Question about SS Decals Everything I need to know about life Helmet Sticker
Vw cabrio 2.0 wont start replaced fuel pump .The fuel pump wont kick on in case its in the door nt kick on in case you have the key in it
Help
  • 2,509 Answers
Please post this in the correct category
Posted on May 15, 2014
95 vw cabrio wont start replaced fuel pump it only kicks on when key is in the door
check fuel relay under hood fuse box and iside fuse box might have blown/make sure pump relay is connected to fuel pump connection..check all electrical connections
Mar 21, 2014 | Volkswagen Vw Cabrio 1995-2001 Radio...
My 96 vw jetta wont start, where are all the relays located in the car?
under dash on drivers side remove kick plate above pedal should be right next to fuse panel if its like my vw cabrio 2.0
Dec 05, 2012 | Cars & Trucks
1999 volkswagen cabrio, wont start on its own, replaced the fuel pump, replaced in jectors, it WILL start when kicked off with starting fluid...but wont stay running...
I think you should open you exhaust in front of your catylitic converter. Pull the O2 sensor or just take the pipe off.
Jul 11, 2012 | 1999 Volkswagen Cabrio
2001 VW Cabrio engine sputters and kicks and feels like it loses so much power gong up a hill. Thanks for any help! Russell
Hi!!
Perform a tune up on the vehicle. If no improvement is noticed, check fuel pump pressure, Your VW is about due for a new fuel pump.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 02, 2010 | 2001 Volkswagen Cabrio
2000 VW Cabrio Car just stops running while driving and Wont start back up . I have Changed the Coil what else could it be
Mas air flow sensor went on my cabrio, pretty easy to fix, when it went my car would lose power sputter then die out. also could be spark plugs fuel pump, fuel pessure regulator,
Jun 20, 2010 | 2002 Volkswagen Cabrio
Vw golf 1996 cabrio 2.L ran out of petrol, i put 10 litres in and now it wont start
there most likely isn't enough fuel for the pump to pick up. Once a fuel tank runs dry it takes more fuel than usual to get the pump to send the fuel to the engine. Try a little more fuel, and if that doesn't work, let me know :D
Apr 22, 2010 | 1996 Volkswagen Golf
1998 VW cabrio doesn't start. acts like it is not getting gas.
I wouldnt recommend someone messing with fuel lines, especially on a 2.0L 8v mk3 VW, without knowing exactly what theyre doing.
Make sure it has at least 1/3 tank of fuel. When you turn the key to the acc position, do you her a soft whirring for 1 to 3 seconds?
If so, that is your fuel pump pre loading your injectors. If you do no hear it, than it is possible its your fuel pump.
With someone helping, turn the ignition over, and have someone lightly tap the fuel pump under neath the car. It is located by the rear passenger wheel.
If you cant hear the fuel pump when key is first put in the ACC position, but the car stutters and turns over while the pump is being tapped, its your pump.
Your best bet would be to take it to a certified vw mechanic, and have them do an inspection with a tuneup including a new fuel filter
Apr 07, 2010 | 1998 Volkswagen Cabrio
Fuel filter for 96 vw cabrio
Usually on the drivers side underneath the vehicle just in between the drivers door and the rear passengers door.Hope this helps.
Feb 14, 2010 | 1996 Volkswagen Cabrio
Im have a prob with getting my 1989 cabrio to start. It just quit on me on day. I changed the fuel pump, but still no luck. It turns over, just wont start.....need help!!
First, turn on the key, just to the run position.
try everything that should normally only work with the key on, headlights, turnsignals, horn etc.
the first three generations of vw had somewhat weak ignition switches, especially if the owner had a tonne of keys, keychains, teddy bears and **** dangling off their key ring.
if these thing do not work with the key in the on position, then you need an ignition switch.
if they do work you need to investigate further to find out if you have fuel delivery and\or correct fuel pressure and if you have spark
Oct 09, 2009 | 1989 Volkswagen Cabriolet
Vehicle lost fire
the security system doesn't disable spark, it works by not letting the fuel pump run or not allowing the starter to work, but never does it affect spark or fire as you call it.
Jun 16, 2009 | Directed Dei Valet 561r Remote...
SS Decals Everything I need to know about life Helmet Sticker Logo
46 people viewed this question
Top SS Decals Cooking Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a SS Decals Cooking Expert? Answer questions, earn points and help others
