Question about Brabantia Protective Cover For Wallfix Dryer
Brabantia wallfix The cover does not stay closed. The plastic hook does not hold on to the ridge of the metal cover. It looks like a conception problem.
How to remove the outer cover of the exterior light on a 2003 Jayco Freedom pop top caravan to replace the globe
Most RV outside lights are rectangle in shape and have a plastic cover. If your light is like as described, simply squeeze the sides of the plastic cover to release the inside molded ridge on the cover from behind the stationary ridge on the light fixture and pull away.
The units are slightly different as some of them have continuous ridges (squeeze center sides) and other just ridges close to the ends (squeeze toward end of sides).
To re-install just squeeze and insert back into position.
Oct 09, 2016 | RVs
Switch wont go to off 180sthil
The switch is really a fairly simple concept that simply moves a strip of metal away from a contact or allows it to connect to a contact to make or break the ignition circuit. Remove the filter cover and look closely at the formed plastic shape of the switch and look for the strip of springy metal that is moved with the movement of the switch, then you'll see what is binding it up. The springy metal probably has gotten out of alignment and is binding up the switches movement.
Of course it may even be as simple as a bunch of crud stuck in there inhibiting the switches movement.
Jun 08, 2014 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Sharp r520kst door wont stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Mar 23, 2013 | Sharp R-520KST Countertop Microwave Oven...
Samsung microwave #SMH1611B door won't close
If it has the "double hook" type latch on the door,see if the hooks slide up and down.They should be spring loaded,if not,the spring attachment point inside the door may have broken off(my Sharp Carousel did this).I pryed the plastic door trim loose,and reattached the spring by using one of the slots inside to hold a metal wire clip(modified with needle-nose pliers) to hook the spring onto.Your door's design may be a little different,but a similar solution will probably be apparent after you get in there.
Dec 18, 2012 | Microwave Ovens
How do i replace the battery in the garmin streetpilot c330
Follow these steps : 1. Determine that you do have a Garmin GPS with a replaceable battery. Find the information by checking the manual or with a close inspection of the back and sides of the GPS unit. GPS units that have a battery that can be replaced by the owner will have a battery cover lock on the back or side; it looks like a small sliding piece of plastic with slots or ridges.
2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
May 16, 2011 | GPS
How do i remove the battery out of my garmin 1300
  • 2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
  • 3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
  • 4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
  • 5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
  • Mar 01, 2011 | Garmin nuvi 1300 Car GPS Receiver
    Behringer's Ultrabass BXL3000 - problem with the DI out, which I think it a loose wire. How do I get into it to find out?
    You will PROBABLY find the 4 screws on the sides that screw into the chassis and then get frustrated that it will not come out... MANY of the Behringer things HIDE the other screws as the ones holding the handle... The trick is to get at them... The plastic end covers over the handle have ridges that snap under a metal plate that is over the handle. Carefully pry out the plastic near the handle to release these ridges... pry SIDEWAYS a bit... The ridges snap into small cutouts in the metal... what a pain these are. Use a small 1/4 inch screwdriver with blade vertical right where the handle comes out to bend the plastic outward... Dont reach in very far as the blade will catch the metal... just far enough to catch the plastic cover edge... it is scary. The two handle screws usually go into nut-plates that are a part of the amp chassis.
    The DI consists of two sections of an op amp and is truly driven differentally. There usually is a couple of 120 ohm series resistors and a couple of hf bypass caps near the connectors
    Feb 07, 2011 | Behringer Ultrabass Bxl3000
    How to change front headlight bulb on 2006 mercedes c230 sedan?
    Int he back of the headlight, there is a plastic door. You need to open the little door by pressing a tab on the side to snap it off. So look for the tab first. If dust covers then it needs to be cleaned off for better observation. Once the door is open, you will see the a plug with wires attached to it. Pull the plug straightly out. There is a metal clip to hold the bulb in the place of its socket. Look carefully to see where the hook is, so you cant take off the clip from the hook. After the clip is released, the bulb can be easily taken off. Put a new bulb in, put back the clip, put in the plug, close the little plastic cover then you are done. Have fun.
    Aug 11, 2010 | 2006 Mercedes-Benz C-Class
    Gray plastic piece that holds the black clips that holds the door shut is cracked
    you tape the door shut just make sure tape does not cover and vents. check web sites for parts?
    May 12, 2009 | Minolta Di3510f Bizhub Copier
    Philps CD 880 tray switch
    look something that protrudes at its cover that get inside a hole in the cd tray, it is the one that pushes the switch.
    Feb 05, 2008 | Audio Players & Recorders
    Brabantia Protective Cover For Wallfix Dryer Logo
    337 people viewed this question
    Top Brabantia Sport & Outdoor - Others Experts
    Bill Eager
    Are you a Brabantia Sport and Outdoor - Other Expert? Answer questions, earn points and help others
