SOURCE: My recently installed SHE4AM Bosch dishwasher
you have to make sure the water temp going into the machine is correct. let the water run for about 2-3mins then start the machine.
SOURCE: 24 in. SHX99A15UC Stainless Steel Dishwasher: bosch dishwasher does not dry...
Check your heating element..
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
SOURCE: bosch she4am dishwasher noise
Just placing a fiberglass batt over the cabinet exterior will quiet it down considerably. Use some thin synthetic cord to tie it in place so that it doesn't crawl off from vibration. If still noisy, remove the door interior panel and check for any insulation there. If there is any appreciable gap at the sides or top, you may need to staple insulation around the interior of the cabinet opening. I'm surprised that they were that lax in noise suppression. Hope this helps!
SOURCE: The soap dispenser on our
We have this dishwasher and have had similar problems. In our case it's not the Bi-Metal strip that Daniel is talking about but the mechanism that actually causes the door to pop open gets clogged up with soap/hard water residue. You can pop the door off and then soak it to try and clean it off. Unfortunately I haven't found something that does a great job for this. Vinegar and CLR don't seem to be too effective.
Daniel
