Question about Canon iPF700 InkJet Printer
Squeak printing
SQUEAKING PRINTER
If it is squeaking when it is trying to pick up the paper then check the Paper Feed system.
If it is squeeking as it tries to print. Then it will be either the Cartridge or the Drum unit.
If it is squeaking from the back of the machine as the page is fed through the fuser then check the fuser is free moving.
Replacing the faulty unit will fix the squeaking. Be that the Paper Feed System/Drum/Toner/Fuser.
Mar 29, 2016 | Brother Office Equipment & Supplies
Hp 6500n officejet printer squeaky
Check the printer properties settings and check if there is a check mark in any of the options either spooling and squeaking and remove it but if the setting is correct. Resetting the printer will help you clear the error.
Call +2348065607993
Jan 16, 2018 | Office Equipment & Supplies
I have an hp lj4350 that squeaks only when printing from tray 2
There are three rollers. One in the tray and two in the feed assembly. Could be the registration assembly but I have not replaced many of these.
Feb 14, 2014 | HP LaserJet 4350TN Printer
My P2055DN is making a squeaking noise while printing. Not that big of a deal I guess just annoying. I hope nothing major is on the horizon. Please advise if I should worry about this or not. It...
If you are printing invoices from the MP tray the pickup roller might be squeaking against the separation pad (common with this design). Other common squeak is toner cartridge noise.
Jun 21, 2011 | HP P2055DN LaserJet Monochrome Printer
Printer squeaks when printing
remove the fuser wiper if the noise is still present remove the fuser and turn by hand. fuser bearings will cause this
Aug 28, 2009 | Lexmark T632 Laser Printer
Squeaky HP printer
Typically the squeaking comes from the toner cartridge. If you just purchased it, take it back, it's bad. If you can find an identical printer, swap cartridges and see if it makes a difference.
May 27, 2009 | HP LaserJet 1300 Printer
Brother intellifax 4100 squeaks when printing faxes
THIS IS A HARD ONE, THE BEST THING THAT CAN TELL YOU IS TO LUBRICATE ALL THE GEARS IN THE MACHINE, THERE IS A SLIGHT POSIABLITY THAT IT IS COMING FROM THE FUSER MODULE
Jan 07, 2009 | Brother IntelliFAX 4100 Laser Fax
Squeak
PHOTPSMART PRINTER 4180 MAKES SQUEAK SOUND WHEN SCANNIN
Aug 14, 2008 | HP Photosmart D5160 InkJet Printer
Squeaking noise when printing
This is a duplicate posting; here is the link to the active posting: http://www.fixya.com/support/t132706-squeaking_noise_when_printing
Feb 02, 2007 | HP Color LaserJet 5500hdn Printer
Canon iPF700 InkJet Printer Logo
29 people viewed this question
old marine
old marine
