Question about Ecler NUO5 5-Ch Mixer
Channel 2 gain is way higher and channel 4 is acting weird too
I have gotten it fixed and repaired. The it was still acting weird, so I had it looked at again, and everything is fine except for channel 2 being louder than the rest of the channels. Channel 4 also seemed to have some problems but it seems to be fine right now.. Who can fix my channel eq problems without me spending hundreds and hundreds of dollars? HELP!
    Champion:
  • 219 Answers
Send it down to Caracas, bro, I have fixed a bunch of these issues.
Seriously, now, I would check and lubricate your INSERT jacks at the back. These become corroded and let little or nothing pass. Peace.
Posted on Apr 27, 2014
Channel 4 is 10 times louder than other channels why? all gains ect set the same nearly blew my speakers
Try swapping the input with another channel and see if the problem moves. Be sure to set the levels down or you may get your speakers this time. If the problem moves the source is the bad guy. If not check the gain setting, not the slider. The gain is normally the top know on the channel.
Jun 02, 2014 | Behringer DX2000USB Pro 7-Channel DJ Mixer...
What should i set the micro switch on the back at?
Power:
2 ohm stereo (per channel): 975W
4 ohm stereo (per channel): 660W
8 ohm stereo (per channel): 400W
4 ohm bridge-mono: 1950W
8 ohm bridge-mono: 1320W
Load Impedance: Safe with all types of loads. Rated for 4 and 8 ohms in Stereo mode, 4 ohms in Bridge-Mono mode
Voltage Gain to 1-kHz, 8-ohm rated output,
CE 1000:
30.5-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.34-volt sensitivity.
CE 2000:
32.1-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.83-volt sensitivity.
Required AC Mains: 50/60 Hz (North American units are 60 Hz only); 100, 120 and 230-240 VAC (+/-10%) units are available.
AC Line Current,
100 Volts: 11.4 A;
120 Volts: 9.5 A;
230-240 Volts: 5.0 A;
At Idle: All amps draw no more than 90 watts.
AC Line Connector: NEMA 5-15P (15 A).
Sep 07, 2012 | Crown CE2000 2-Channel Amplifier
I have a galaxy 73v that transmits on oe channel recieves on another
common problem bad solder joints in the vco circuit take it to a PROFESSIONAL
Aug 21, 2012 | Galaxy Radios DX-73V 40-Channels Base CB...
Broken Joemeek ThreeQ
hi the same is happening to my joe meek tree q it doesnt make any sound i tested all the resistances capasitors i changed the transistors also two potenciometers but the problem persist you can just open it and make sure that all the components are without ficical damage and firstly the integrated circuits if you can just change it.
Apr 16, 2012 | Joe Meek Joemeek ThreeQ Pro Channel Strip
My Peavey Mark 3 400 CHANNEL 1 does not put out sound. When you turn the pre gain it will cut in for a sec then out. Channel 2 is good. I checked the readings on the pre gain pot on channel 1 and 2 and...
Transfer Channel 2 speakers to Channel 1 to check if it does put out a sound. If it does, it means that your Channel 2 amplifier is defective. However, if it doesn't,
then your Channel 2 speaker is defective. So, have this checked to find out the result. Defective items needs replacement or be repaired. Send us your e-mail for the result so we can further extend our assistance.
Oct 13, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Mackie CR1604 has a consistent click at hi gain
Without hearing the noise or seeing it on a scope, I can't say for sure, but this type of noise can come from a number of sources. If there is a high signal level on one bus, you could be getting some cross-talk from that channel onto the channel with the higher gain setting. Try to track this down a bit by experimentation. For example, do you hear this with NO connections at all, but with the gain turned up on one channel?
Please try a few things to narrow this down a bit and I'll try to provide you with some options.
Thanks,
Dan
Jul 20, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Will not pick up FOX channel!
if you did get the channel you should be able to add in a digital amp (25db gain) and pull that channel back in
Jul 10, 2009 | Olevia LT32HVM 32 in. LCD Television
My amp
4 CHANNEL-1100w MAX
HIGH ENDURANCE SLIM AMPLIFIER
4 CHANNEL [2 OHM] 110W x 4
4 CHANNEL [4 OHM] 80W x 4
2 CHANNEL MONO [4 OHM] 220W x 2
2 OHM LOAD CAPACITY
VARIABLE LOW [40-250Hz] PASS FILTER
VARIABLE HIGH [40-250Hz] PASS FILTER
BASS BOOST
RCA PRE-AMP LINE OUT
SPEAKER LEVEL INPUT
http://www.bcae1.com/repairbasicsforbcae1/repairbasics.htm
This is a really good site to learn about repairing amps and anything else you want to know about car audio. Are you wanting to replace the board or looking for someone to repair your amp.?
Apr 18, 2008 | Audiofonics ADF-242 Car Audio Amplifier
Sub+amp configuration
With a single 4-ohm subwoofer, usually the best choice is a 2-channel amp that can be bridged to a single channel. In your case, the sub is rated for 1000 watts. Not many amps are rated for that kind of continuous power into a 4-ohm load. Kicker doesn't list a minimum power rating, which isn't unusual in subwoofer specs. Depending on your budget, I'd look for an amp rated for 300-500 watts minimum; the higher, the better, up to 1000 watts. Most amps will have several power ratings, based on the load impedance and number of channels driven. A typical 2-channel amp might be rated like this: 150 watts x 2 channels at 4 ohms 300 watts x 2 channels at 2 ohms 500 watts x 1 channel at 4 ohms. The power rating you'll want to look at will be the 1-channel, 4-ohm rating. You can look at mono amps, too, but in the power ranges you're looking for, a 2-channel amp will probably give you the best value. However, if you can find a mono amp with a high enough 4-ohm power rating, it would run cooler and might last longer than a 2-channel amp with comparable power. When looking at mono amps, you'll find their highest power output will be at 2 ohms or 1 ohm; make sure you're checking the 4-ohm rating when making comparisons. Some amplifiers that might work well for you: Kicker SX900.2 Kicker ZX850.2 Alpine PDX-1.1000 Rockford T600-2 Hifonics ZXi 1006 Premier PRS-D2100T Power Acoustik OV2-2200
Jul 05, 2007 | Kicker C12-4 Car Subwoofer
Speaker outputs blown on 4 channel amp
the outputs should be replaced in pairs, there are 2 to 4 pairs, but you sould only need 1 pair replaced. these transistors typically range between 10 to 30 cdn each + labour, look for 1 to 1.5h to replace & test the unit after repair. check your local repair shop for their rates. good luck
Nov 05, 2006 | Kenwood KAC-728S Car Audio Amplifier
Ecler NUO5 5-Ch Mixer Logo
Top Ecler Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Ecler Audio Player and Recorder Expert? Answer questions, earn points and help others
