Question about Dryers
I had a feather pillow blow up in dryer, now it smells burnt. How do I get rid of smel?.
A feather pillow blew up in dryer, now it smells burnt. How do I get rid of the smell? The dryer seems to be working fine otherwise.
SOURCE: My clothes smell burnt
If you have done any recent painting or drywall work, oftentimes the dryer will breathe these fumes and it will affect the smell of your clothes. (Just had the same problem) Maybe let the area air out and see if that corrects your problem
Posted on Dec 14, 2007
  • 1028 Answers
SOURCE: Back heating grate inside dryer has become dark like it's burnt
darkning of the element housing at that point is normal the smell may be coming from lint on the heating element ..may pay to have it cleaned to be sure there is not excess lint accumilation ..or if it has a bottom panel pull it off and clean the base and around the element housing or if filter is on top remove back and clean..still may have some odor simply from lint floating around but better safe than sorry
Posted on Sep 25, 2008
  • 61 Answers
SOURCE: dryer gives off a strong odor which make my clothes smell.
if you have been painting or staining recentley the chemicals in these products are mixing with the mercaptin in the gas to cause the odour. The problem will correct itself when the fumes are gone.
Posted on Dec 18, 2008
ned_san_jose
  • 234 Answers
SOURCE: Overheating/burnt rubber smell
classical sign of a bad motor. the motor has a thermal switch on it telling the unit to shut off when it gets hot. after it cools down, the switch will tell the motor to turn back on again. good luck, i'm pretty sure that's your problem. contact me for further help if needed. thanks :)
Posted on Jul 07, 2009
  • 608 Answers
SOURCE: Smells like burnt diesel or very hot smell
Can't help thinking that either you don't have the revised operating instructions, or the "Sensor Dry System" is not working properly. Download the revised instructions here [http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6231 ] and see if this helps. Otherwise have the sensors in the machine tested.
Posted on Mar 23, 2010
How do I dry a foam pillow
do not use a drier
the heat from the drier will release the rubber smell and make it unusable
best just to air dry on a line
Aug 08, 2016 | Kenmore Elite HE3 Steam 8674 Dryer
How to gt rid of burnt smell inside the microwave from burnt popcorn
Wash with baking soda wipe out clean then wipe down with vinegar
it will eventually go away.
May 17, 2014 | Microwave Ovens
A down pillow came apart in my LEQ2152ES Frigidaire electric dryer. I tried to shop vac the feathers out and ran it on air only clearing the lint filter and drum frequently. I checked the vents in the...
yes these units are fragile your going to need to gain access to the heating section... removal of the bottom panel and you may be able to get the top off and get most of them the screws are in the rear for the top and then the top slides backwards to remove try that first and vac out if not then remove the bottom section and go in from there....
Jan 05, 2011 | Frigidaire GLEQ2152ES Electric Dryer
I was drilling a hole and my drill blow up with a burning smel
could be quite a few problems, did you overload or stall the drill, did you have adequate power supply? Quick test without knowing the model number and brand can you turn the bit or chuck with your hand? If it is cordless is the battery contacts burnt? If electric unplug and remove the handle halves and look at the armature/field for burnt windings or burnt switch, all which could cause a burning smell and shut the tool down, let me know and I will try and help further.
Dec 21, 2010 | Bosch Drills
Problem washing pillows. They get full of water and washer won't spin the water out.
You can remove the pillows and squeeze most of the water out and then put them back in to spin the rest. Washers weren't really made to wash pillows and pillows werent really made to be washed in a washer. Get new pillows and put hypoallergenic covers to keep the funk out. Wash the covers as necessary.
Alternatively heating and tumbling them in the dryer might get rid of whatever aspect you were trying to neutralize or wash out of the pillows.
May 14, 2009 | Frigidaire Washing Machines
Remove debris from around the outside of drum
Take the top off the dryer. You can access it from the back and remove the screws. You will probably find a lot of dust as well. You can also lay the dryer on its frontside to get to the bottom. There isn't going to be anything you can damage here. Vacuum it well especially around the motor.
Feb 07, 2009 | Whirlpool Dryers
Burnt Rubber Smell
ok the rubber smell is your socks and underwear band,,and things with elastic in them ...ok open your dryer ,,look in the back where the hot air blows out,,,does it look like a burned iron..that where the clothe stick and melt too..just take a brillo with a little bit of water,,little dampness ans scrub the area..onthejob...
Feb 02, 2009 | Whirlpool LER7646E Dryer
Samsung WF448AAP maybe clogged with feathers.
dont put expensive pillows into a washing machine.
Dec 12, 2008 | Samsung WF337AA Front Load Washer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
