Garden Logo
G
Glen Vaughan Posted on Mar 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Karcher gun leaking
The gun on my Karcher 520M leaks but only when the trigger is pressed, even after I replaced the o ring (PINK IN COLOUR!) on the metal part of the hose that enters the gun. I have taken off the four screws that hold the gun together but still cannot open up the gun to see what the problem is. First question is "how do I open up the gun to see what the problem is? Secondly what is the problem likely to be? Many thanks.
Benny Freeman
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 165 Answers
  • Posted on Apr 21, 2014
Benny Freeman
Expert
Level 2:
Cheetah:
Answers
165
Questions
0
Helped
77941
Points
302
The gun needs replacing, non servicable, interchangable with many brands
5 Related Answers
Anonymous
  • 46 Answers
  • Posted on May 25, 2009
SOURCE: karcher 520m oil leak
small engine shop should be able to obtain the proper gasket for you.....oil 20 weight fill untill you can see it at the bottom of the threads at the whole you pour it into!
Anonymous
  • 174 Answers
  • Posted on Jun 11, 2009
SOURCE: Karcher B302 gun leaking = taken gun apart but I
jeane_m I can e-mail you a diagram. Can you e-mail me? [email protected]
Anonymous
  • 174 Answers
  • Posted on Aug 03, 2009
SOURCE: trigger gun
It sounds like you left out the spring in the hose.
There are about 10 different models of K330 with several types of guns. Go here and search until you find the correct gun so you can see the diagram. I think it will be hard to buy a replacement spring, though.
Anonymous
  • 760 Answers
  • Posted on Jul 29, 2010
SOURCE: Karcher K2.900M spray gun leaks. Not sure which
www.pressure-washer-parts.com has many parts available. There are complete guns, and gun repair parts listed here.
Anonymous
  • 100 Answers
  • Posted on Nov 09, 2010
SOURCE: Karcher Model K 2.40, water is leaking from the
You are going to have to purchase a new trigger gun, they don't offer any parts for replacement on the inside of this trigger gun. See this link to purchase a new one.
Have a Karcher kb4040 that continues to run constantly even when the trigger isnt pressed. Also water flows out of the detergant hose when im not pressing the trigger. Pressure seems down slighlty, not...
This is two things. One is the back flow check valve to the soap line is leaking. The other is the pressure switch on the output side of the pump.
Oct 13, 2012 • Garden
1helpful
Water leaking from spray gun
It depends on were the water is leaking from on the gun. If the water is leaking from were the high pressure hose goes into the gun it could be that on oring as been damaged. If the water is coming from the trigger you may need a new trigger gun.
If you tell me your model number (1.xxx-xxx.0) i can tell you the part number that you will need to give to your Karcher dealer/supplier to replace it.
1helpful
I have Karcher 520m and when you press the trigger you can hear what sounds like a relay engaging but there is no water pressure, then it will fire up and work, but next time you press the trigger the...
The issue you are having is with the unloader valve in the pump. Now with the 520m it is a little bit harder to repair than with more gasoline powered pressure washers but it can still be done. It would be easier if I could just send you a email of the breakdown on the machine. Send me a email to [email protected] with the discription of the problem you are having.
Karcher Model K 2.40, water is leaking from the gun at yellow trigger.
Karcher 1650 leaking water from trigger
i believe the spring is the actual trigger spring that pushes the trigger switch back in place and the water leaking out is probably a seal issue
Leaking water
The o-ring and the plastic insert is broken. They may not have a part replacement, may have to get a new gun. Take the gun apart and you'll see the problem.
Karcher 520m oil leak
6helpful
Karcher 520M wont operate at high pressure
The solution is very simple. All you have to do is change the spill valve.
This because the spill valve is not worth servicing. The actual problem is that the spill valve is leaking from its bottom-part seating. When you close the gun, the spill valve goes down, opens from the underside, and switches the electricity off. When you press the gun, the spill valve returns to normal, and if the underside does not close, you have low presure, because the water keeps circulating.
Regards,
MG. (Karcher service engineer).
Top Garden Experts
Jay Finke
Jay Finke
john h
