Question about Bosch Classixx WFC 2465 Front Load Washer
Mildew smelling towels and no separate rinse cycle
I have a problem with my towels coming out of the dryer smelling good, but leaving a mildew smell on my skin when I dry.  This is especially noticeable with brown towels.  I can control it somewhat by smaller loads, occasional vinegar in the wash, hot water and extra long wash cycle.  My real question is why does this washer do that?  My top loader never did.  Is there any way to get it to add more water for better washing?  And finally, my Bosch has no separate rinse cycle and I wonder what the best way is to rig it when I only want to rinse something.
  • kechmocash Nov 01, 2007
    Thanks!  I do leave the door open after washing, but I will now check the seal.
  • valerie kronsburg Oct 03, 2008
    i have the same issue with the towels...i will try the advice posted. also what bothers me the most is no rinse cycle alone. is there a way to figure out how to get a rinse cycle.
I had the same problem. An appliance repairman recommended a washing machine cleaner sold at SMELLYWASHER.COM
He explained that the mildew smell from the towels was from detergent/fungus buildup inside the washer. After we got the washing machine smell removed we just had to soak each load in 1 teaspoon of smellywasher cleaner and the smell was gone! We had tried bleach, baking soda, vinegar, washer magic and affresh with no luck!
Posted on Dec 16, 2007
  • 244 Answers
The problem is your door seal if you close the door after a wash then what happens is the water goes mouldy on the inside of the door seal what you need to do is replace the door seal you will never get rid of the smell without replacing it never close the door after a wash always leave it open to make sure its your seal the easy way is to look at the inner part of the seal and it will be mouldy only thing you can do
Posted on Oct 31, 2007
  • peter gittos
    peter gittos Nov 01, 2007
    it will be the door sel only part that makes the smell of mould  seen it plenty of times been a domestic appliance engineer for about 13years now but if you have a cut on your fingers or on your hand do wear  gloves when you change it can give you a bad infection
My Samsung front load washer, which is about 1 1/2 old, smells like mildew. I've read that people put bleach in the drum and run it on a maintanence cycle and I'm wondering how I do that. ...
I had this problem too---same washer. The rubber door seal often harbours moisture and it's hard to clean just by running a cycle. You'll have to scrub away the mildew by hand.
Get a pair of gloves, a soft sponge, and a bucket of hot water with soap and bleach. Open the door. Press the sponge into the folds of rubber where the moisture is trapped. Work your way around the circumference of the seal. Repeat until the black goo is gone. Finally run a rinse cycle with some bleach.
Avoid this in the future by leaving the door ajar when not in use. Tuck an old towel into the seal to wick away the water.
Let us know if the smell is still there.
May 20, 2011 | Samsung WF337AA Front Load Washer
There is water left under the tub after the wash is over. When I move the tub I can hear the water sloshing. How can I get rid of the water. It makes my towels smell like mildew.
If it is draining down and spinning the clothes dry then all of the water is draining out. There is only about a 1/2 in space under the tub. There is a balance ring around the top of the tube that holds water. That may be the sound you are hearing? Try washing a load without anything in it on hot and use a box of baking soda. See if that will help with the smell. My washer leaves a mildew smell sometimes. I started running an extra rinse cycle on it. And that helped. I think it was my water.
May 28, 2010 | General Electric WCSR2090D Top Load Washer
Awful smell! I drain it every cycle, I use the washer cleaner, everything! I am so sick of my towels smelling awful.
Sounds like the little flexible apron just in front of your washer drum has mildewed. Take a look and see if it is holding water, and look for mold while your'e at it. Use a good bathroom mold and mildew remover to kill the mess and deodorize it.
Mar 24, 2010 | LG WM-2277HW Front Load Washer
Strong mildew smell in washer is making cloths & towels smell bad, how do you get rid of the problem?
if you look inside washer there is a rubber rim on the inside around the openning. Look inside and you will find where the stink is coming from. Keep door open when not in use and wipe inside of rubber trim to keep the mildew out.
I use tilex sometimes and do a rinse spin.
Nov 16, 2009 | Kenmore Elite 45986 Front Load Washer
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have exactly the same problem!
Try using the tub clean cycle and use a good dose of bleach or vinegear. Here is how to run the tub clean cycle.
To start the TUB CLEAN cycle:
1. Remove any clothing or items from the washer and close the door.
2. Open the dispenser drawer and add liquid chlorine bleach to the bleach compartment.
NOTE: Do not add any detergent to the detergent compartments. Excessive suds may be produced and leak
from the washer.
3. Close the dispenser drawer slowly.
4. Power On and then press the Extra Rinse button for 3 seconds. (Prewash option will be selected.)
5. Press the Start/Pause button to start.
6. After the cycle is complete, leave the door open to dry around the washer door opening, door seal and
door glass.
Jul 11, 2009 | LG WM2688HWM TROMM SteamWasher
When i opened my washer it smells like mildew. How do I get the smell gone?  i noticed that my towels smell mildewy also.  Will this go away if i leave the door open all the time?
With the washer empty, put in a cup or two of bleach and then run a complete cycle with HOT water and the HIGHEST water level setting. When the agitation first starts, wait a couple minutes, then turn off the machine and let it soak with the bleachy water for about 20 minutes - then turn it back on and let it finish the cycle. If it's REALLY a strong smell, add some Simple Green, or some other NON-AMMONIA detergent to the bleaching process. (Mixing ammonia and bleach together is a MAJOR no-no. It gives off nerve toxins. Very bad.) If you can't find Simple Green, then add some dishwasher detergent. Not dish soap, like Dawn or Joy, dishWASHER detergent like Cascade or Electrasol.
That should help.
If it doesn't help, then unplug the machine, turn off the water supply, disconnect the hoses, and pull the machine away from the wall. Check UNDER the machine for the problem... If the machine, or the hoses, or the drain have been leaking, the mildew smell may be coming from your floor or walls as they rot... If that's the case, you'll have to find and fix the leak, and then repair your floor and/or walls.
Also, check your dryer vent connection... When your dryer is running, do you get hot, damp air coming out from behind it? If so, the vent pipe connecton may be loose, in which case you probably have a build up of dryer lint behind and under both macines.. This can be a fire hazard (especially if you have a gas dryer) and if combined with a little water from the washer, can start to mildew and smell. Reconnecting the dryer vent correctly and cleaning under both machines may solve the issue.
Hope that helps!
Jul 10, 2009 | Samsung WF337AA Front Load Washer
LG washing machine has AWFUL mildew smell
I have an LG washer that had the same problem. Go to the site and read all about why this is happening, how to fix it and how to keep it from comming back. A few different ways of cleaning the machine are explained.
The site sells a product that you may or may not need but the explanations are really good.
Nov 12, 2008 | Washing Machines
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
Bosch Classixx WFC 2465 Front Load Washer Logo
385 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
