Question about Battery Biz Computers & Internet
Hooked battery up backwards, now lights,horn,wipers,radio, heater blower, fog lights, rear defrost,cig lighter dont work. plus when you change wiper fuses the keep blowing?
Car starts though and is driveable
    Habit-Forming:
  • 157 Answers
Check all fuses.
Posted on Nov 09, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 68 Answers
Check your main fuse block under the hood. Chance are you have quite a few blown fuses. If not then you will probably be looking at an ECU issue
Posted on Mar 22, 2014
Y need book for fuse box
Fuses are listed here
* = maxi fuse
1*=50A I/P fuse panel
2*=40A blower motor relay
3*= 50A 4 wheel ABS module
4*=20a Main light switch-Instrument cluster
5*=50A Ignition switch, starter relay
6*=20A Transfer case relay
7*= NOT USED
8*=20A Auto Ride Control Switch/on off switch
9*=40A Auto Ride Control relay
10*=30A PCM power relay
mini fuses
1=10A A/C relay
2=20A Aux power point
3= not used
4=15A Fog lamps-Daytime lamps
5=10A Air Bag diagnostic monitor
6=10A Powertrain Control Module (PCM)
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump relay and RAP module
10= 15A Horn relay
11=15A Park Lamp relay-Main Light Switch
12=30A Main light switch--Multi Function switch
13=15A Heated O2 sensors, EGR Vacuum Regulator, EVR solenoid,Camshaft position (CMP) Sensor,
Cannister Vent Solenoid, A4LD Auto Transmission
14=30A Generator-Voltage regulator
Interior fuse panel (mini fuses)
1=7.5A Power mirror switch
2=7.5A Blower motor relay,PAD module,Air Bag diagnostic monitor
3=7.5A Trailer tow connector
4=10A Left headlamp
5=10A Data link connector (DLC)
6=7.5A Air bag diagnostic monitor, Blower motor relay, Passive deactivation Module (PAD)
7=7.5A Trailer Tow connector
8=10A Right headlamp, Daytime running lamps (DRL) module, Foglight relay
9=7.5A Stop Lamp switch
10= 7.5A Speed control-amplifier assembly,Brake pressure switch, Generic electronoc Module (GEM)
Shift lock actuator, Blend door actuator, Main light switch, RABS resistor, A/C heater assembly
Flasher
11= 7.5A Instrument cluster, Main light switch, RABS resistor
12= 10A Power window relay, Washer pump relay
13= 20A Stop lamp switch, Brake pressure switch
14= 20A Rear Anti Lock Brake system (RABS) module
**10A 4WABS module**
15=7.5A Instrument cluster
16= 30A Windshield wiper Motor, Wiper Hi-lo relay, wiper run/park relay
17=7.5A Cig lighter
18=15A Drivers unlock relay-All unlock relay
19=25A PCM power diode
20=7.5A RAP module GEM module, Radio
21=15A Flasher (hazard)
22=20A Aux power socket
23=15A Turn signals
24===not used
25= 7.5A GEM module, Instrument cluster
26= 10A Battery saver relay, Electronic Shift relay, Interior lamp relay
Power window relay,Electronic shift control module, transmission control
27=15A Switch,DRL, Backup lamp switch, DTR sensor,Instrument illumination dimming control module
Dome/map lamp, GEM,electronic shift,Interior lights,Glove box lamp and switch
28=7.5A GEM module-Radio
29= 15A Radio
30=15A Park lamps, trailer Tow relay
31===not used
32=10A rear blower
33=15A Headlamps, DRL module, Instrument cluster
34=7.5A Rear integrated control panel, CD
35=10A RABS test connector
36=7.5A CD, rear integrated control panel, memory seat,
i copied this off another post hope this helps
Oct 09, 2016 | 2003 Ford Explorer
Where is my ign fuse located on car
Below dash instrument panel, R16 ignition relay
98 Ford Contour SE Fuse Box Map
Fuse Panel Layout Diagram Parts: passenger side air bag, heater blower, interior lighting, heater blower motor, parking lamp, interior lighting, electric mirror, clock, wiper motor, ignition, reverse voltage protection, rear window defrost, engine management system, instrument panel illumination, radio, wiper motor, power windows, ABS module, backup lamp, brake lamp, door lock, main light, cigar lighter, electric seats,
link below should be the same as yours, press the helpful button
http://www.autofuseboxdiagram.com/1342-98-ford-contour-se-fuse-box-diagram
Jan 30, 2016 | Cars & Trucks
Battery hooked up backwards
check all fuses in the vehicle and under the hood and hook the battery up correctly also have the relays checked
Mar 21, 2014 | 2002 Kia Sedona
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
May 23, 2011 | 2005 Jeep Liberty
I lost my manual for 97 mountaneer fusebox diagram
1. pwr antenna 7.5 amp 2. high mount stop lamp 7.5amp 3. lights 15 amp 4. left headlight 10 amps 5. data link connector 10 amps 6. airbag, blower motor relay 7.5 amps 7. lamp dimmer 7.5 amps 8. RH headlight, daytime running lts, fogs 10amps 9. autolamps, memory seat 10amps 10. blend door ( heater), shift lock actuator, cruise control, brake press limit, console, integrated contol panel, rear blower relay 7.5amp 11. radio, dimmer relay, inst cluster, autolamps 2 7.5 amp 12. liftgate wiper washer, front washer relay 10amps 13. brake on off switch 15 amps 14. antilock brakes 10amps 15. airbag diagnostic 7.5 amps 16. wiper main 30amps 17. cig lighter 25 amps 18. heater-a/c eatc module 15 amps 19. radio noise cap, ign coil, PCM power diode 25 amps 20. radio, powr ant 7.5 amps 21. turn /hazards 15 amps 22. turn hazards 10 amps 23. rear wiper relay, 10 amps 24. anti theft 10 amps 25. cluster 7.5 amps 26. rear window defrost, overdrive trans, backup lamps 10 amps 27. interior lighting 10 amps 28. GEM, mem seat 2 , 7.5 amp 29. radio CD changer 10amps 30. not used 31. rear blower relay, RH heated mirror, 7.5 amp 32. heated rear window switch RH heated mirror 7.5 amp 33. DRL module, RH LH daytime running lamp 15 amp 34. power antenna module, remote chassis unit 7.5 35. not used 36. not used
Jan 07, 2010 | 1997 Mercury Mountaineer
Abs fuse
* = maxi fuse
7*= NOT USED
mini fuses
1=10A A/C relay
3= not used
7=30A 4WABS module
8=30A PCM relay
9=20A Fuel Pump2.gif relay and RAP module
10= 15A Horn relay
4=10A Left headlamp
Flasher
17=7.5A Cig lighter
23=15A Turn signals
24===not used
29= 15A Radio
31===not used
32=10A rear blower
36=7.5A CD, rear integrated control panel, memory seat, Message center Attached images fuse%20box001.jpg?imgmax=800 __________________
Oct 29, 2009 | 2003 Ford Explorer
I need a fuse box diagram for a 2003 Ford Explorer Sport
I believe that this is what you are looking for.....
