I need a manual for a 1989 brock wood furnace #3624
I can't find the manual on line
I need a manual for a Woods 59018 programmable timer
Try Googling (woods)(59018)(manual) without parens.
Jul 01, 2017 | Woods Hardware & Accessories
Tip
Outdoor Wood Stove Hot Air or Hot Water
You're getting a new wood stove and you have many decisions to make. Other than brand, you need to decide whether you will use hot air or hot water to get the heat from the wood stove to the living space.
If you have a hot water heating system already installed then you obviously need to have a water stove. If you are thinking about what to install in a new home or already have hot air then you need to consider what will be the best option for you.
Now if you are installing a new system then you want to go hot water. That is by far the best way of heating and will be the best way to heat using an outdoor wood stove. Hot water heating is one of the best ways to get great heat transfer from the fire to the water to the air.
If you have hot air heat and want to heat with wood then you can install a wood hot air furnace, and set it beside your existing furnace. The ductwork will have to be reworked to get the heat from the wood furnace to the existing ductwork. Or you can install a coil into the ductwork on the supply side of the furnace, for the water to run through from a hot water wood burner. This is probably the best way to heat if you have a hot air furnace. Installing the hot water coil is a very simple process and the piping is fairly easy to hookup.
Hot air wood furnaces are almost always a inside the structure appliance, which means that you have the mess of the wood and the ashes inside. This dust and dirt mess is something that is much better kept outside where it can be cleaned up much easier.
Bottom line here is that you want to use a hot water wood burning stove if you can. You will be much happier with the heat that you get from burning wood.
on Dec 08, 2009 | Heating & Cooling
Got induction fan for Volgelzang wood furnace and no instuctions
I don't have one and cant seem to locate one online. You will need to go to a dealer or call them again.
Mar 23, 2014 | Vogelzang Norseman Warm Air Add-On...
Not enough heat coming from my Norseman furnace
I suspect the heat exchanger is caked with soot. The type of wood makes a very big difference in keeping them clean. The top cover is removable to access and clean it. No pallet or treated wood to keep it clean. Don't remove any screws you don't have to.
Dec 12, 2013 | Us Stove Company Vogelzang Norseman Add-On...
I have a Johnson aire ease ultra 90 gas furnance. I also have a outdoor wood furnance that has its own thermostat. On the original thermostat I turn the blower in the on position. I then set the outdoor...
I would first eliminate one furnace from the equation, the exterior wood furnace... turn its tstat down. Will the gas furnace then operate normally? Can you run the blower manually, as in summer mode? Make sure your filters are clean also... that can sometimes overload the blower.
Apr 12, 2017 | Heating & Cooling
Powrmatic Wood/Electric Furnace Manual Model # EW18-18 serial # 8503-1331
I need a wiring diagram for a powrmatic ew-30 wood electric furnace.
Jan 24, 2011 | Heating & Cooling
I need instructions on how to use my outdoor timer for the model59733 the other number is 23uld/3ao
59733 appears to be Woods timer number, but Coleman Cable CCI does not have 59733 manual.
Internet search turns up no Woods 59733 number.
There is a Woods 59730 outdoor timer stake, but I can't find manual for 59730 either.
http://www.acehardware.com/product/index.jsp?productId=4433644&CAWELAID=604875525
I do not have 59733 timer photo or manual.
But some Woods timers go by more than 1 number.
Check if your timer appears on following page:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Woods also has promotional line of timers sold in retail stores, and many of these timers carry Woods name but nobody has on-line information.
If I find manual or more information I will post on this thread.
Nov 29, 2010 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
Have a 1998 wild travel trailer and need to
Hello. I can help you. Your gas furnace only needed a small amount of electrical power to operate. The electric heater on the other hand will need a lot more power and most likely will need 220 volts as opposed to 110 volts for the gas furnace. Therefore, a new line to feed your electric heater, sized appropriately will have to be run from the electrical panel to the electric heater. I recommend that you have a pro do this wiring job for you as there is no room for error. Good luck with it.
Nov 01, 2009 | Electrical Supplies
Pilot on water heater is going out when furnace turns on!!!!
contact the furnace company and let them solve your problem free of charge
Dec 12, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
