Question about Royal Procision 7910 Carpet Extractor
Royal carpet extractor not picking up water well
It used to pick up the water great until i had to change the front piece because it cracked. now it only picks up water from the center and leaves the carpet really wet. I've had it to the dealer and he can't see to figure it out.
  • Royal Master
  • 1,534 Answers
Try to follow the suction from the machine through the dirty water tank to the front floor suction piece. Make sure the dirty water tank is seated properly. Make sure there are no suction leaks any where.
Posted on Mar 26, 2014
Testimonial: "Thank you! I will see what I can try."
2 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: I have a Royal 7910
One person wrote this in a review:
Most home carpet extractors are very difficult to take apart for cleaning and maintenance. The Royal 7910 is the exception. No tools are needed to take the front housing off to clean out all the pet hair.
I'm thinking that there has to be some trick you're overlooking to get at the hair. I couldn't find any blogs about getting this machine apart, so I'm thinkig you might run it by a vacuum repair shop and just see if they can show you, since that's their specialty.
It might just be one little thing or trick.
Good luck, and hope this helps.
Posted on Sep 25, 2010
When the shampooer is moved forward to initially to spray the shampoo the plastic guard on the front drags the floor and keeps it from moving forward and shampooing. .
The one's I've used the sprayer is on the back of the suction (suction hood which is kind of clear plastic), you watch that clear part to see if it is picking up dirty water. Recall it's easier to pull it and if caught just push down on handles and that raises front of machine to clear carpet snag. I would walk backward as it sprayed and then picked up the water with dirt. If different machine you could spray moving backward, go back to same starting point go again and don't spray but just hold it near carpet so it picks up the water.
Jun 03, 2016 | Bissell ProHeat Pet Upright Deep Cleaner,...
Water from clean water tank is getting into soap container ???????
There is an electric solenoid that may be stuck open allowing the water to flow into the soap container.
Jan 24, 2015 | Royal Procision 7910 Carpet Extractor
It does not pick up the water after cleaning solution is applied
The most common reason for lack of pick up on the F5000 series is that the lid is not fully seated on the dirty water tank. Be sure to hook the two tabs on the front of the lid, and then snap the rear latch into place. Another reason is that the duct on the front of the dirty water tank is missing. The duct may have been removed to install the hose, and was not put back in place. It is a square plastic piece, about the size of a slice of sandwich bread, which slides into the front of the tank. A far less common reason for no pick-up is that the seal that the tank sits on has fallen off the motor cover suction tube. You will see a round tube on the bottom of the dirty water tank. This sits on top of a large rubber seal on the motor cover when the tank is in place. Be sure the seal has not fallen down into the hood.
Aug 16, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Hoover SpinVac SpinScrub machine and have used it seven times. The last time I used the machine to clean my carpets, it would not **** up the dirty water. I clean it out each time I use it, but...
The most common reason for lack of pick-up is that the lid is not fully seated on the dirty water tank. Be sure to hook it in front before latching it in the rear. Another common issue is that the duct is missing from the front of the lower tank. The duct is removed to install the attachment hose, and must be put back in place before trying to clean carpeting. It is a square plastic piece - about the size of a slice of bread - which slides in and out of the dirty water tank.
Feb 21, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
Changed hose on carpet cleaner and it wont pick up the water
If you are unable to pick up water from the carpet after using the hose attachment, is is usually due to one of two reasons.
1 - The duct on the front of the dirty water tank has not been put back in place after using the hose. It is a square plastic piece about the size of a slice of sandwich bread.
2 - The lid is not properly seated on the tank. Be sure to hook the two tabs on the front edge in place before hooking the latch at the rear. This also applies when using the hose.
Feb 19, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
I have a very old kirby generation 3 unit that converst to a carpet shampooer. I was attemtping to shampoo the carpets but it does not seem to be picking any of the water back up out of the carpet. What...
make sure the belt on the carpet shampoo aggitator is good, (could be stretched or broken) recommend replacing that belt. also make sure your fan in the front of the machine doesnt have any chips or cracks around the center. (this will cause lower suction) a new belt should cure the problem for you.
Jan 06, 2010 | Vacuums
My bissel vacume was not picking up the dirt on the carpet. So I found that the hose was clogged. I unclogged it but the vacume still is not picking up the dirt. I also changed the filters.
I found out that if you remove the front filter holder, tip vacuum back and look down inside. Sometimes there is hair caught back in there and you won't get suction. I had to use something long, knife, very long type tweezers, to pull all the hair out. Worked great after that. About half way through vacuuming I will stop and remove the foam rubber filter and clean it. Oh yea, you will have to use a flashlight to look down inside to see all the hair caught behind the foam rubber filter cup.
Dec 14, 2009 | Bissell 6594 PowerForce Bagless Upright...
When I move my bottom lever from Floor to Carpet
I cannot express enough you need to clean your dyson as great as it is its still a vaccum. look underneath at roller, clean out tube wash filter and check to see if vaccum ate something which is stuck inside. I have had mine for 4years and still picks up after 2goldens and kids.
Oct 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Where can i buy a royal procision 7910 carpet extractor tank
just look on craigslist ebay or a local vac shop.
Jun 24, 2009 | Vacuums
No suction when carpet cleaning. Also won't stand upright
Its possible that it may be blocked in the foot of the vaccum. try going through your instruction manual to locate details on how to disassemble the suction brush and connecting ducts. If you dont have one then use this link to download it. http://ubermanuals.com/node/1870
Let me know how you got on
Cheers
Jun 10, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Royal Procision 7910 Carpet Extractor Logo
751 people viewed this question
Top Royal Vacuums Experts
Electroboy
Electroboy
Are you a Royal Vacuum Expert? Answer questions, earn points and help others
