My heat won't come on.
I've tried everything. Checked wires, pushed buttons, flipped the circuit breaker, and my heat won't come on. And there's no pilot light.
  • 400 Answers
Newer furnaces do not have a pilot light. If yours does, you will have to relight it. Find the gas valve inside the furnace and follow the lighting directions. Generally, you turn the valve to the pilot position, press a button and hold it while you light the pilot. Hold it for about a minute and then release. If the pilot stays lit, then you can go ahead and set the thermostat to call for heat. If it does not stay lit, or the furnace still will not light, I think you need to call a repairmen or someone with knowledge of how to troubleshoot the problem.
Posted on Mar 21, 2014
Dishwasher heating element won't turn off
Hello niki4god - I recommend resetting the dishwasher by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn on the unit. An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset. In this case, your unit may possibly be experiencing a communication problem with the control board or a potential wiring failure.
Jun 20, 2013 | Frigidaire 24 in. FDB635RF Built-in...
My circuit breaker won't stay in the on position. when you try to flip it to the on position it automatically goes back to the off position
either the circuit breaker is faulty or there is a fault in the circuit, this is something that would need to be checked by a professional
Mar 12, 2012 | Electrical Supplies
Blinking light on Kenmore Pro 13873K dishwasher: won't run
May be the drain pump is jammed. Try to clean the area and after that try to reset the panel. Download the user manual and there must be the reset sequence.
Nov 18, 2017 | Kenmore 13873 Stainless Steel Built-in...
We have 2 breaker boxers for my house. 2 nights ago, a breaker got tripped, (too many air conditioners i'm guessing) and i flipped it back and all we well...almost. The power was lost upstairs and came...
Your main breaker may be problematic... GO to your master panel... the one with the meter, and reset everything, and on any sub panels reset everything.... Good Luck...
Jul 23, 2011 | Challenger Circuit Breaker
My fridgedaire window unit A/C and heat won't come on. I had replaced an outside light fixture a couple of weeks ago and had turned off the circuit breaker that affected this unit too. Now the unit...
Plug a light into the outlet used for the A/C, if the light does not come on when reset then the circuit breaker that provided the power to the outlet need to be reset or replaced.
May 22, 2011 | Frigidaire FAS257S2A WallWindow Air...
No heat
was the old heater bad? check your fuses and /or circuit breakers fuses will show a break in the glass part, circuit breakers flip to off and then back on. some times breakers dont flip to blown section. if all o.k. test the terminal block where wire connects to dryer see if a terminal is blown. if o.k. chreck thermostats especially fuseable link inside back panel most likely fuseable link will be no good. if everything checks out youmay want to buy a repair booklet or call a repairman as the problem is very technical. good luck
Jan 27, 2009 | Whirlpool Dryers
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
