Question about Bissell 12-Amp ProHeat 2X Upright Deep Cleaner 92002
The water will not spray when cleaning - Bissell 12-Amp ProHeat 2X Upright Deep Cleaner 92002
    Master:
  • 966 Answers
Debra, that is because the spray unit is blocked due to buildp of calcium etc. Dip it for afew minutes in vinegar or CLR and that will clean it. good luck!
Posted on Apr 18, 2014
Dishwashwer not cleaning dishes at all, though it runs through a complete cycle.
try removing spray spinner and clean out holes the spray heads get blocked and stop water flow, or you may be able to remove spray nozzles and clean out , i had this several times in the past also make sure the base drain filter is clean some times the small holes in the filter get smaller and smaller reducing water flow
hope this is of some help good luck
Aug 02, 2016 | Bosch SHE5AL06UC 24 in Builtin Dishwasher
How do l clean the dryer lent screen
HI,The best way to clean the dryer lint screen is physically very careful with your hand remove the lint on the screen and place the removed lint in the garbage.If you have a garden hose,set it to a spray and spray down the screen outside,if that is possible.Do not use heavy pressure on the spray setting as you do not want to spray the water to hard and rip the screen.Take a spray bottle with white vinegar and mix water and vinegar in the spray bottle.Spray down the screen with the water and vinegar mixture.This will help clean and sanitize the dryer lint screen.Then just let the screen dry outside in the sun.Now you have a clean and sanitized dryer lint screen.I hope this helps you.Carrie
Oct 14, 2014 | Dryers
Spray arms not working
Hi frustrated in Raleigh,
I understand that the spray arms are not moving or spraying water, even after you have cleaned the screens and arms. What might be happening is you are not getting enough water pressure to the dishwasher.
The hot water line to your dishwasher must provide water pressure between 20 and 120 psi.
Low water pressure may occur when laundry or showers are in operation.
Wait until water use is reduced before starting dishwasher.
If you are still noticing that the spray arms are not moving or spraying water, I would have a local Authorized Technician come out to see what exactly is going on with the spray arms of your dishwasher.
-Best Regards-
Jan 06, 2014 | Frigidaire FPHD2491KF Dishwasher
My Bosch SHX56BO6UC14 is not getting the dishes clean at all. It's making a grinding sound. It is pumping water & spraying water, but not getting anything clean. help?
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 09, 2011 | Bosch Dishwashers
Does not spray cleaner
It helps to always run hot water in the soap holding tank after you have cleaned the carpet to make sure the soap does not dry inside and clog. Make sure that the dirty tank water filter is clear of debris, I have noticed that if it is clogged it won't spray out solution. Another thing to try is, it usually will always spray out of handheld cleaning attatchment. steve
Jun 06, 2010 | Bissell 1699 ProHeat Clear View Upright...
Top level rack pots are not cleaned, spray head does not rotate but water coming out of sprayhead, no obstruting parts
Check and see whether it freely rotates, when turned manually. The spray arm rotates under water pressure from the pump inside the machine.
Check inlet water pressure and clean the strainer at the inlet hose end near th inlet to the machine. Check and clean the spray arm axle housing also
Apr 12, 2010 | Dishwashers
Not enough compression to spray thompson water
Maybe just plugged. If it has the nozzle that can be rotated 180 degrees, roll it and try to spray. Sometimes a bit of debris gets in there and stops it up. If no on the rotatable nozzle, take the tip off and try to push liquid back to the container, or a waste bucket, to clear the line. You also may need to clean the tip. One last item.....since you sprayed water.....if you chased the water with the TWS, you may have made an emulsion. If so, remove the spray gun, and turn on the pump, pumping into a waste container, until the emulsion is displaced. Clean the gun. I'd say that if it'll spray water, TWS would be even easier.
Regards, --W/D--
Aug 03, 2009 | Wagner Air Tools & Compressors
Will not clean dishes on the upper rack
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Jun 16, 2009 | KitchenAid KUDR01TJ Dishwasher
Bissell Proheat 9500 won't spray water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ukyr
Jun 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 12-Amp ProHeat 2X Upright Deep Cleaner 92002 Logo
135 people viewed this question
Top Bissell Heating & Cooling Experts
Lawrence Oravetz
Tom Chichester
Are you a Bissell Heating and Cooling Expert? Answer questions, earn points and help others
