Question about Cisco Cp7962gch1 Ip Phone 7962 With 1 Rtu License
Cisco ip phone 7962 when messages no red light
Red light isnt on when messages
SOURCE: Ethernet Disconnected message in POE 7941G IP Phones
the first problem will be to check or replace the cable that you use to connect the phone or check the jack that you use
Posted on Jul 12, 2007
SOURCE: Cisco 7912G IP Phone
You can not shut off CCM CSRST fall Back service. You need to either remove SRST reference in the device pool or for the phone specific configuration. I suggest you create device pool similar to one you have but without SRSR reference. Then you need to re-apply device pool in the phoone configuration and restart the phone.
Posted on Jun 09, 2008
SOURCE: CISCO 7912 Ip Phone,Red lights are continuously on.
I have seen this problem when there is no Voicemail, all old Voicemails deleted.
Posted on Jun 27, 2009
  • 82 Answers
SOURCE: my red light wont go out on cisco 7940 phone, even
Has this just stopped working, or has it never been working?
On the call manager / CME the MWI (Message Waiting Indicator) needs to be configured. This could be undertaken either via the GUI or from the CLI
For instance ...
ephone-dn 30
number 8000...
mwi on
ephone-dn 31
number 8001...
mwi off
and also mapped to each phone to enable MWI status
ephone-dn 1 dual-line
number 111
label Chris
name fred
call-forward busy 800
call-forward noan 800 timeout 10
huntstop channel
mwi-type visual
Complete config details are at:http://www.ciscosystems.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_m1ht.html#wp1018439
If this helps pls leave feedback
Posted on Feb 04, 2010
  • 121 Answers
SOURCE: CISCO IP PHONE 7941 -add background images (user preferences,
See Cisco's user guide regarding template modification and customization at http://www.ciscosystems.am/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/7_0/sip/english/administration/guide/7960usrS.pdf
Posted on Feb 19, 2010
Cisco 7942 factory reset
When performing the factory reset procedure we are about to describe, it is important to keep in mind that the IP phone will lose all configuration files and phone applications. This means that it is necessary to have CallManager or CallManager Express setup so that the IP phone will be able to receive the new information (phone application and configuration) after the reset procedure is complete, otherwise it is most likely that the IP phone will not be usable until this information is loaded on to it.
This preparation also happens to be the procedure for upgrading a Cisco IP phone firmware.
Follow the steps below to successfully factory reset your Cisco 7942, 7962 IP phone:
  1. Unplug the power cable from the phone and then plug it back in. The phone begins its power up cycle.
  2. While the phone is powering up, and before the Speaker button flashes on and off, press and hold #. Continue to hold # until each line button flashes on and off in sequence in amber.
  3. Release # and press 123456789*0#.
You can press a key twice in a row, but if you press the keys out of sequence, the factory reset will not take place.
After you press these keys, the line buttons on the phone flash red and the phone goes through the factory reset process.
Do not power down the phone until it completes the factory reset process and the main screen appears.
Oct 10, 2014 | Cisco 7942G IP Phone
How do i reset my password for the voice messges on the cisco ip phone 7962
password is a server level not phone, you have to contact your system admin.
Sep 11, 2014 | Cisco 7962G IP Phone
My red light wont go out on cisco 7960 phone, even when i have no messages
get a dial tone and dial 7091.
do the same with 7090 to turn the message light on.
May 08, 2012 | Cisco 7940 IP Phone
Cisco ip phone 7912 is not working. when conecting in LAN then it will not boot, while another same series ip phone on that LAn port works perfectly. Only red and green LED blink continue in...
If it is getting an IP address, goto that IP address and there you will be able to see some console messages. See if alternate TFTP is set and is going to a different CM server. If so change it to the ip of your CM.
Aug 17, 2017 | Cisco 7912G IP Phone
Not working cisco 7962
For starters, have you obtained a Cisco Phone power supply for your 7962G? These phones require either a local 48V AC Adapter, or Power Over Ethernet, in order to power up.
Mar 04, 2011 | Cisco 7942G IP Phone
I need to replace a Cisco 7060 handset that has gone faulty, I can only get 7961 models, would this model work properly? or can the firmware of 7960 be able to support 7961 or 7962 ?
The handset piece is interchangable. The firmware is NOT. The handset is simply the piece with the speaker and mic in it that you hold in your hand.
Aug 25, 2010 | Cisco 7940 IP Phone
My red light wont go out on cisco 7940 phone, even when i have no messages
For instance ...
ephone-dn 30
number 8000...
mwi on
ephone-dn 31
number 8001...
mwi off
number 111
label Chris
name fred
huntstop channel
mwi-type visual
Feb 04, 2010 | Cisco 7940 IP Phone
Cisco ip 7962 6 phone lines on a set 4 sets in our office When we answer someone else's line and put it on hold. They cannot pick it up from their desk. If we try to transfer it, it goes to voice mail...
In a VoIP setup, there aren't any "lines" you have to forward the call. Each phone is different on how to do this, but usually you hit transfer and punch in the extension and then hit dial.
Dec 18, 2009 | Cisco 7962G IP Phone
Well, in most Cisco VoIP phones those lights are used to tell you if you have a voicemail. Have you checked your vm and cleared any new ones? This might be your issue ;)
Oct 14, 2008 | Cisco 7912G IP Phone
Cisco Cp7962gch1 Ip Phone 7962 With 1 Rtu License Logo
52 people viewed this question
Top Cisco Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Cisco Lands Phone Expert? Answer questions, earn points and help others
