Question about Kenmore Refrigerators
Ice Maker isn't making much ice
My Kenmore Elite 795.79773.900 isn't making much ice. It makes about one batch of six cubes per day, or not at all. I have tried the following: turning icemaker off/on, reinserting bin, ultra ice button, and changing cube size.
  • Laura Swope Zinter Mar 21, 2014
    I just now had the door open at the right time and got to witness the ice maker in action. I saw the rotation "comb" like thing go all the way around (no ice came out) and then I saw the water fill the tray. I am not sure why it's not working, but I did see movement and I did see water. Hope that helps eliminate two possibilities.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 50 Answers
Check the temp in your freezer it should be about -2 degrees if not it wont make much ice and you probably dont have enough air flow due to coils froze from not defrosting properly or the little fan motor in the freezer is not working. You will have to remove the inside back freexer panel to check either one. also if you have a water filter on your line check that.
Posted on Mar 24, 2014
  • 489 Answers
SOURCE: LG ICE MAKER
Be sure that the fill tube is getting into the ice maker and that the ice maker is not blocked with ice.  If everything seems ok, you may have a leaking water valve which causes it to constantly drip water into the ice maker causing the block of ice.
Posted on Jun 08, 2008
huuum
  • 750 Answers
SOURCE: ICE CUBE MAKER SMELLY ICE CUBES
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Posted on Oct 12, 2008
  • 8 Answers
SOURCE: Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
Posted on Nov 05, 2008
  • 36 Answers
SOURCE: I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Posted on Jul 24, 2009
  • 6 Answers
SOURCE: kenmore coldspot 106.556325 not making ice
could be your ice maker or your water valve
Posted on Aug 30, 2009
My ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
Jun 16, 2012 | Kenmore Side by Side Refrigerator
Model 501-78353 dispensing water but icemaker has not worked since it made one very large batch of ice and the lever rose - I guess to stop the icemaker
yes the lever needs tp be push lightly down and then the ice maker will be in on position again. then the ice maker will call for water then it should start making ice in a few hours.
Feb 13, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Not making ice fast enough
Good day,
Assuming the cubes it's making are the proper size, the speed the ice maker produces ice is determined by the temperature in the freezer.
When the ice maker harvests a batch of ice, an electric heater heats up the whole ice maker.
There is a thermostat embedded in the ice maker. It must cool back down to approx. 12 degrees before making the next batch. The colder the freezer compartment, the faster the cycles.
If the cubes are too small then that is usually caused by a blockage in the water filter if your unit has one, or the water valve that feeds water to the ice maker is getting weak, or lastly the water supply to the machine has become partially restricted.
On extremely rare occasions the thermostat built into the ice maker goes out of calibration which can cause a delay in cycling and requires the ice maker to be replaced. But again, it is a very rare occurrence.
Oct 27, 2010 | Sub-Zero Bottom Freezer Refrigerator
I have a Kenmore Elite 59969 and no ice
six weeks old / prob still under factory warranty . but ck the tempts in freezer it must be 15 deg of colder to work . so reset the control for freezer to the highest setting then back one.. this should help .
Jul 03, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker is making a creeking noise
I went in and knocked all the ice out and it started to work just fine.
May 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hello margrek
Welcome,
company.
Huuum
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker stopped making ice
hi there,
sounds like the i/m is making ice. if you have ice in the bucket, it means that the only problem is the dispensor. if you have frost anywhere, the problem is with the actuator, which is the ice pladdle. you may have a broken spring or just the ice paddle need to be replaced.
Oct 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite refrigerator 795.775.62600
make sure the ice maker is turned on, push and hold the little round button on the front for 15 seconda and see if it starts up an cycles. Also check to make sure the fill tube isn't clogged to the ice maker and another thing to check is the water valve.
Sep 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Refrigerators Logo
184 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
