Question about Vizio VF550M 55 in. LCD HDTV
I have a vizio XVT553SV. When I turn on the tv, the screen flickers with different colors. The picture gets a fuzz and freezes. After it freezes, it then shuts off and the vizio name flashes for about
Flickering and colors on screen. Screen freezes for about a minute then tv shuts off. The vizio name flashes for about 2 minutes then the tv turns on and works fine. This happens everytime I use it!!! Please help me.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Vizio Expert
  • 158 Answers
Try resetting your tv back to factory mode. Go to menu, system information, and resetting back to factory default. Parental code is 0000.
Posted on Aug 25, 2015
    New Friend:
More than likely if its image issue its a defective T-Con board.
Posted on May 04, 2015
    Habit-Forming:
  • 84 Answers
Does the vizio name flash with a repeating pattern? Some tv's will blink the power light to indicate which part is failing.
Posted on Mar 22, 2014
  • 4 Answers
SOURCE: Vizio m550nv led lcd tv. Problem began a couple
I had same problem. Unplug set for 10minutes then plug it in and let it go thru it's startup routine.
Posted on Jan 27, 2011
  • 67 Answers
SOURCE: 55'' vizio screen color is distorted
I have been pleased with the help from Vizio. Try techsupp@ vizio.com. Good luck. I believe they respond within 48hrs.
Posted on Jun 27, 2009
  • 11 Answers
SOURCE: Vizio SV470m with a pixelated screen after being on for 5 minutes
verify if it only happens on the antenna/cable input and if it works fine with dvd or other input, then it is a signal issue with the cable or antenna u r using and repair that problem and not the tv
Posted on Apr 18, 2010
budmrtn
  • 11361 Answers
SOURCE: My 42" Vizio LCD HDTV
It can be the unstable power supply due to bad DC filter caps, bad T-CON boards, main board.
I would inspect the power supply first for caps with domed tops.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Feb 18, 2011
  • 18 Answers
SOURCE: I've owned a Vizio VT420M for just over 13 months.
The flickering is most likely due to a faulty fluorescent backlight. Once the bulb heats up the flickering usually goes away. Some bulbs are easier to replace than others so I would contact your local TV repair shop.
Posted on Mar 01, 2011
My vizio tv is not powering on andi dont know what to check
I think this new tv have a chip cor the picture quality proba ly it burn ot die so if u warranty on the tv just call n they will fix it for free.
Oct 01, 2016 | Vizio XVT553SV 55 in. LCD TV
Why doesn't it turn on?
Could be power supply failure
Mar 24, 2016 | Vizio XVT553SV 55 in. LCD TV
Vizio downloads firmware every time it is turned on
Firmware corrupted. A reinstallation is necessary. Contact any service technician.
Mar 04, 2017 | Vizio XVT553SV 55 in. LCD TV
Vizio xvt553sv no picture and will shut off
Good evening
Since unplugging will not work, take the remote click on SETUP and go through general as well as picture. See if you cannot make it better.
Good luck
kolbrun
Jul 10, 2012 | Vizio XVT553SV 55 in. LCD TV
What is the code for my Direct TV remote for a Vizio XVT553SV
There is no specific code for different models, but the codes for Vizio TVs are:
10864, 10885, 11756, 10178
Try each of the above codes until you find the one that works or works best, i.e. controls most functions. White remotes RC16, RC23, and RC24 may not be programmable to some newer TV models.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 06, 2010 | Vizio XVT553SV 55 in. LCD TV
Flickering screen and lining-out on top inch at first
This sounds like tiling. are you using a cable box?
May 07, 2010 | Vizio GV42L 42 in. LCD Television
Vizio VF550M 55 in. LCD HDTV Logo
787 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
