Question about RIM BlackBerry Curve 8310 Smartphone
Blackberry phone wont start but makes humming noise when charging
Wont turn on or charge up but makes a crackling humming noise
  • 1,511 Answers
Pull the power cell out and replace. For testing, take it to the phone store and have them run a continuity test to see if any of the other components were damegaed.
Posted on Apr 15, 2014
  • 147 Answers
SOURCE: blackberry charging problem
Sure sounds like a problem with your charging outlet. I recommend taking it to your service provider and having a technician run some tests only they can do.
Please let me know if this helps. Take care!
-Chimpster
Posted on May 02, 2008
hughharris83
  • 4 Answers
SOURCE: so my blackberry curve just crashed
what has happened is some file some where is corrupt. It any easy fix really, just download your current os which you can find by holding down alt and then type eace and that will bring it up. download the os from here www.blackberry.com and then connect and reload your os
Posted on Oct 22, 2008
label_chick
  • 407 Answers
SOURCE: Blackberry 8800 will not charge on wall charger
You need to find out if the problem is with your current AV charger - the battery or the phone.
Clean the battery and the metal connection with a dry cloth, and try to charge using a USB charger.
Posted on Jun 03, 2009
  • 55 Answers
SOURCE: My Blackberry Wont charge?!
look at the 6 pins on the phones charge port and see if one is higher than the others (usually on the end). if the pins is too far up the lower half doesnt connect to the charger. If your usb port will charge on via usb "DOCK" then more than likely the charger itself (which is way more simple to fix)
1.) if one of the pins on the phones charge port is pushed up, grab a sewing needle and GENTLY push the pin back into place,
2.) if the charging dock is working and is a usb charger like your wall charger, buy a new wall charger at your local electronics store.
hope this helps!
Posted on Jun 12, 2009
fleshgear
  • 541 Answers
SOURCE: blackberry 8310 charges,but doesn't connect with pc.
it is not a hardware or a software issue it could be a problem with the UBS port on the handheld or on the laptop or it could be a problem with the USB cable.
Posted on Aug 10, 2009
Crackling noise coming from travel power adapter
Only one reason for the noise on a power adaptor and you already guessed it - spark jump. Do not use until repaired or replace.
Jan 28, 2014 | Computers & Internet
My 8520 turns on but won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 30, 2012 | RIM BlackBerry Curve 8520 Smartphone
Blackberry 8900 would not turn on
Make sure that your battery is not absolutely empty. Plug in your charger and hang on for 15 minutes. If nothing happens than you must have a hardware problem, that means you have to visit your phone brand's service.
Feb 23, 2012 | RIM BlackBerry 8900 Smartphone
Blackberry curve 8520 wont turn on, no red light wont charge or do nothing when the usb is inserted
maybe a bad cord. if it charges normal on the charger then it needs to be setup so it will charge thru the usb
Jul 14, 2011 | RIM BlackBerry Curve 8520 Smartphone
My blackberry storm 9500 wont charge
blackberry storm will not charge brought new blackberry battery put it into phone and it turned on turned it off and left it on charge now it wont turn on even when still pluged into mains charger red light comes on but as soon as i disconect from mains light goes off and nothing happenes
Sep 29, 2010 | Cell Phones
Been on charge all night. wont turn on and has rotating black clock in centre of a blank screen
my blackberry curve went dead and when i placed it to charge for the entire night i tried to turn on the phone and it wont turn on but there is a red light on the phone for a few minutes .... what can i do?
Nov 05, 2009 | RIM BlackBerry Curve 8520 Smartphone
Blackberry Pearl wont turn on....
Try taking the battery out for a minute then putting it back in and see if it will turn on. Otherwise the display may be broken, did it get dropped?
Aug 29, 2009 | RIM BlackBerry Pearl 8100
Black berry that wont turn on
Remove the back of the phone. Pop out the battery. let it sit for about 10 minutes. Replace the Battery & the back cover of the phone. If the phone starts up, then let it start and immediately plug in the charger and let it charge for 1/2 hour before you touch it again.
If the phone does not start up then do not try to start it just immediately plug in the charger and let it charge for 1/2 hour before you touch it again.
It works for my Blackberry Curve 8310...
Nov 25, 2008 | AT&T Blackberry Curve 8300 Smartphone
Siemens sl30 phone wont charge. Just blinks the last part of the battery. When I turn on the speakerphone to dial the phone dies and shuts off. when regular dialing can hear crackling static
I have similar problem with my gigaset 4000 micro, i bought 600mah NiMh bettery and when I start charging it charges cca 3 min and displays that battery is full and it doesnt charge it any more. I can speak max 12 minutes and phone starts beeping that battery is empty. What should i do to make phone to charge this battery properly.
Aug 08, 2008 | Siemens Lands Phones
RIM BlackBerry Curve 8310 Smartphone Logo
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
