Question about Samsung HCL652W 65" Rear Projection Television
HCN653W HAS JUMPY PICTURE OW DO I FIX IT
PICTURE STARTS JUMPING AFTER A FE MIN OF PLAYING
Jumpy speedometer
possibly faulty transducer on the transmission, I am assuming it has an electronic speedo
Mar 04, 2014 | 1999 GMC Jimmy
Purple static lines and a jumpy picture
Your picture tube is about to go.
If it's still under warranty,take it back.
Hope this helps.
Nov 26, 2013 | Mitsubishi VS-45607 45" Rear Projection...
2004 santa fe (4 cyl model) low jumpy idle and low power at slow speeds and idle ..... very jumpy. Transmission has checked out ok. Seems to worsen if you have the air conditioner on.
Do you have a check engine light? If so have Autozone tell you what engine code is ( free). Sounds like could be cranck shaft position sensor. Symptoms sound just like what ours was doing before we replaced sensor.
Sep 17, 2010 | 2004 Hyundai Santa Fe
I have a 57 in toshiba rear projection, picture just started jumping and went out, if you put it on another imput for gaming the picture is there but is rounded and is jumpy could you tell me what is wrong...
Possibly not repairable, because many problems are related to a board called the "hyper" board, which is mostly no longer available.-- Most picture problems other than convergence or a bad tube, which doesn't sound like yours.
Mar 08, 2010 | Toshiba 65H82 65" Rear Projection...
EWV404 picture gets very jumpy at times
then ,the tape it is.have you tried different tape ?
May 07, 2009 | Televison & Video
Zenith tv picture jumps after 20-30 min.
the variations of the supply causes that. a verticle stability be checked, specially semiconductors and capacitor changing valuas
Q= CV
Q=IT
THEREFORE
IT=CV=Q AND frequincy = f=i/t
so if I AND T CHANGES CAUSING MOVEMENT OF PICTURE
SO I is for time and T for tempareture
Mar 28, 2009 | Zenith B25A02Z TV
Going down fast
Its definately fixable. Can you post a picture of what your refering to when you say horizontal lines and jumping? Also do you have any soldering ability or troubleshooting experience? Let me know
Jan 12, 2008 | Mitsubishi VS-70707 70" Rear Projection...
Picture is jumpy and expands
Right now it should not be expensive to repair but dont use it anymore or it might become worst,sound like loose conections in the horizontal circuit ,seek assistance it should not be expensive to correct.
Oct 01, 2006 | Panasonic PT-61G54 61" Rear Projection...
Samsung HCL652W 65" Rear Projection Television Logo
15 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
