Question about Apple iPad Mini
Changed the ditigizer screen and lcd does not light up
Lcd scree is black but there is sound
    New Friend:
  • 19 Answers
Maybe there is a problem in the process of changing the screen. Recheck it. I'm sorry this is all I can say.
Posted on Mar 25, 2014
Is my Android tablet LCD screen cracked as well as the digital screen?
and you just learned a 45 dollar lesson . they are not made to sit on .
Aug 06, 2015 | Xelio P1001A-BK 10.1" 4 GB Black Tablet...
What is wrong whith nabi 2 that has sreen probloms
sounds like your screen broke. Nabi has 2 'scereens' a piece of glass on top, then the LCD screen below. The LCD screen can be broken by hitting or twisting it. It can also become more prone to breakage if you leave it out in excessive heat.
Nabi will fix the screen for about $60...
Jul 02, 2014 | Nabi 2
Hipstreet Flare 2 Frozen on startup scree that says "@9"
If you cant get in on recovery mode there is little you can do - its hosed.
Take out any sdcard that may be in it and do a pin reset using the reset hole in the back of the tablet.
Apr 20, 2014 | Hipstreet Tablets & eReaders
Hp entertaiment pc problem display STAYS BLACK BUT ALL LIGHTS COME ON
If the Video Controller fails, the screen will stay black when the rest of the computer runs as it should. To test this, look to the side of the computer and locate the external Monitor attachment. It is a nine pin male outlet. Take a regular computer monitor and attach it to the connection and turn on the computer. If the Monitor acts like your normal LCD screen, then the main LCD screen is bad. If Neither the Monitor or LCD works, then the Video portion of the computer may be defective.
Apr 15, 2014 | HP Pavilion Entertainment tx2500 Tablet...
Replaced digitizer now black screen only
If the LCD was working before replacement, the most likely suspect is a loose cable connection. It is also easy to crimp those tiny flat cables, or to break the locking mechanism so the cable can work its way loose. Sounds like you booted to a black screen after repair, so I would walk back through it and double check every connection, then look at all cables closely in bright light and with a magnifying glass, to be sure nothing sustained damage (twist, crimp, etc.). Remember to check the power cable to the LCD, as well. No power, no backlight, no video.
Mar 22, 2014 | LG Electronics Unlocked Optimus G Slate...
Start up stuck on yes optus screen
You maybe able to RESET the tablet.
There maybe a pinhole RESET button on the back of the tablet. Insert a straighten paper clip into the pinhole RESET button to reset the tablet.
Mar 31, 2013 | ZTE V9 Smartpad Android Internet Tablet
Half the screen on my ipad is black with stripes , how do I fix it
This would be a hardware problem in LCD. You may be required to change it or the LCD flex cable may be causing it. That requires an expert technical to check or install it. Other than that you are fully responsible opening your iPad . Which I do not recommend because you may damage other parts. Check YouTube for the error to see if it solves it
Jan 01, 2013 | Apple iPad 32 GB 3G Tablet PC
Hi! How do I replace a Viewsonic V1250 tablet pc screen. Mine went completely black with no picture.
If the screen does not have a cracked glass, then it maybe a back-light problem, maybe a faulty inverter or a faulty CCFL lamp. These components are much cheaper to replace than the whole LCD screen.
For service, parts and DIY info check out LCD Parts WEB site - click on this link to their WEB site :-
www.lcdparts.net
Dec 30, 2009 | ViewSonic : V1250 Convertible Tablet PC...
Tc1100 Blank Screen
You have identified your problem/fault by plugging in an external monitor and the image is OK. This proves the video card is OK and the fault could be the inverter or most likely the CCFL lamp.
The flickering screen indicated the CCFL lamp is faulty, it is a mini fluro tube which provides the back-light to the LCD. The inverter supplies high voltage to the CCFL lamp. It could be faulty and it is easier to replace.
For service, parts and DIY info check out LCD Parts - use this link to their WEB site : -
www.lcdparts.net
Oct 10, 2009 | Compaq tc1100 Tablet PC
Screen goes blank (white), sometimes screen display will get big
You can update graphics driver, if that does not fix the issue check the display on external monitor. If the external monitor works fine you can isolate checking the display in BIOS Setup scree (Restart your computer and keep tapping F10 to getinto BIOS). If the same issue in BIOS, you may have to change display of the unit.
Jun 26, 2009 | HP Pavilion TX1320US Tablet PC
Open Questions:
See all Apple iPad Mini Questions
Apple iPad Mini Logo
35 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
john smith
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
