Question about Garden
Countax K18 clutch belt diagram
I have replaced the above i need to know if i have set the two guide pulleys in the correct position they are plastic and have metal guides that hold, position the belt correctly just need to check i have them in right place
    Master:
  • 378 Answers
Sounds like a plan.
Posted on Apr 28, 2014
  • 3 Answers
SOURCE: belt diagram
The deck drive belt makes an L shape looping to the the outside deck pulley that has 2 pulleys. The deck drive belt rides on the top set. X = pulley engine x
l l
l l
l l -
l l x x = outside deck pulley
back deck pulley =x
motor to idle to outside
motor to tension to outside back side of belt goes around idler
This is the most common belt to replace
idle pulley (x)
lx tension pulley
/ l_______
the deck running belt left deck (X ________________ ____ x)
Posted on May 12, 2009
  • 376 Answers
SOURCE: fan above drive belt pulley is hitting metal brace
If the fan blades aren't torn, you could try bending them back in place. I have had sucess doing that before. The plastic naturally wants to go back to where it was, with a little help. If that doesn't work, you can replace the fan, or have it replaced.
Posted on May 27, 2009
mowerman1857
  • 389 Answers
SOURCE: Murray model # 425303x92 primary drive belt #
Go to www.murray.com/manuals/ , input yourr model number and download what you need
Posted on Sep 14, 2009
  • 146 Answers
SOURCE: i need to replace a mower deck belt on my exmark
There will be one or two "idler pulleys" besides the spindles that turn the blades. Usually one idler pulley is mounted on a plate that swivels, pulled by a strong spring, to put tension on the belt. The other idler pulley is usually fixed in place. Use strong pliers (vise-grips or channellock) to pull the spring out of its notch at one end, releasing the tension. Then the belt can be threaded. Now you have to restore tension by by pulling on the spring and anchoring it on that swivel plate again.
Posted on Jun 06, 2010
  • 4 Answers
SOURCE: require an electrical circuit diagram
Call Countax on 01844 278800, they're customer service is usually good at supplying this sort of info. Ask for a parts list and user manual while you're at it.
Posted on Jun 20, 2010
Contax k18 ride on mower the deck shudders and there's smoke coming from the belt what's wrong with it this happen's occasionally the belt is new
Check all of your idler pulleys as it sounds like one has a bearing that locking up. If these are of the plastic style one may flat spotted.
Apr 27, 2015 | Garden
I ust had the water pump replaced. Now my ac has gone out. I know nothing about cars but I do know that I hear a strange noise and the front part of the ac unit was turning and now it's not. It seems...
It is unlikely that the replacement of the water pump and AC failing are related, however ensure that the V belt is correctly positioned and under tension. The AC pulley should be spinning continuously by the V belt. The AC compressor is engaged by an electrically operated clutch within/behind the pulley wheel. If the pulley wheel is not spinning but the belt is sliding over it then you have a seized AC compressor and this will most probably need replacing. If the wheel is spinning but the AC compressor is not working (no cooling) then it is the clutch that is not engaging. This could be due to a worn clutch, failed clutch actuator, broken electrical connection, failed relay, broken fuse a failed interior thermostat (the car thinks that the 'set' temperature has been reached and so switches the AC off). To check, put the AC on the lowest setting and test the voltage at the AC compressor connection. If voltage is being supplied it is likely to be a failed AC clutch. There are lots of AC clutch repair videos on youtube and these should be a great help.
Aug 22, 2011 | 1999 Mercury Mystique
My countax mower c300 keeps blowing the p c b board
hi, my countax k18 is needed for this season for my buisness, after about 10 or so minuits it cuts out on me, no deck attached And i havnt engaged or disengaged anything... any ideas?? its defo electric as it cuts out really quick....
Mar 25, 2011 | Garden
How to adjust a tension pulley?
This vehicle should have an automatic tensioner. You can use a wrench (13mm, 14mm, or 15mm depending on whether it's aftermarket or not) and rotate the pulley bolt clockwise to release tension. If you need to make it tighter, you either has a belt that is in need of replacement or a tensioner that needs to be replaced. This type of automatic tensioner is replaced as an assembly
The tensioner bolt can usually be accessed from above, but it is easier if you can lift the passenger front or the can, remove the wheel, and remove the rear plastic splash shield. This will also make it easier to correctly position a new belt over the crank pulley if necessary.
Feb 13, 2011 | 1993 Saturn SL1
98 plymouth voyager power steering belt
See diagram
http://www.fixya.com/uploads/images/C2ED0FB.jpg
The triangular-mounted AC belt must come off first.
At the top pulley is a small bracket and hex screw. This is a jackscrew, which when loosened, will lower the top pulley and the belt will become slack. If jackscrew become detached from pulley, just raise pulley by hand to reconnect, and tighten screw to re-thread.
