Washerdoesnotagitate the motor works fine but the drum will not agitate. The belt is not broken.
    Prodigy:
    An expert who has answered 500 questions.
  • Washing Mach... Expert
  • 517 Answers
The spider sounds like it is broken
Posted on Apr 02, 2014
My Frigidaire front loader washer drum will not turn or agitate but will fill water and drain water, what is the problem?
Hello acoach194 - If the washer is not agitating try the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this. If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, then it will need to be replaced. If it is loose, then it will need to be tightened. A professional will need to do so by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, once again call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Dec 17, 2012 | Frigidaire FTF530FS Front Load Washer
Drum wont turn but the moter does
Hello Deanna - This particular issue could be caused by a variety of reasons. I would suggest trying the following steps:
If the washer starts spinning, then that means the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
Sep 30, 2012 | Frigidaire Affinity ATF7000E Front Load...
My machine won't agitate or spin out ...the motor sounds like its working fine and there is no rubber burning smell..the outer drum looks like it is going to agitate and yet it just budges a little..thanks...
unless it is a belt drive unit your problem is with the transmission. If the motor turns and the drum doesn't then the transmission is "striped out" used parts could be a souliton but they are not easy to install
Apr 18, 2011 | Haier HLP21E Top Load Washer
Drum does not agitate water goes in and it just humms, no agitation or spin
The drive belt is broken or the motor's rotor is stuck. Open the door and rotate the drum manually. The drive belt is worn or broken if you can freely rotate the drum. The rotor is most probably stuck if you cannot turn the drum.
Visual check can be done by removing the back panel. Remove the screws holding it to the cabinet and pull it off. Replace the belt if it is worn or broken. Simply wrap it around the drive motor pulley and on one side of the drum pulley. Rotate the drum pulley in such a way that the belt completely wraps around it.
Try to free the rotor if it's stuck by lubricating it and forcibly turning it back and forth until it turns freely. To remove the motor, disconnect the motor wiring harness and ground wire from the terminals and remove the mounting bolt. Pull the motor out of the mounting slots. To reinstall or replace, simply slide it back into the mounting slots and secure it with the mounting bolt.
In some cases, the drum will not spin due to a broken drum pulley. Post it back if that is the case.
Feb 07, 2010 | Kenmore 42822 Front Load Washer
Won'i\t spin or agitate. was working fine-went
Hi..
if agitator movement is weak or moves in only one direction check the following:
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt(belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
If drum does not spin check this:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the drive belt (belt drive only)
  • Test the motor
Good luck !!!
Regards
PCmania
Jul 11, 2009 | KitchenAid Washing Machines
The agitator on my ingis liberator is no longer working
Hi..
Try to do this
Good luck !!!!
Regards
PCmania
Jul 08, 2009 | Washing Machines
Fills up and agitates, but doesn't spin cycle
The belt may have broken. The drum may be jammed by an item of clothing. The main motor may be faulty. There may be a broken wire to the motor.
May 03, 2009 | Kenmore Washing Machines
Kenmore:Noise; agitator not working; drum full of water...HELP!
Sounds like you have a broken motor coupler, check the tutorial at www.shop.washermd.com dave
Jan 12, 2009 | Kenmore 15944 Top Load Washer
Washer will not agitate, took belts off and it will only spin one way.
Only one direction seems fine. On some machines there is a solinoid connected to a lever that either disengages or engages the drum brake to keep the drum from rotating during agitation. Some units reverse the motor direction when agitating and spinning. (one direction for spin the opposite for agitation. Most generally when the motor works in only one direction, say it spins fine but not agitating the culpret is the control dial. There are several combinations of electrical connections that must all make to go from one cycle to the next. On some other models there is a plastic cog that is moved by the solinoid to make the change. Without other info such as make and model, I can't really be sure how to tell you to diagnose the problem..The main thing is one direction is probably right on the turn question.
Feb 03, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
