Question about Toshiba Satellite A15-S129 Notebook
Toshiba Satellite A15-S129 PC Notebook will not turn on
I have the above notebook and the power light comes on yellow and blinks.  Nothing turns on when the power button is pushed.  I got the green power light to come on and it charged the battery but when I tried to turn the computer on the yellow blinking light took over again and even the green charging light went out when plugged in.  Nothing spins, or starts on the machine.  Just dead.  It died here and there, but now will not come on at all.  Is this the activity of a dead clock battery, or is there a fuse, or anything else that is fixable.
Re: Toshiba Satellite A15-S129 PC Notebook will not turn...
I have the same problem. What I have found with mine is that if I can get the battery to take just a little charge then I can get it up and running. Here is how I do it. Disconnect AC power leave the battery in and start the laptop. As soon as thing start to run I plug the AC back in and it works fine from there on. Now mine is flashing as well now and I have a dead battery and it will not restart. Something I have noticed thought is it appears that the yellow light is blinking a code. This is what I have come up with. I appears to be flashing 323 as the code or could be 2 shorts 1 long then 2 shorts and then 3 shorts.
Anyone know where to find info on these flashing codes.
Posted on Dec 14, 2007
Your plug in AC power supply may be defective. I had a very similar problem and checked the output at the round plug with a voltmeter and saw that it fluctuated. I found an inexpensive replacement on eBay (about $25 with shipping). Problem gone!
Posted on Jan 01, 2008
  • 689 Answers
SOURCE: Toshiba Satellite A15-S129 PC Notebook
Have you turn the wireless antenna switch on?
Posted on Mar 31, 2009
0 characters
3 Points
Toshiba a15-129 laptop--Will not turn on. Yellow
Your laptop is having a power problem. There was one Toshiba satellite pro that my friend had, it gave exactly the system fault as yours. And by the time we checked, it was a power problem.
The laptop had one IC that controls both the power and the entire board. If anything happens to that IC, it will affect the whole board.
I hope yours is different, because if it is the same, it will result you replacing the whole laptop mother board.
I would advice that you take your laptop your a qualified specialist, so that the fault will be made know and solution will follow.
I wish you the best.
Dec 18, 2009 | Toshiba Satellite A15-S129 Notebook
Hello, Can I install a 512MB DDR DIMM, N mem stick taken out of my Dell Desktop into a Toshiba Satellite A15, S129 laptop? Thanks, RD
You can try, without fear of having your laptop "blow-up".
Turn your laptop off.
Remove the battery.
Physically, does the RAM fit into the RAM slot? If not, the answer is 'no' -- most "desktop" RAM is much bigger than most "notebook" RAM.
If it fits, connect the AC power, and turn the computer on.
If it beeps wildly, or does not beep at all, the RAM is incompatible.
Disconnect the AC power.
Remove the RAM.
Re-insert the "old" RAM.
Re-insert the battery.
Reconnect the AC power.
Do a Google-search for "RAM upgrade Satellite A15" to find sellers that sell compatible RAM.
Oct 10, 2009 | Toshiba Satellite A15-S129 Notebook
DC power light is blinking orange on my Toshiba Satellite a15-s1292. Nothing else is working.
In general this indicates a problem with the power supply, this a very difficult error code to decipher unless you are familiar with hexadecimal code. I suggest you contact Toshiba Technical Support.
Sep 23, 2009 | Toshiba Satellite A15-S129 Notebook
Toshiba laptop does not run, just amber light blinking
Did the computer ever work? Have you checked that your memory is properly seated? Remove the bottom plate that reveals the memory modules, pop both loose then back in. Try to restart. Is the battery fully seated?
Sep 18, 2009 | Toshiba Satellite A15-S129 Notebook
Noisy fan
Ebay is a good source to get parts for Toshiba satellite. Look at Toshiba satellite for parts. Ton of them on regular basic.
Jun 04, 2009 | Toshiba Satellite A15-S129 Notebook
I have a Toshiba Satellite Laptop Model A15-S129 - The unit shut down and never would restart. I Checked the AC Adapter and it has no DC output voltage. I do have a 15VDC 2A Adapter connected to it now,...
hello..if you need to run @ safe the unit only up to 16v 2amp DC u need to try not try higher from 16v DC or Lower 15v DC..or you need buy a new..Thanks And Good Luck...^_^
May 17, 2009 | Toshiba Satellite A135-S4467 Notebook
Mar 31, 2009 | Toshiba Satellite A15-S129 Notebook
Toshiba Satellite A200 -AH9 Wont Turn On.
maybe you have power conection problem
your problem maybe on the circuit after the battery
so you must check your circuit
or you can contact your Laptop manufucturers
Jan 21, 2009 | Toshiba Satellite A15-S129 Notebook
Compaq presario v2000 notebook will not boot up blank sreen
If it is working fine with AC Adaptor, change your battery it need replacement.
Feb 09, 2008 | Toshiba Satellite A15-S129 Notebook
Toshiba Satellite A15-S129 Notebook Logo
505 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
