Question about Caterpillar Toys
LCD displays on instrument panel do not work
I am experienced Electronics Technologist seeking information about the instrument panel so I can determine what route I should take to help the customer. He could purchase a new assembly, but if you are a 'fixit' such as I am, you will recognize my intentions and help me to short-circuit the 'replace it' mindset that causes too much electronic equipment to end up in our landfills. Please help if you can.
rolltape
  • 58 Answers
SOURCE: HP 2025 20.1" Monitor
Unfortunately, the LCD screen of any screen is always the most expensive part of the monitor, and it usually costs as much as the monitor itself to buy, not including shipping and replacing (unless you plan to replace it yourself). I could not find any replacement screens myself, and they are very hard to find. My suggestion is to just buy a new one. Sorry.
Posted on Feb 11, 2008
yalmer
  • 549 Answers
SOURCE: Broken Display KCMS145JSS-1
http://www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=%60Bkitchenaid
http://www.howstuffworks.com
Posted on Mar 13, 2008
SOURCE: BenQ FP72G+ 17" LCD Monitor NO DISPLAY
There is a small thing that make it work again, search on the board to BFXXX fuse usually its a 3 Ahm fuse replace it and it will work.
Posted on Apr 08, 2009
SOURCE: I need the assembly instructions for a Four Seasons Gas Grill
I purchased this grill and assembled it yesterday. I noted the area that is providing confusion as it is wrong. Please follow the following instructions. It is quite simple when you have a background in electrical and electronics engineering. These directions should translate my knowledge into step by step instructions for all.
1. Attach the two thinner wires with two terminals on each wire, from the front of the grill head to the larger (Input or Control) terminals on the igniter assembly. These two wires are from the push to turn micro switches on each of the burner control knobs on the grill head. Attach the two smaller terminals on these thinner wires to the micro switch on the side burner control connected as part of the regulator and hose assembly.
2. Attach the three thicker wires from the front of the grill head to three of the six smaller (output) terminals on the igniter assembly. These wires go to the igniters themselves.
3. Connect the two thicker wires from the rear of the grill head to two of the six output terminals on the igniter assembly. The small wire is for the igniter on the bottom infrared burner and the larger, thermally insulated wire, connects to the igniter on the rear infrared burner.
4. Connect the lead from the side burner to the remaining small output terminal on the igniter assembly.
5. Mount the igniter to the front of the right side shelf by removing the battery cover and hexagonal nut. Insert the shaft through the hole in the front of the right side shelf and secure with the hexagonal nut. Replace the battery cap. Do not install the battery at this time.
6. Mount the side burner control by inserting the long end of the control into the side burner assembly. Attach the control to the front of the right side shelf with the two screws held in the front of the control assembly. NOTE: You must remove the screws from the control assembly and insert them through the Off/On bezel and front panel of the right side shelf before screwing them back into the control assembly. Install the control knob for the right side shelf. Verify that the connections to the side burner control micro switch made in step 1 are still intact.
7. Insert the battery into the igniter assembly by removing the batter cap and inserting the AA size battery with the positive (pointed) end out. Replace the battery cap.
8. Test the igniter assembly prior to installing the gas tank and installing the “Flame Tamers” and grates by pushing in on each burner control knob in turn. Listen for a popping sound and look for sparks at each burner.
I hope this helps.
Ed Roberts
President
E. F. Roberts & Associates
www.efrobertsassoc.com
Posted on Apr 09, 2009
don_farr
  • 1011 Answers
SOURCE: HP 1050c....Hi, i am getting error on display for
Are you using HP factory new cartridges or some third party cartridges or even wores a refilled cartridge?
80% of the time, that's the cause of the failure.
Don
Posted on Feb 24, 2010
My pc desktop is showing a white screen when its on what should i do?
Is it an LCD monitor ?
When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See Below for the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance. Hope this helps.
Dec 30, 2012 | Compaq Computers & Internet
My pc is showing a white screen when iys on
La32c450e1 lcd not working only red light on
This may mean that the Back light or a capacitor is blown, you may need to seek a repair shop or buy a new TV. Unless you're good with electronics.
Dec 07, 2012 | Samsung LA32C450 32 LCD TV
Lcd too bright
If the brightness of the backlight cannot be decresed as desired, you have to enter its service mdoe option to adjust the minimum back ligh condition. But, this is a skilled work, and must ahve sound knowledge in electronics. Visit the site named 'Electro-help' for more details. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy.
Service mode options and proceedings to more than 550 brands are described in detail there. Check it , and determine, whether can you do it by yourself or not. If you are not confident, seek support of any experienced service technician. There is no need to open the set to adjust this parameter.
Aug 09, 2012 | Samsung LN32A330 32 in. LCD TV
Need help please. Why has my Vizio TV malfunctioned? And what are my options?
It sounds that the T'Con board [Timing Control Board] to your TV is faulty. But before confirming it, just re-seat all the flat cable connections from it to LCD panel. You must have knowledge in electronics to proceed. Otherwise, seek help of any experienced service technician.
Jul 10, 2012 | Vizio M260VA 26 in. HD-Ready LCD TV
Backlights on coby led3226 will not turn off
There is some missing voltage/s from the main power regulator board to other boards. The circuit with control On/OFF to CCFL inverter board is absent. actually, this is a very skilled work, and need all measuring instruments and sound knowledge in electronics to proceed. It will be best to seek any experienced service technician's help in this work. Work with Power SMPS boards are fatal to any user, it he/she do not have knowledge in electronics.
Jul 04, 2012 | Televison & Video
LG 32LC3R LCD TV picture disappears after few minutes
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!!!
May 14, 2011 | LG 32LC3R 32 in. HD-Ready LCD TV
27 lcd model #fpe2705 no picture only sound
2. Power Supply
3. Backlight
Thanks!@#
Apr 21, 2011 | Audiovox FPE2705 27 in. HDTV-Ready LCD...
Sanyo lcd tv 20"has sound but no picture
2. Power Supply
3. Backlight
Thanks! ! ! !
Apr 20, 2011 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
No picture sound only, blue light stays on
2. Power Supply
3. Backlight
Thanks!&^%
Feb 22, 2011 | Westinghouse 32" Flat Panel LCD HDTV
Toys Logo
Top Caterpillar Toys Experts
fordexpert
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
