Question about VeriFone new vx670 gprs wireless machine No smart card
Settings and Printer Issues
Hi. I have a vx670 and am wanting to know how to get to the settings to change the sleep timer and power saver mode? and also to turn off the tip oftion for my drive-thru customers? I am also only printing on the left side of the reciept. The right hand side is completly cut off not even fading. I have cycled power and reseated the battery and paper and have had no change.
    New Friend:
  • 3 Answers
Hi
try to access the sys. mode by pressing F2 + F4 using the password which it is set by your merchant or try the default password (1,alpha-key, alpha-key,668831 ) where u can find the wanted setting..
for the printer , i thinks the right side of the printer is broken or it may be so dusty . in case of printer damage it should be handled to any maintenance center.
thanks ...
Posted on Mar 24, 2014
Dell Inspiron 530s Desktop fan motor keeps running
It\'s NOT the fan. Check the power save settings on the computer ITSELF. Check your BIOS settings as well. Inspirons ALL do the same thing with waking up.
Nov 05, 2013 | Dell Inspiron 530s Desktop Computer
Tip
PC sleep mode problem?
Follow this instructions to disable sleep mode
In windows XP
1)Right-click the desktop, and select "Properties."
2)Click the "Screen Saver" tab, and click the "Power"
button at the bottom.
3)Change the option next to "System Standby" to
"Never" for either "Plugged in" or "Running on
batteries" or both if that is what you want. Click
"Apply," "Okay" and "Okay" once again to close the
Display Properties dialog.
In windows vista
1)Click the "Start" menu, and then click the Control
Panel.
2)Click "System and Maintenance," and then select
"Power Options."
3)Select "High Performance" to disable the overall sleep
mode. The monitor will still go into sleep mode unless
you click "Change Plan Settings" and disable all sleep
options.
In windows 7
1)Click "Start," and then select "Control Panel."
2)Double-click "Power Options."
3)Select "High Performance" under "Additional Plans,"
and then click "Change Plan Settings." Change all of the
options to say "Never."
on Dec 17, 2010 | Computers & Internet
How can I disable my monitor's sleep mode? I don't want the screen to go black, I want to be able to see the screen saver as it cycles. Thank you.
You can do this in the Power Savings options with Windows. For Windows 7, rght click on the display (anywhere with no icons or running programs) and choose Personalize. Click on Screen Saver in the lower right hand corner. Adjust the Wait time for the screen saver if desired and click Apply. Then click on Change Power Settings. This brings up the Control Panel > Hardware and Sound > Power Settings. Then click on Edit Power Settings for the active power plan. (For desktops it is usually the balanced power). Then change the setting for Turn off monitor to Never when plugged in. Also change the Sleep time for the computer to Never. You can do the same for when on battery but it will shorten the length of time that the computer will be able to run on the battery for laptops. Then Save Changes and close the windows.
For older versions of Windows, these advanced power settings are also available from the Screen Saver settings page but details may differ.
I hope this helps.
(for most monitors, as long as the computer is sending a signal the monitor will stay on)
Dec 23, 2010 | Dell 22" SP2208WFP Widescreen Flat Panel...
I am unable to access the internet from sleep mode Can only get on internet from shut down mode
Three possible causes of sleep mode. first, an extensive screensaver with password lock prevents display. A condition that is observable as a blankscreen also known as sleep mode. Second, a computer power saver settings that shutsdown during idleness. Third, An improper shut down of the computer would have caused a sleep mode to save the system data files.
Restoring the computer to regular functionalioty
First solving predictable sleep mode settings
1. A movement of mouse pointer across the screen should reestablish unprotected password modes
a. password protected sleep mode would display an promp message requiring key code soon after the mouse pointer has changed direction
sloving unpredictable sleep mode settings
1.A computer power saver, screen saver, or splash screen displays prevnting programs acess would require manually powering off the computer system.
a. A manual power back on of the system should restore to program functionality mode
important notes
1. contact expert technical assistance
Dec 20, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
Hp2338h monitor goes to sleep all the time. When turned on it displays for a couple of seconds, then message flashes that its going to sleep. Its a not graphics driver board or power saver setting,...
I've seen on a few Windows 7 machines has been the display turning off after only 15 minutes, even though I set the Turn off the Display option to Never. Weird!
You're probably reading this because you've tried changing the power plan settings to Never for everything and your monitor still turns off! This can be very frustrating and usually occurs with new installs of Windows 7, though I've seen it happen on older installs too.
