Question about Dell Dimension Computers & Internet
Dell error code 4400:011B
My Dell dimension e521 keeps crashing. Dell confidence test of HD presents errors of 4400 011B, medium error (0-0000)in three message blocks so far (25% completed). I also get messages of Device Initialization Failure 4600:0009. SmBios structure 52 has illegal length. OS: Win 7 Home Premium. The computer runs for a short while then goes to a black screen that asks me to boot from my external DVD, which then runs diagnostics. I am trying to determine whether to replace the hard drive, reinstall the OS or replace the computer. Thanks for any advice or wisdom.
    Sergeant:
    Champion:
  • 266 Answers
..have you used the System Restore to go back a few weeks or months? This will clear up everything. There has to be a restore point somewhere in the c: drive
Posted on Mar 21, 2014
Cytherian
  • 124 Answers
SOURCE: Dell GX270 Maxtor 7Y250M0
If you are getting bad block reports on your hard drive, it means that your hard drive media has suffered some degradation. It could very well be that some system files are being affected by this, thus continually triggering the problem. You may not like the suggestion I have, but it looks to me like the most solid solution (saving you hours and hours of troubleshooting).
Backup all files from your hard drive, save all of your browser shortcuts to backup files, then perform another Windows XP installation with a low level format of the hard drive. I know a PC specialist with many years of experience that says hard drives develop faulty areas over time and that every 5 years or so, it's just best to back up data from the hard drive and perform a low level format. This resets the device completely. If there are any faulty areas on the disk, they are skipped over--to the operating system, the drive will be perfectly fine.
This is not a guaranteed solution, but it sounds to me like it will eliminate a lot of possible culprits for you. Good luck.
Posted on Dec 30, 2008
  • 998 Answers
SOURCE: Computer will not boot.
Form the info you provided, you have a RAID (Redundant Array of Independent Disks) disk array. RAID 0 (striped disks) distributes data across several disks in a way that gives improved speed and full capacity, but all data on all disks will be lost if any one disk fails. Apparently Diagnostics has determined that “Drive 2” is defective. You will have to replace the defective hard drive and reload the Windows operating system.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 21, 2008
proton77
  • 1183 Answers
SOURCE: Dell dimension E310 crash
Hi ed,
There is a problem with the hardware of the system, In case you have another system to go online , go to the following link
http://tinyurl.com/6khcaf
This would help pin point the problem. What I think is the problem on your system is misaligned memory modules , try reseating them one by one and power on to check change in those front LEDs
Thanks
Mandeep
Posted on May 02, 2008
appman67
  • 33 Answers
SOURCE: c0000218 error code.cannot boot dell 8400 to troubleshoot problem
It sounds like you've had a fatal error - you can reboot the PC back to factory setting - this is called a hard reset - but before you do that - unplug you tower and clean it out (dust & dirt) - once you're done with that - restart you computer and press &hold down the "Ctrl" and "F11" button at the same time - this will let you reset the PC to the original factory configuration.
Posted on May 03, 2009
wipdhuls
  • 133 Answers
SOURCE: dell dimension L800CXE
Hello Wademyd,
It seems that the installation CD that you have is not a bootable CD.. must be old one.
Please down load the boot disk for windows from http://www.bootdisk.com or follow the Microsoft article link given below:
http://support.microsoft.com/?kbid=310994
Do not be intimidated by the article, although it looks big but there is very little that you need to do, rest of it is general instructions like where can you order a new CD from etc...
OR
Simple solution is to borrow Bootable Windows XP installation disk and install it using the serial Key that has been given to you.
Please let me know if that helps and please rate the solution if it helped you.. it will not cost you anything but will make a difference for me :)
All the best and kindly let me know in case you need any further assistance.
Regards,
Srinivas
Posted on Jun 11, 2009
My dell demension E521 is giving me a "alert system battery low" message. Any suggestions?
Check the batteries voltage and check to see if the battery is being supplied charge voltage when the computer is off. If both these are good then your low battery message is in error. No charge voltage would mean faulty charger and low battery voltage would mean faulty battery.
Dec 15, 2012 | Dell Dimension E521 PC Desktop
I have a Dell Dimension E521 desktop computer. When I try to turn it on the button just flashes green but it does not come on at all. What might be the cause and is it something major to fix?
Blinking Green power button indicates the computer is in a Windows® Standby power-saving state. Do any LED error codes display on the front? They are located next to the 2 USB ports on front.
Aug 10, 2011 | Dell Dimension E521 PC Desktop
Ran Dell diagnostics and SATA Disk Confidence test failed, Error Code 0F00 1332,Disk Block 30819848(etc)IRQ did not set in time. Dell Inspion 1545 laptop with SATA disk s/n 5VC2W51X
consider to replace your hard drive, your hard drive detected crash on your bios so you have to replace it. your hard drive can be use to external hard drive buy some external hard drive case 2,5"
you can re partition your hard drive and maybe if you are lucky the harddrive can be use again on your laptop
Jan 16, 2011 | Dell Inspiron 1150 Notebook
I have a Dell Dimension E521. I inserted a SD memory card into the SD card slot and nothing happens. The slot is not showing up under My Computer. I'm trying to transfer pictures from my computer to the SD...
check the device manager if it is showing there ? if with an error then u need drivers .. if it does not show up there then there is a problem with the memory card reader ..
Oct 24, 2010 | Dell Dimension E521 PC Desktop
I have a dimension E521 and when it starts up all it does is take me to a screen that says: A disk read error occurred and it's a black screen with spots ont the screen
Disk read error means that your hard disk broke down. You can first check if your BIOS setup for the hard disk is intact meaning it is properly configured, and the power is properly connected. if yes, no option but to replace hard disk.
Sep 13, 2010 | Dell Dimension E521 PC Desktop
I have a Dell Dimension 8400 P4 3.2G w/XP Media Center V2002. Just replace the HD due to a crash of orig HD. Cannot get the TV to work. Get the following error msg - Decoder Error - The video decoder has...
Sounds like the driver for the TV Tuner is not installed, or the video and audio drivers may not be installed properly.
Mine was always a bit wonky in XP, works like a charm in Vista or Windows 7 though
Jan 26, 2010 | Dell Dimension 8400 Desktop P4 630 3G 1GB...
I get a connect ok and then a connection terminated error message. [*] Connection established to 192.168.1.2, then an error message that gmail terminated the connection.
Somebody else is kicking you off of the network. Thats probably why you keep getting disconnected. Try moving your computer closer to the area or getting a new wireless card.
Nov 17, 2009 | Dell Dimension E521 PC Desktop
Boot, black screen, error code 3
2 short, 1 long
BIOS checksum error
1 long, 2 short
Memory test failure (bad memory during memory sizing)
Jul 30, 2009 | Dell Dimension E521 (D10E16) PC Desktop
NIC error/keyboard fuse failed
hear what u can do u can try resetting the bios or taking out the cmos battery for like 30 to 45 mins and the error u r getting will go away but if the NIC error keep accuring well there a problem with yr network card and for the hard drive when the pc is now booting up all dell normally comes with a testing device tool to get this testing device u can press F2 on when yr pc now going throught the post and just select hard drive testing...if it fines an error with the hard drive well u need to replace it....ok let me now if that work.
Dec 19, 2007 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
1,674 people viewed this question
Alun Cox
