Question about Magnum Radio Communications
Usb audio Hi...I have a Magnum 257 which tx and rx fine, the problem is when im on USB people tell me the audio is distorted or clipping out. When I go to LSB the audio is perfect, AM and FM are also fine, just problems with USB. Any help plz
    Novelist:
  • Magnum Expert
  • 500 Answers
Need to put it on an oscillascope and frequency counter and have it aligned. even taking to a shop should be less than $45 to have it fully done.
Posted on Apr 01, 2014
2 Suggested Answers
SOURCE: magnum 257 it will not transmit on lsb or usb it will on am and f
With SSB you have to put audio on the carrier you cant just key the microphone and expect it to output a signal unless you talk into the microphone at the same time this is how SSB works.
So if you talk and the meter starts to move then its ok, if you talk or whistle and nothing moves then the circuit on the SSB side of the unit is faulty.
Posted on Feb 07, 2009
Mirage 88.. RX okay TX distorted
try the original mic . If its still distorted then it,s a radio problem.
Mar 14, 2012 | Galaxy Radios DX- 88HL Base CB Radio
Magnum 257HP ,Poor TX audio , tried several mics ,SSB ALC , Bias no effect . Did not align TX lower stages . AM , FM are perfect , all RF power outputs perfect , looks good on scope with generator but...
That mod that magnum does really ups the sensitivity. so much thats is too much. If that model has a switch for the compressor turn it off. It will help 100% and make it sound decent not twangy and over modulated. Just the design of these newer exports are not like the old ones.
Dec 14, 2010 | Magnum 257 CB Radio
My 257 magnums audio keeps cutting in and out but my receive is fine
hi it may be a dry joint , on the audio driver or power .if mike is power.could be battery hope this helps
May 21, 2010 | Magnum 257 CB Radio
Compre un cb magnum 257 pero perdi las instrucciones y quiero agarrar frecuencia con otros radios pero no se como empesar cual es el primer paso des pues de en cender el radio
mira el magnum force 257 es un radio de 10 metros y modificable a 11 metros , los canales mas usados en 11metros son el canal 9 osea 27065 mghz , o si tienes licencia puedes usarlo en 10 metros 28,000 por ahi para arriba se usa mucho 28315 en usb , en 11metros se usa am mucho, busca en yahoo , el manual de servicio para que te familiarizes con el suerte.
Apr 02, 2009 | Magnum 257 CB Radio
I need to rewire my roadking 56
Hi and welcome to FixYa,
Pinout and mic wiring as follows:
  • 1 - mic - white
  • 2 - RX - black
  • 3 - TX - blue
  • 4 - Ch Up/Down - NC
  • 5 - GND - bare/red
  • 6 - Vcc (+13.8VDC) - NC
Good luck and thank you for using FixYa.
Feb 11, 2009 | Magnum 257 CB Radio
Magnum 257 6 digit display
To tune frequencies in either 10 kHz or 100 kHz increments,
press the STEP button until the desired digit is
flashing. Rotate the FREQUENCY control in either direction.
The entire frequency range of the Magnum 257
can be stepped through in 10 or 100 kHz increments.
To tune in 1 kHz increments, press the STEP button
until the 1 kHz digit flashes on and off. Rotate the FREQUENCY
control. NOTE: When stepping in 1 kHz increments,
you are limited to tuning within a 10 kHz
frequency range.
Dec 22, 2008 | Magnum 257 CB Radio
Magnum 257 it will not transmit on lsb or usb it will on am and f
Nov 26, 2008 | Magnum 257 CB Radio
Magnum 257 No Audio Being Transmitted
Hello.I have a similar situation on a Magnum 257 HP operating on SSB (AM and FM works fine). If i Transmit it works fine, but when i release the Mic button (after TX), in the bottom side were the RX level should be, it appear somth like a signal level 3 to 5 (constant and continous), but i can't get any reception at all. Only if i turn the TX power level to MAXand i transmit, then it goes back to reception, but not every time. Somtime after TX i need to push the mic button 2-3 times to make it recive somthing, but this wors only if the power level is over 60-70% an i repeat, only on SSB.Can i get some help with this issue?
May 10, 2008 | Magnum 257 CB Radio
Magnum 257 off freq
Colin, here is all the tech info on alignments that your looking for,,,go here;
http://www.cbtricks.com/radios/rflimited/magnum_257/index.htm
Hope this gets you on the right track,, let us know.
Mechanic
Mar 09, 2008 | Magnum 257 CB Radio
Radio Communications Logo
64 people viewed this question
Top Magnum Radio Communications Experts
AnyMHz.com
AnyMHz.com
John Porter
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