Fuse and relay locations--2nd generation power distribution box Layout- I think this is a good sticky candidate--
* = maxi fuse
7*= NOT USED
mini fuses
1=10A A/C relay
3= not used
7=30A 4WABS module
8=30A PCM relay
10= 15A Horn relay
4=10A Left headlamp
Flasher
17=7.5A Cig lighter
23=15A Turn signals
24===not used
29= 15A Radio
31===not used
32=10A rear blower
Oct 10, 2009 | 2003 Ford Explorer Sport
FUSE BOX DETAILS
left to right...
1. empty
2. e flashers
3.horn, brake lights
4.clock, trunk light, inside light, radio
5. rad. cooling fan relay (AC only)
6. right side running lights
7. left side running lights
8. right high beam and indicator
9. left high beam and indicator
10. right low beam
11. left low beam
12. reverse,turn signal and inst panel
13. main and transfer fuel pumps, auxiliary air reg., ox sensor heater
14. license plate and glove box light
15. wipers
16. rear defogger
17. heater blower (no AC)
18. cig lighter
19. rad cooling fan (no AC)
20. Heater blower (AC)
21. rad cooling fan (AC only)
22. empty
23. Ox sensor, idle stabilizer,seat belt warning relay, (Digifant only, control unit, idle boost control, idle boost valve)
24. inst panel lights, heater control lights
25. reading lamps
26. empty
27. empty
28. empty
Hope this helps...;-)
Apr 17, 2009 | 1992 Volkswagen Fox
1989 Mercury Tracer Sta. Wgn.
your owner manaul has it. your fuse cover should have chart too.
here is 96 tracer. You also have main fuses under hood.
INTERIOR FUSE JUNCTION PANEL REFERENCE CHART Fuse Fuse Rating Color Protected Components (REAR WIPER) 10A Red Rear wiper and washer motors, heater and A/C relays, daytime running lamps control (Canada), climate control assembly panel illumination HAZARD 15A Blue Front and rear turn signal lamps, turn signal indicator lamp, indicator flasher ROOM 10A (1.9L)
15A (1.8L) Red
Blue Dome and map lamps, safety belt warning chime, ignition key illumination, luggage compartment lamp, vanity mirror lamp, radio chassis (memory), power door lock relay, shift interlock system, powertrain control module (PCM), radio amplifier (memory) ENGINE 15A Blue Fan control (FC) relays, PCM relay RADIO 15A Blue Radio chassis, radio amplifier, remote control mirror, instrument panel illumination (DOOR LOCK) 30A Light Green Power door lock actuators BELT 30A Light Green Passive restraint control module, passive restraint motors (POWER WINDOW) 30A Light Green Window regulator electric drives METER 15A Blue Instrument cluster, backup lamps, rear lamps, speed control system, shift interlock system, safety belt warning chime, passive restraint control module, hazard flasher, PCM (1.8L Canada) WIPER 20A Yellow Windshield wiper motor and windshield washer pump STOP 20A Yellow Stoplamp, horn (1.9L only), rear hi-mount lamp TAIL 15A Blue Parking lamps, cornering lamps, rear lamps, license lamps, compartment lamp, instrument panel illumination (SUN ROOF) 15A Blue Sliding roof panel motor ABS 10A Red Anti-lock brake system (ABS) (1.8L only) (DEFOG) 20A Yellow Rear window defroster HEATER 30A
circuit breaker — A/C blower motor HO2S
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 10A (1.9L)
20A (1.8L) Red
Yellow Heated oxygen sensor (HO2S) CIGAR
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 20A Yellow Cigar lighter knob and element CIGAR 20A Yellow Cigar lighter OBD II 10A Red Data link connector #2 BLOWER 30A Light Green Blower motor relay HORN 20A Yellow Horn (1.8L only)
Aug 10, 2008 | 1989 Mercury Tracer
Computers & Internet Logo
111 people viewed this question
Top Battery Biz Computers & Internet Experts
justwinwin
Lawrence Oravetz
Greg Baldwin
Are you a Battery Biz Computer and Internet Expert? Answer questions, earn points and help others
