Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
John Deere lawn tractor X304--performance problem
My 2-year old tractor has just started (a month after annual servicing) to run at a low RPM, that is most noticeable when I engege the blades (otherwise, the throttle seems to run pretty high w/o PTO engaged).
JD limited support suggests fuel (new gas, used a little stabilizer just in case), and fuel filter (looks fine..clean w/ no clogs visable), and looking at spark plug (which is OK).
Just now, I cleaned up loads of built up dirt/mud on the undercage (blade-path). The last time I used mower it buckled under heavy/tall grass, and now it is operating in this half-hearted manner.
Any help MOST appreciated!
nickpower
  • 43 Answers
SOURCE: 20 Hp (kawasaki) John Deere GX255 tractor over revs when cold.
the engine is icing up. Kawasaki may have a winter kit available. I have solved the problem it the past on other engines by partial blocking the air intake screen with cardboard. Cut a piece of heavy card board the same size as the intake screen cut a few pizza slice shapes out and zip tie it to screen. remove in the spring. refer to owners manual if you are unsure what the air intake screen is.
Posted on Dec 19, 2008
SOURCE: spitting and sputtering
mine did the same, I found out that the high speed jet was clogged, I pulled the fuel line off the filtor(going to the carb), stuck the line into a mixture of half gas half carb cleaner, I fanned it up and in 2 or 3 minutes it started running well, hope this helps.
Posted on Jun 03, 2009
wadembly
  • 513 Answers
SOURCE: Hard start or won't start
the float in the fuel bowl might be getting stuck what you can do is push & pull on float to see if it flows if not the replace the float if i can help further e-mail me wade @ wadembly@aol.com
Posted on Jun 28, 2009
  • 95 Answers
SOURCE: Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
Posted on Jul 31, 2009
wireguy212
  • 1627 Answers
SOURCE: JD 6400 tractor, PTO light flashes when engaged
The most likely problem is the pto solenoid valve on the rear of the tractor.It could be the speed sensor but you won't know until you get the codes read by the dealer.I have had to replace the b.c.u. for this problem but it is not common.
Posted on Oct 20, 2009
Trying to find out the year of a John Deere Garden Tractor model is 110 ser # A29457
The first John Deere 110 lawn and garden tractor was built in the John Deere manufacturing facility in Horicon, Wisconsin, in 1963 and subsequently became an American classic. The tractor was originally designed as a garden tractor, although it is often called a lawn tractor; the company discontinued the model 110 in 1974.
May 19, 2018 | John Deere Garden
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
I have a John Deere X304 with 4 wheel steering. I noticed what appears to be some kind of oil dripping from underneath the left rear axle area. HOW do you get to where you can check transmission and or...
X300, X304, X320, X324 and X340: The transmission is a sealed component. No maintenance is required on this transmission. If you suspect any transmission problems, please contact your authorized dealer. The transmission, power steering and hydraulics (if any) are all on one system, you won't be able to service it without disassembling it.. But it might be a bad seal. Try tracing it back to where it's coming from.
Oct 28, 2013 | John Deere 420,1020,2010,2020,2510,2520...
I have a John Deere X304 that mows unevenly.
Make sure that your gauge wheels are not running on the ground during mowing,they should only hit the ground when you engage a high spot on one side.also when you level the deck the front should be a 1/2" lower than the rear.
May 12, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
How can I tell the year of my John Deere 445 lawn tractor. Product # M00445C096237 ?
1993: 010001
1994: 020001
1995: 030001
1996: 040001
1997: 050001
1998: 060001
1999: 070001
2000: 080001
2001: 090001
http://www.tractordata.com/lawn-tractors/000/0/4/45-john-deere-445.html
Mar 10, 2010 | Garden
I need a john deere X360 44" front blade
you can buy it on ebay right now!
here's the link: http://cgi.ebay.com/John-Deere-44-Blade-X300-X304-X320-X324-X340-Ops-Manual_W0QQitemZ120402528023QQcmdZViewItemQQimsxZ20090406?IMSfp=TL090406151008r17840
May 10, 2009 | Garden
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
1,263 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
