Question about Samsung Appliance WF405ATPAWR
Samsung water leaks out of the air vent
Water leaks from the air vent at the rear
Therinnaiguy
  • 1420 Answers
SOURCE: samsung air conditioner leaks and spits out water in house
Your condensate hose is blocked, clean it out.
Posted on Aug 19, 2008
  • 233 Answers
SOURCE: i have a samsung 1300 btu,theres a stinky stale
verify that the drain coming out of the back of the unit is clear, and make sure that the unit is pitched downhill to the outside, you can safely spray some bleach water in a spray bottle on the front of the indoor coil, that will ehlp with the smell after you get the drain cleaned,( you may also have some build up on the indoor coil. I would take the unit outside and thoroughly wash it.
Posted on Jul 12, 2009
SOURCE: Samsung rs255sl refrigerator leaks water at water
The problem is at the water lines behind the kick plate. Remove the 3 screws on the kick plate. You should see too water lines a red and a blue coupling. Push the water lines in rather forcefully towards each other. When looking at the couplings on your left hand side you should see a small gray lip. You need to slide those outwards and insert the red clips (that should have been left in the plastic bag with the allen key used to adjust the door height) in between the lip and the coupling as they are compression fittings. This should fix your problem right up!
Posted on Oct 24, 2010
hvac1960
  • 2133 Answers
SOURCE: I have a samsung biotech
Check your air filter & evaporator coil for dust blocked. Clean it.Even if less rpm of blower motor is also one of the problem. Replace the capacitor.
Posted on Dec 30, 2010
dr appliance
  • 266 Answers
SOURCE: Our Samsung RF265AB (bottom freezer) is leaking
have a water tank or line leak for water dispensor
Posted on Jan 27, 2011
LEAKING WATER IN SIDE THE REFRIGERATOR
I assume you are talking about ice and water in the fresh food compartment. It is most likely that the defrost drain is blocked in the freezer causing the water to drain through the air vents into the fresh food area. You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube. You may want to place a small tub in the top shelf to collect all the water that will pour through the vents and have some towels. it can get very wet.
Aug 17, 2014 | Refrigerators
Frigidaire side by side refrigerator is leaking water
I assume you are talking about water leaking from the freezer onto the floor. It is most likely that the defrost drain is blocked in the freezer causing the water to drain through the air vents. You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube.
Aug 15, 2014 | Frigidaire Refrigerators
Why does the air conditioner leak water from behind the unit. My air conditioner is placed in a wall and the back end of the conditioning unit sticks out inside the garage. I have ventilation by...
It is normal for an air conditioner to leak water out the back. This water is actually the humidity being taken out of your house. Being vented out in to the garage is always an issue with condensate water. I have seen some people take a funnel and run a hose outside the garage somewhere. Keep the vent closed. It will be harder to cool the house with the vent open because it lets outside air in to the house.
Jul 04, 2011 | Friedrich Heating & Cooling
I have a samsung biotech plus which is leaking water from the vents in the front. The unit was already in the home when we purchased. Cools beaut but the water is a pain. Can anyone suggest an answer...
Dec 30, 2010 | Samsung Heating & Cooling
When the hot water heater is running water leaks from the chimney. the pipe from the heater to the chimney is dry upon removal. about 3 gals. of water leaks from the chimney with two showers.
If I understand correctly, your Bock gas water heater vent is causing water to leak down into chimney.
This is a very serious concern
Water leaking from water heater flue indicates improper venting.
The hot air gasses from water heater combustion contain water vapor, but the gas should vent out of house before condensate forms on pipes.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#flue
The problem might be caused by a power vented furnace that pushes vent air from furnace down into flue pipe for water heater. As a result, the water heater doesn't vent properly.
There could also be a clog.
Light a match under water heater draft hood and see if smoke from match travels instantly upward.
There are two major concerns.
1) If vent is not working, it means that odorless CO gas is entering home instead of venting outdoors.
CO carbon monoxide is deadly poison.
http://en.wikipedia.org/wiki/CO_poisoning
You can buy CO detector after vent is repaired.
2) Water condensate will eventually rust away vent pipes because of acidic content of the combustion vapor. It can be expensive to replace pipes, and pipes with holes pose risk of CO poisoning.
My suggestion is call a qualified plumber ASAP and explain what you observe.
Plumber will want to inspect the vent pipes, and may want to extend water heater vent pipe up further inside chimney so furnace is not pushing air back into water heater vent.
Plumber may also find blockage somewhere in the vent stack or chimney.
Also post on a professional water heater forum like the Tank to double check anything the plumber says to you. These are the pros.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Dec 25, 2010 | RTO Bock Water Heaters 32E 32 gal 104,000...
At the top of the frig where the cold air blows into a small "vent" is it suppose to still have styrofoam the inside of the small "vent"? PC Water is leaking into frig and into veg bends.
most likely the drain is clogged..if it is, the water flows to the path of least resistance, hence, into the air vents and down under the crisper..remove rear freezer panel. the drain pan is located under evaporator. Defrost the drain pan if there is ice in it. there will be a small drain hole. this is where you need to see it gets open via hot water and all will be ok..make sure you hear or see it flowing into drain pan...Bruce Denton, master tech
Jun 19, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water Leaking around Ceiling Vent in Kitchen
it is likely a small leak i'd get a plumber money well spent you don't need the expense of a flood or search with a very brite flash light.Tom
Jun 18, 2009 | Heating & Cooling
Hard Top Vents
the vents are there to relieve pressure inside the cab when you close your doors. i suppose they could leak water if they're comming off since there is only a piece of rubber seperating the inside and outside
Apr 11, 2009 | 2000 Jeep Wrangler
Water leaking into KH laser Hatchback
It could be coming in through the rear door as the rubber might not be sealing properly the easiest way to find the leak is to remove your seats and carpet sit inside get someone to squirt the car round the doors and windscreen air vents.
Feb 25, 2009 | 2006 Ford Laser
Samsung Appliance WF405ATPAWR Logo
35 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
