Question about John Deere Seat For F710 F725 F735 Riding Mower
Leaking oil around muffler and valve cover
The bolts that come from the engine that tighten the muffler to it are tight, but oil collects around the nuts. Also the valve cover and surrounding area is pretty filthy with oil residue. any help would be appreciated. thanks
  • John Deere Master
  • 2,478 Answers
Did change valve cover gasket? I blow mine with each time I use it. Then every month soap and water. When engine is cold.
Posted on Mar 21, 2014
Testimonial: "Great advise. Thanks again."
  • Alan Fransen
    Alan Fransen Mar 22, 2014
    Hey thanks. I changed it out and it is good for now. When you say you blow yours every time you use it. What do you mean by that. The Soap and water makes a lot of sense. Although in addition i just changed the spark plugs and one was quite a bit dirtier than the other. It was also on the same side as the leaky valve cover.
  • Dennis Key
    Dennis Key Mar 22, 2014
    I had a air compressor and blow nozzle.
Engine is making oil
An engine does not make oil, but it can spill the oil that should be inside. You could have an oil leak, which means that oil will be leaking from either the front or the rear oil seal. The front oil seal is just behind the crank pulley, the one that drives the fan / alternator belt. If oil is leaking from there, suspect the front seal.
If you have oil leaking from the bell housing, that the the bell shaped metal thingy between the engine and the gearbox. you can suspect the rear oil seal.
If you inspect the engine and see oil leaking from the oil pan under the engine, you have a leaking pan gasket. This can usually be solved by tightening the pan bolts, a whole lot of bolts underneath the engine.
Finally, and this is probably the worst, if you see oil around the breather pipe that goes from the valve cover on top of the engine to the gas intake system, you have leaking compression, that means either the valve stem seals are leaking or the compression rings are finished, and you will have to have the engine overhauled, or at the very least have the cylinder head overhauled.
If the rings are suspect, you will also have excessive smoke out of the exhaust when you drive, especially when you accelerate. Check the exhaust for signs of wet oil.
Mar 18, 2015 | Cars & Trucks
1998 Chevy Malibu is using excessive oil. Had an oil change done back in October 2012 . Then checked Oil level in December of 2012 and was about 3/4 low in oil! why ?
first thing check make sure oil pan drain plug tight. check make sure oil filter tight. try tighten oil filter by hand see if turn tighten oil filter clockwise direcction if all is good. how many miles on vechicle.could have oil leaks park vechicle in spot that clean.move vechicle see if you see oil spots on ground if yes.your front timing cover seal leaking oil or rear main oil seal ;eaking.or valve cover gaskets leaking.if find no oil leaks more likely engine burning oil.replace pcv valve.check air filter if you see oil in air filter housing either have bad pcv valve or pcv not getting vacuum make sure pcv valve getting vacuum when engine running vacuum should be felt at pcv if not pcv valve bad or pcv hose disconnected broken or plugged.if pcv valve okay engine has worn piston rings.worn valve seals or guides or oil return holes stopped up thats all possible reasons for engine burning oil.if spark plugs oil fouled engine burning oil.
Jan 11, 2013 | 1998 Chevrolet Malibu
I have a 2005 chevy aveo. I took it in yesterday for an oil change because it was running funny. The guy popped the hood and told me that i had an oil leak...top right hand side in the front...said that...
Sure you can do it. I recommend that you get a manual for your car. It will guide you threw the steps of fixing almost everything on the car. Well worth the money, since you not paying a mechanic. The first thing I would do is clean the are that is leaking, not all of it just most. Then tighten the bolts, nuts for the seal/gasket. see if this stops the leak. You will have to drive the car a couple days to see if it starts leaking again. If it still leaks then procede with the repair. Some repairs are easy some just take alittle more time. But it is all held together with nuts and bolts.
Jun 26, 2011 | 2005 Chevrolet Aveo
I have a Husqavarna LT100 mower (15 years old) It started leaking oil from where the B & S engine is bolted to the frame. I've tightened up the 4 bolts but its still leaking. Any ideas...
Bear in mind that the bolts holding the motor to the frame do not have any oil passages near or through them. The oil is just oozing down the side of the motor and collecting there. If there is a little valve cover near the spark plug(s), the gaskets for these often get hard with age, leak and need replacing. This will be a small door about 2x3 inches with a bolt on the top and bottom, again near the spark plug(s). remove the bolts, take off the cover, clean the old gasket material off the cover and the engine block, put your new gasket on and snug the bolts back up. In the real world this would be a good time to have someone adjust the valve clearances too, given the age. You are not doing that yourself and when I replace that gasket I put some gasket goop on the new one before I put it in. I have a very handy neighbor who is subject to beer bribery and I have him adjust the valve clearances.
Apr 12, 2011 | Garden
Oil leaking from valve cover gasket
Oil sending unit is it hard to replace?
Aug 15, 2010 | 1993 Plymouth Sundance
We have oil in the spark plug wells
Most likely you have a leaking valve cover gasket. There is a gasket the goes around the valve cover, and also a gasket where the cover mates to the head for the spark plug holes.
Mar 16, 2010 | 2003 Mitsubishi Galant
Oil leaking around engine
Oil leak can be attributed to several factors.
1. Gasket failure.
2. Uncontrolled Crank case pressure Failure.
RECOMENDATION:
Tighten both the valve cover and oil pan bolts.
Replace the Positive Crankcase Ventilation Valve and vacuum line.,
INFO: PCV
This is a valve causes a negative vacuum on the engine while its running, As to say if it had a leak in a valve cover it should not be leaking while its running, only when the engine it turned off.
Hope this tip guides you in the correct direction to solve this problem.
R/
David
Feb 22, 2010 | 2000 Ford Focus
Oil leak around timing belt area
1. Gasket failure.
RECOMENDATION:
INFO: PCV
R/
David
Feb 21, 2010 | 1999 Volvo S70
Oil leaking
clean the engine then start the engine have look it mybe gasket cover or mybe it is loose.
check the gasket and bolts or nuts which is tighting cover it has washers.
check engine breathe pipe on the valve cover.
Oct 22, 2008 | 1987 Honda Prelude
Leaking oil bad
If you're certain it isn't your oil filter, then it can only be three other things. The first (and easiest) thing to check is a small diamond-shaped plate on the side of the block, under the intake manifold, towards the alternator. It has a bolt and a stud in it. Verify that both of those are tight. If they are tight, check the four bolts that secure the "push rod cover" to the side of the engine. The push rod cover runs the length of the engine and is located directly under the intake manifold. This was the culprit of my oil leak, and I imagine it will be yours also. However, if you find that those bolts are tight and no oil can be found leaking from that area, check your valve cover. The Fiero valve covers were stamped from very pliable steel and it is difficult, at best, to get them to seal correctly. Problems usually occur when people torque the bolts too tight and bend the valve cover. I recommend a product called "Indianhead" gasket shellac. Remove the valve cover and ensure all gasket surfaces are clean. Ensure the valve cover's gasket mating surface is straight - straighten with a hammer and block of wood if needed. Follow the directions on the bottle to the letter, making sure to coat your valve cover gasket surface, both sides of your gasket, and the gasket surface on the head.
Aug 02, 2008 | 1984 Pontiac Fiero
John Deere Seat For  F710 F725 F735 Riding Mower Logo
258 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
