Question about Health & Beauty
How to fit side stand on honda x8r motorcycle
Side stand for Honda x8r
  • 2336 Answers
SOURCE: information on a honda cbr 125
The owners manual is online here: http://www.mmra.org.uk/marci/cbr125/Honda_CBR_125R_Owners_Manual.pdf
Posted on Nov 10, 2008
SOURCE: How do I remove the seat on an 84 Honda Sabre motorcycle
I have an 85 Sabre and was looking for an answer to this as well. I read the daniels solution. Not sure what Mr. Daniels is smokin but was he dead wrong. First, the helmet lock has nothing at all to do with this procedure. Why he thinks that is beyond me. Also, there is no "lever on the frame" to push forward.
So, after tugging a little here and there on my seat, I stumbled on the procedure. Here it is: 1) Remove the side covers off of each side of the bike. They are only held in place by grommets at 3 locations per side. A small tug at each of the 3 positions will remove them. 2) You will now be able to see a bolt on each side of the bike that secures the seat. Remove them. 3) Now it's technique time. The seat is now only held in place by a plastic tab and a steel tab. The plastic tab is part of the seat bottom at the front of the seat. The steel tab is on the frame of the bike. That steel tab goes into a slot on the underside of the seat. So here we go. Grab the back edge of the seat and firmly pull it rearward and slightly upward at the same time. That will disengage the molded slot on the underside of the seat from the steel tab on the frame. Once the seat has been disengaged from the steel tab, you can angle the seat upward. Once the seat is angled upward about 30 degrees, pull the seat in a rearward direction to disengage the plastic tab on the underside of the seat from the frame of the bike.
Since the air cleaner on a Sabre is underneath the fuel tank, all Sabre owners who do their own maintenace have to know how to remove the seat. One of the fuel tank bolts is hidden under the seat, The other two are on the front sides of the tank.
Posted on Apr 12, 2009
SOURCE: reguire manual for honda x8r moped
Title: Twist & Go (automatic transmission) scooters service and repair manual Copies: 2 res-button.gif Author: Mather, Phil Copies on order: 0 add-button.gif Year: 2007 Reviews: 0 moredetails.gif ISBN: 1844256251 Reservations 0 review.gif Class: 629.28775
Posted on Apr 17, 2009
crouchdash
  • 83 Answers
SOURCE: how to change sparkplugs on honda shadow motorcycle
VT1100 has two spark plugs per cylinder, the sparkplug caps are snap-ons so they're fairly easy to remove. You need a spark plug socket wrench to remove and replace the spark plugs.
Posted on May 18, 2009
  • 57 Answers
SOURCE: Fitting Instructions - Hard Luggage - Honda 800 VFR VTEC
Go to http://www.vfrdiscussion.com under downloads...manuals, you will find the hard luggage installation instructions.
Posted on Sep 22, 2009
What make is the carburettor on a Honda x8r s 50cc 2003
cant tell .... is this look like the one
SKU: T000113012009
found this new one on Ebay
Nov 05, 2016 | Honda Motorcycles
What's the green white wire coming out of the cdi unit on a Honda cb250n engine I've heard it's for the side stand this engine is now fitted in a go cart
Hi, Ian sorry you can't find the first and best tool you ever bought for your Honda despair not for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Honda cb250n wiring diagram Google Search
http://oldmanhonda.com/MC/WiringDiagrams/MCwiring.php#class
http://www.hondampe.com.au/docs/owning_a_honda/owners_manuals/motorcycles/CB250-1992.pdf
http://www.carlsalter.com/download.asp?p=1183
Mar 28, 2016 | Honda Motorcycles
Honda motorcycle manual
If it cuts the engine when you pull clutch in, check side stand micro switch, it thinks stand is down still, WD40 and a good clean usually works or loop it out
Aug 23, 2014 | Honda VT 600 C Shadow Motorcycles
Honda 600 f2 side stand
Probably a bad kickstand (sidestand) sensor, or the wiring to it might be damaged or even unplugged.
You didn't say what MODEL YEAR yours is, but here's for a 1989:
http://www.bikebandit.com/houseofmotorcycles/1989-honda-cbr600f-stand/o/m2036sch1877
Item #1 is the switch and wire.
Feb 11, 2014 | Honda CBR 600 F(2)P Motorcycles
Brought a motad exhaust for a honda deuaville 650 the center stand bracket will not fit any ideas as there are no drilled holes on the system it's self
the bracket fits on the left hand side of the bike- contact us at the factory and we will talk you through it
Motad UK
Mar 01, 2010 | 2000 Honda Deauville NTV 650
How do you fit a centre stand on a Honda Varadero xl 1000 2009
take off the gear lever look under it you will see a engine bolt that wen you remove is very close to the gear lever then u know thats the wright one mount the fittings for the stand with the alan key bolts they can be a bit fiddley put the springs on the stand then mount it with the shaft you will have to pull the stand a bit then wen you have it on move the right exhaust clamp round so it doesnt hit the stand.and re fit the gear lever
Sep 29, 2009 | 2008 Honda XL 1000 V Varadero
My Honda X8R scooter starting problem when warm
sound like the engine might be worn out do a compression test
Jul 12, 2009 | 2002 Honda Xr Baja
Reguire manual for honda x8r moped
Apr 10, 2009 | 1972 Honda CB 250
Health & Beauty Logo
37 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
