Question about Clarion CCA329 CD Changer Replacement Cable
I need the equivalent replacements of rjh3044
1991 Nissan maxima burnt fuseable link
I recommend replacing fusible links with either a fuse of equivalent value (using a standard accessory fuse holder), or with a self-resetting breaker of equivalent value. If the replacement fuse or breaker also blow, you have a problem with the circuit that needs to be corrected (which will require basic troubleshooting).
Aug 12, 2014 | Cars & Trucks
Acer aspire 5315-2153 has a power problem caused by wrong adapter, the 3 ics on intel celeron board have got burn't. Can you send me the equivalence of the 8 legs Dip ic that i can buy in the market to...
The numbers on the IC's are what you need to use to order replacements. Generally, there are no equivalents available without knowing the numbers on the faulty IC's.
Dec 30, 2013 | Computers & Internet
I just replaced my fuel pump and now it sputters
You need to replace your pump with original one ( and same specs) or at least equivalent with original / existing one. Different model and specs may not working good.
So please check back your previous pump specs and compare with the one you just installed.
They should equivalent and better similar.
Regards
May 14, 2011 | Car Audio & Video
The oil sensor needs to be replaced where is it
  1. Remove the engine sight shield.
  2. Disconnect the oil pressure sensor electrical connector.
  3. Using J 41712 or equivalent, remove the oil pressure sensor.
    0996b43f802053c4.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Using J 41712 or equivalent, remove the oil pressure sensor-8.1L engines
To install:
  1. Apply sealant to the threads of the oil pressure sensor.
  2. Using J 41712 or equivalent, install the oil pressure sensor.
    1. Tighten the sensor to 22 ft. lbs. (30 Nm).
  3. Connect the oil pressure sensor electrical connector.
  4. Install the engine sight shield.
Nov 15, 2009 | 2001 Chevrolet Silverado 2500HD
What kind of battery (size) do i need for replacement
HI, there isn't a specific size here. The actual battery that is located under the hood is the correct type but, you will need to purchase the equivalent of what was shipped in this vehicle. any auto parts store will have an equivalent battery that will be compatible with this car.
All car batteries are the same, just different brand names.
Jul 08, 2009 | 2004 Volkswagen R32
Remove/replace shock absorber assembly 900s 1995 saab
  1. Slightly loosen hub center nut when all four wheels are on ground.
  2. Raise and support vehicle, then remove five wheel bolts and wheel.
  3. Remove hub center nut, then the wheel sensor,
  4. Press back brake piston using slip-joint pliers,
  5. Remove caliper from steering swivel member, then suspend in wheel housing with cable tie.
  6. Remove brake disc and back plate, then slightly loosen tie rod end nut.
  7. Press out tie rod end nut using puller tool or equivalent.
  8. Remove nut and tie rod end bolt, then the anti-roll bar to swinging arm nut.
  9. Remove outer ball joint nut.
  10. Press ball joint out of steering swivel member using puller tool or equivalent, installed on spring link.
  11. Remove nut and discard. This self-locking nut must not be reused.
  12. Remove three upper mounting nuts for MacPherson strut, then the strut.
  13. Clamp MacPherson strut in vice.
  14. Compress spring using spring compressor or equivalents.
  15. Hold piston rod and remove nut using MacPherson strut socket tool 89 96 662, or equivalent. This is a self-locking nut and must not be reused.
  16. Remove mounting and top spring seat, then the coil spring, gaiter and compression stop.
  17. Unscrew damper using wrench tool No. 89 96 670, or equivalent, then remove damper from strut.
  18. Reverse procedure to install, noting the following:
    1. Screw damper in place using wrench tool No. 89 96 670, or equivalent.
    2. Lower end of coil spring should abut against stop in bottom of spring cup.
    3. Position MacPherson strut on vehicle and install three retaining nuts on top mounting. Tighten nuts alternately, according to specifications.
    4. Always use new hub center nut with self-locking threads.
Jun 04, 2009 | 1995 Saab 900
What is the lcd equivalent for the hitachi
there are several equivalents to a 28" crt in lcd. But you will probably be offered a 26" or 29" as I believe that they don't actually make a 28" lcd.
May 08, 2009 | Televison & Video
Need equivalent IC
i made programmer for 89c51. in this use ic ds275. i want know what is the equivalent ic of ds275.
Aug 10, 2008 | LG F-185 CD Shelf System
Clarion CCA329 CD Changer Replacement Cable Logo
326 people viewed this question
Top Clarion Audio Players & Recorders Experts
John
John
xxxxxx xxx
Anthony Kelly
Anthony Kelly
Are you a Clarion Audio Player and Recorder Expert? Answer questions, earn points and help others
