Question about GE (PSS26MSRSS) Side by Side Refrigerator
No light in door dispenser
How do I change the light bulb in the door dispenser, can't find the old bulb, may have already been removed.
    Habit-Forming:
  • 76 Answers
The light bulb is located in the top panel just above the dispenser and to the front. Be sure to check the manual for bulb voltage, most of these used a 12 volt bulb and NOT a 115 volt. It looks like an old style small base Christmas tree bulb.
Posted on Mar 22, 2014
2 Suggested Answers
SOURCE: dispenser light very dim
Put a new York Bulb for your tired computer. Sorry! Can't answer this.
Posted on Sep 23, 2008
How to change the light bulb on the ice dispenser in the door?
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
First - Make sure the dispenser light switch is turned off. Now, that you have broken the bulb it is like having a bare 110 volt hot wire.
I recommend that for safety purposes you do not use either the ice or water dispenser and well as the chance of condensate from warm outside air getting into the electrical and burning out the control board or harnesses.
Get some electrical tape. Turn power off to the refrigerator at the breaker box or unplug the refrigerator. Then, tape over the broken bulb. Turn power back on to the refrigerator.
You may have a ice dispenser cup that you can remove or the dispenser frame for more ease of access.
You now may need a pair of needle nose pliers to remove the bulb.
You did not provide a model number so I can see exactly what you have. Your model number is on the inside of your fresh food section on a label on the upper inside wall.
May 10, 2015 | Kenmore Refrigerators
The dispenser light won't turn off and ice and water not working after filter change..
I'm not really sure of this one but here's a couple ideas. If the refrigerator ice and water dispenser is not working the dispenser control board might be defective. The control board governs most of the functions of the dispenser system. If only one item of the dispenser system is not working, troubleshoot further to see if the problem is with one of the components in the system. The board is more likely to be the cause of the problem when the entire dispensing system fails. It may also be the door switch If the refrigerator ice and water dispenser is not working. When the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice maker dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.Before either of these try shutting it off (or place it in demo mode) and return is to active state.It may just need a reset
Mar 30, 2014 | Maytag MSD2732GR Side by Side Refrigerator
Freezer light bottom not working,bulb good
Warranty time, call maytag, most fridge come with 1 year warranty.
Oct 27, 2013 | Maytag Ice2O MFX2571XE 25 cu. ft. French...
I have a Whirlpool side by side fridge freezer with ice maker and water dispenser which is about 3 years old. Model number I think is WSC5533. Recently I had an interior lamp bulb blow in the fridge which...
HI,
You may have a failing door switch which is causing this problem, if you remove the bulb and close the door, the the red light out? If so, its possible you bulb is fine, you door switch has failed.
I hope this helps
Jul 26, 2011 | Whirlpool Refrigerators
The lights on my liftmaster garage door opener suddenly stopped working I have already replaced the old light bulbs with ones I know work but the lights are still not working.
Unplug the opener and remove the light bulb. Using a small screwdriver lift up on the center contact of the socket. Replace the bulb and plug the opener in.
Oct 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chasnge light for water dispenser
Dispenser
Unplug the refrigerator.
The bulb is located on the dispenser
under the control panel.
Remove the light bulb by turning
it counterclockwise.
Replace the bulb with a bulb of the
same size and wattage.
Plug the refrigerator back in and you are ready to go!
Thanks, Sea Breeze
Apr 25, 2010 | GE Profile Arctica Stainless Steel Top...
I NEED TO CHANGE LIGHT BULB WHERE WATER IS DISPENSED IN DOOR OF AMANA SXD26VW. PUT IN 12V - 6 WATT & IT BLEW THE BREAKER. WHAT SIZE BULB IS NEEDED. NO MARKINGS ON OLD BULB & NO OWNERS MANUAL.
It requires a 120 volt bulb. If it is a screw-base bulb, it's the same bulb as used in plug-in nite lights. If it's not a screw-in you'll need to go to an appliance parts store to the proper bulb.
Apr 23, 2009 | Refrigerators
I have a GE side by side refrigerator model # PSS26SGRD and the water and ice dispenser stops working without any warning or symptom intermintently. It will be working find for days or weeks and suddenly...
Well, the solution to this problem was posted in this thread
http://www.fixya.com/support/t1295372-ge_profile_ref_ice_despenser_motor_not
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
Good luck
Dec 07, 2008 | GE Profile¿ 26.5 Cu. Ft. Stainless...
Dispenser Light broken
you can just unplug the refrig and use a pair of needle noase pliers to remove the base then install a new bulb it can not be over 10watt a night lite one works great (7watt) this will be a better solution that dissably. the panel
Feb 20, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
89 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