In this article, I'll go through the different ways you can fix this problem. Note that if your computer is on, but the screen is showing No Signal or No Input, you should read my post on fixing blank or black screens. Now let's go through the possible solutions.
Power Options - Control Panel First, we need to make sure everything is set correctly in Power Options. Click on Start and type in power options or go to Control Panel (icon view) and then open Power Options from there.
Click on Start, then Control Panel and then Hardware and Sound, and then click on Power Options.
Click on the Change plan settings link that is next to the plan that is currently selected. In my case, the High Performance plan is selected, so I'll click on the link next to it.
First, make sure that Put the computer to sleep is set to Never. Next, change the Turn off the display setting to whatever value you want it 10,15 min etc.. You don't have to set it to Never if you don't want to. After this, click on the Change advanced power settings link.
Expand Hard disk and then expand Turn off hard disk after. Reduce the value till it gets to Never. Click OK and then click Save Changes on the Edit Plan Settings page.
Screen Saver - Control Panel The second setting you want to check is the screen saver. Go to Control Panel, click on Personalization, and then click on Screen Saver at the bottom right.
Make sure the setting is set to None. Sometimes if the screen saver is set to Blank and the wait time is 15 minutes, it'll look like your screen has turned off.
BIOS, Graphics Card, Monitor The two methods above are the most common reason why your display will turn off after a set amount of time, however, there can be other possible causes.
BIOS - On some computers, the BIOS can have power saving settings that determine how the computer sleeps. These are called sleep modes (S1, S2, S3, S4, and S5). On some computers, you'll see an option called Deep Sleep Control. You may need to disable this in order for the computer to wake up faster.
Graphics Card - If you have a high-end graphics card installed, make sure you have the latest driver and management software installed. If you go through the settings, you may find an option that puts your graphics card into lower power mode or something similar.
Monitor - Lastly, some monitors have power saving features themselves. Usually, the monitor is supposed to go into power saving mode if it doesn't detect any input (HDMI, VGA, DVI, etc), but sometimes it happens unexpectedly.
You'll have to press the buttons on the monitor to get access to the monitor settings. Those are about all the reasons I could think of for your display turning off when it shouldn't. If you have any other questions please post them here ,Best
We Are Here To Help !!
Oct 04, 2017 | HP 22" Widescreen Flat Panel TFT LCD HD...
Will not display
For clarification, may I know how long that your computer before it going to sleep mode?
You can change the settings on how the computer hibernate or gone to sleep mode by going to display properties >> click on the screen saver tab >> clcik on the Power button. There you can set the time on how long the computer will gone to sleep.
Let me know for any clarification.
Jul 08, 2010 | Dell E173FP 17" LCD Monitor
Can you change the energy saver adjustment
yep!
you can change it. actually it is on user's settings
it is located under general settings key operator mode.
just scroll down for energy saving
mostly the default value is sleep mode. after you press the sleep mode, the it will ask you for the sleep time you want. just press a number ( each number corresponds to number of minute)
that's it
Apr 02, 2010 | Panasonic Office Equipment & Supplies
Monitor goes into sleep mode as I'm working on it. How do I shut off/
How do you shut off sleep mode? I take it you're using Vista, as XP has "standby:" mode rather than sleep. You first right-click the desktop, then click "personalize." from there, click on "screen saver," and then "change power settings." from there, look on the left hand side of the window and choose the option you want to change. Probably, you'll want to "choose when to turn off the display." Hope this helps,
DH
Sep 22, 2009 | Dell E173FP 17" LCD Monitor
I want to watch a movie on my pc but it goes into sleep mode 20 minutes into the movie. How can i change the settings. It displays (auto input interjection) how can i change it?
Turn off your screensaver from your desktop settings, and modify your power control settings from within control panel. Alternately, you can make a conscious effort to move the mouse every 19-1/2 minutes. I think I would change the settings.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 30, 2008 | Dell Dimension 4600 PC Desktop
Sleep mode turn off simpletech 500gb pinifarina
Hi
Go to system Preferences and click on energy saver. Change the sleep setting to Never. This will stop the computer from sleeping. Also go into schedule and see it it is set to shut down or wake up at a given time.
Hope that helps.
Jul 14, 2008 | Computers & Internet
VeriFone new vx670 gprs wireless machine No smart card Logo
179 people viewed this question
Top VeriFone Computers & Internet Experts
lolthepcman
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
