is not fully drained after 10 minutes of draining. Remove the cabinet cover and check the following:
  1. Connector The connector may disconnected or disassembled. Reassemble or repair if necessary.
  2. Drain pump coil
4helpful
2answers
How to replace bearings on LG WD-1019BD washer?
To get to the bearings you need to remove the rotor as you have done, remove the front, you need to push a card under the lip of the top at the front to open the top to get out the front. Then then you need to undo all the bolts in the middle of the tub, then take out the inner drum and then you can hit the bearings out with a drift, Don't just replace the bearings, you also need to replace the seal and spider which is the 3 legged part with the main shaft on it, otherwise if you don't replace all the parts listed it will not last long before the same happens again. The problem is caused by the seal letting watter into the bearings, the new seals are mdified to help stop this happening.
LE fault code for LG WD-1019bd washer
Usually it is the stator at fault with an LE error. I would make sure the cable between the stators windings and hall sensor are ok back to the main control board also give the wires a good tug sometimes the copper breaks inside the wiring insulation at the white connection blocks. Check to make sure theres nothing got trapped inbetween the drum and tub this can lock the drum up and give the fault. After checking all the above i would think it would either be a faulty stator or the main control board has failed. Hope this helps.
LG WD-8074fhb
Your problem is either in the control board or the water level switch.  The computer can't tell if the water has drained or the control board is stuck in the 8 minute drain cycle.  Recommend pulling the plug and wait 5 minutes to reset the computer.  If the problem persists, it will require an LG experienced tech to see what's going on.
Top Washing Machines Experts
john h
