Question about Husqvarna Designer I
Embroidery arm does not work
Embroidery arm makes a screech noise and hoop holder will not move. message on screen will not read correctly. Screen keeps saying to slide off hoop for positioning and continues to pop up.
    Scholar:
  • Husqvarna Expert
  • 104 Answers
Sounds like the embroidery arm belt stop is out of adjustment. Unless you're pretty handy, take the machine and arm to a professional. If you're going to tackle it yourself, get a service manual for the machine.
Posted on Apr 14, 2014
4 Suggested Answers
  • 192 Answers
SOURCE: cant get rid of message
I think that you need to have an authorized Husqvarna Viking repair center look at your machine.
The only thing that I can think of that you can do is place your left hand on the embroidery arm that moves left and right. Put your thumb into the opening where the hoop holder comes out and lift the cover slightly. I have seen the cover get pushed down too far so that the sensor inside is not able to move when the hoop is removed so the machine thinks it is still there. Look at the end of this opening in the arm that is closest to your stomach to see if it looks as if the cover is pushed down too far.
Beyond that, several things could be causing this problem, only one or two being serious. Most are simple.
Posted on Apr 09, 2009
  • 152 Answers
SOURCE: the embroidery arm is not working properly
You definitely need to take that in for service. The machine has a feature that lets it know which hoop is on the machine so is can't sew outside the hoop area, so if it does, you'll need a technician to make it right.
Posted on Oct 15, 2009
  • 201 Answers
SOURCE: i bought a new embroidery unit for my designer 1
Don't know for sure what is happening, but you should not put on a hoop until you are actually ready to embroider. The unit goes on while the machine is turned off; turn on the machine; it will make a noise; you should get a pop-up on your screen to Calibrate the unit. Touch this button, and the arm moves into position ready. Load your design and choose the correct hoop then put the hoop and project on the machine. Also be sure that your design will fit in the hoop selected.
Posted on Sep 09, 2010
While sawing the embroidery holder moves as well, looks like its not falling into its place correctly after embroidery, how can I fix it? Also I've self checked the machine but cant get the zi
YOUR MACHINE USES A PULSE MOTOR (SMALL MOTOR) THAT CAUSES THE NEEDLE ARM TO MOVE. IF THE MOTOR IS A PROBLEM THEN YOUR ZIGZAG STITCH AMONG OTHER STITCHES WON'T WORK. YOUR HOOP I'M NOT SURE BUT IT SOUNDS LIKE YOUR HOLDER ISN'T LOCKING WHEN YOU PUSH THE HOOPS ON. LOOK INSIDE THE HOLE WHERE YOU PUSH THE HOOP AND TOUCH ON EACH SIDE AND PLACE PRESSURE TO SEE IF THEY BOUNCE BACK. ANYWAY, YOU WILL PROBABLY NEED TO GO TO YOUR LOCAL REPAIR SHOP ON BOTH OF THESE PROBLEMS.
Nov 17, 2014 | Janome Sewing Machines
Embroidery unit
This can happen, click back to tools option check whether hoops selection is correct. If this is not the problem, off your machine then put on again. If message remain pull out the embroidery carriage & push in again. Hope it can work.
In jam situation, just exit from your embroidery option, fix the jam by moving the embroidery carriage, work on a different design and see if it work. Sometime a design may not work fully.
Sep 29, 2013 | Singer CE-100 Futura Computerized Sewing...
My Husqvarna designer SE embroidery unit keeps giving an error message "install hoop correctly". I've checked everything but can't get around the message. can anybody help ,?
You have probably got the machine set to use a different size hoop. Click on the hoop icon and change it to the size you are using. Hope this helps you.
Aug 04, 2013 | Husqvarna Sewing Machines
CONNECTING THE ARM AND IT MAKES A GRINDING SOUND WHEN TRYING TO DO ALIGNMENT
While the embroidery arm makes a certain amount of noise when it is initially indexing, I'm assuming from your description that the mechanism is making noise but ends up stalled (probably with the hoop holder in the rearmost position). It sounds like it's not engaging the end stop switch correctly. Take it in for adjustment. This is not something you want to tackle yourself. Beyond the switch adjustment it may additionally require recalibration to properly register the various hoop sizes.
Dec 17, 2012 | Husqvarna Designer I
Embroidery machine is making grinding noise and carriage doesn't move. Then, screen says malfuntion, turn machine off.
Just because the hoop holder has been moved during transportation. Shut down the machine, manually bring hoop holder in central position in both X and Y, it will restart.
Apr 20, 2012 | Brother PE770 Computerized Sewing Machine
In the middle of stitching a design - and when I came to a color change, the new color began stitching 1 to 2 inches below where it should. The screen showed the correct place, but the needle was way too...
If the design isn't too big, try rotating it in the hoop and stitch it sideways. If it works in that position, you probably should have the embroidery unit cleaned. I recommend the embroidery unit be serviced every 5 years. It may need it more often depending on your environment.
Dec 11, 2010 | Husqvarna Designer I
I bought a new embroidery unit for my designer 1 when I but it on it makes e terible noise and says to slide of hoop and clear position for i . embroidery position'But it won't go into embroidery...
Sep 01, 2010 | Husqvarna Designer I
The embroidery arm is not working properly. When i try to use the embroidery feature, the arm starts in the wrong area and the machine tries to put the needle through the embroidery hoop. The arm is also...
Oct 15, 2009 | Husqvarna Designer I
Wrong hoop display
If you haven't already done so, download the latest update for the Designer 1 and install it. 2.22 is the latest. Your current software version is in the lower right corner of the display when the machine is first turned on. It only shows for a short time so be ready when you turn it on.
If you have one of the last few versions, the embroidery unit will calibrate by moving the arm to the right and the hoop holder moves away from you, then back part way to the left and the holder will move back toward you and you will then hear a "grunting" sound as the holder moves slightly forward and back to finish verifying its position. If the arm fails to move from side to side or the holder doesn't move forward and back, the embroidery unit may not be fully connected to the machine so turn the machine off, slide the unit 2-3 inches to the left and firmly reconnect it and try again.
You can't bypass the "wrong hoop" display. We just have to convince the machine that you have the correct hoop installed. Let me know how it goes.
Jun 07, 2008 | Husqvarna Designer I
Husqvarna Des 1.. won't recognize hoops
The embroidery unit needs to be calibrated. Can only been done by a trained dealer. you can relax, it is not a major issue and shuold not cost you a arm and a leg. Ask the dealer to also calibrate your touch screen and download the working hours on your machine.
Regards
dupina
Dec 11, 2007 | Husqvarna Designer I
Sewing Machines Logo
123 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