The larger serpentine belt is loosened by performing a Righty-Tighty to the tensionner pulley. The belt will easily slip off all pulleys. Be sure to follow diagram to install new belts. Remove plastic shield under engine for access to lowest pulleys. I recommend tying up belt above top pulley, threading around everything except tensioner, then untying & position belt over tensionner.
Jul 29, 2010 | 1998 Plymouth Voyager
How to replace drive belt on john deere model 345
- remove deck
- remove seat and rear fenders
- pry off deck adjusting knob
- remove F/R pedals
- remove floor plate
- use jackstands to prop up entire right side of tractor
- remove (2) screws holding fuel lines on side of frame
- lift out gas tank, set alongside left side of tractor
- remove plastic fan from hydrostat
- disconnect the electrical connector for the electric clutch
- from the top-side - use a 3/8" drive rachet - stick it into the tensioner slot next to the idler, rotate it to take tension off the belt, and remove belt off hydrostat pulley
- from underside - remove front idler (next to electric clutch)
- from underside - remove the "right-most" idler off the spring tensioner
- from underside - remove the "left-most" idler off the spring tensioner
- now the tensioner can rotate fully to take almost all the tension off the extension spring
- pop the spring off the tensioner arm
- the belt should now be able to be removed from the machine
- reinstall in the opposite fashion
- note: to reattach the spring, connect a nylon cord to the spring, and pull it rearward and guide it onto the tensioner arm - you need to stretch it about 1"
- for reattaching the two idler pulleys to the tensioner, get someone to hold the ratchet so the tensioner is positioned for the belt being in it's most-loose position. You may need to wrap the new belt around the hydrostat pulley first, and assemble the last idler pulley and belt at the same time to complete the procedure.
Apr 20, 2010 | Garden
The 2001 Windstar we have here only has 7 pulleys and the diagram dosnt match any ides.
here you go. please rate, thanks
Item Part Number Description 1 8620 Drive Belt 2 10300 Generator Pulley 3 6C348 Idler Pulley 4 6B209 Drive Belt Tensioner 5 3D673 Power Steering Pump Pulley 6 2E884 A/C Clutch Pulley 7 6A312 Crankshaft Vibration Damper Pulley 8 8A528 Water Pump Pulley
s1w~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The drive belt tensioner has no provision for adjustment and will be damaged if forced to travel beyond its operating range. Automatic tensioners are calibrated at the factory to provide the correct amount of tension to the belt. There is no need to check tensioners for proper tension.
NOTE: Drive belts (8620) with automatic drive belt tensioner (6B209) do not require adjustment.
NOTE: When a drive belt is installed new or reinstalled after a service procedure, the drive belt does not fully seat into pulley grooves until engine has run for several minutes.
This vehicle is equipped with:
  • a V-ribbed serpentine accessory drive belt.
  • automatic drive belt tensioners.
New drive belts should be of the same type as originally installed.
Drive belt chirp is a regularly occurring chirping noise that occurs due to:
  • pulley misalignment.
  • excessive pulley runout.
It can be a result of a damaged pulley or an incorrectly replaced pulley that was not correctly aligned.
To correct drive belt chirp:
  • determine the area where the noise comes from.
  • check each of the pulleys in that area with a straightedge to the crankshaft pulley (6312) for front accessory drive and the water pump drive pulley to the water pump.
  • look for the accessory pulley to be out of position in the fore/aft direction or at an angle to the straightedge.
Drive belt squeal is an intermittent noise that occurs when the drive belt slips on a pulley during certain conditions such as:
  • engine start-up.
  • rapid engine acceleration.
  • A/C clutch engagement.
Drive belt squeal can occur under the following conditions:
  • The A/C discharge pressure goes above specifications:
    • The A/C system is overcharged.
    • The A/C condenser airflow is blocked.
Feb 27, 2010 | 2001 Ford Windstar
Does Not drive, belt position not sure is correct, connected and tight. Engin runs and Blade turns just fine. Craftsman, 917.374511, Lawn Mower
"belt position not sure is correct," from your description above
The first thing to do would be make sure belt position is correct, connected and tight.
This system is quite simple, the belt goes in the pulley on the engine shaft and the pulley on the transaxle only, nothing else. Using a short piece of rope or anything else readily available, temporarily tie down the safety bail (handle) and engage the drive handle. Now check your belt, it should be fairly tight and you should not be able to turn the transaxle pulley without considerable effort, if it is easy to turn, replace the belt. Now release the safety bail (handle)
If the drive belt seems to be working okay as above, remove the front wheels and inspect the gear teeth in them. If the outer half of the teeth are worn down more than 1/2 the original size as compared to the inner half, replace the wheels.
While you have the wheels off, if you have a couple of blocks of wood or similar items, set one under each corner of the front of the main frame outside the arch of the blade and start the engine, engage the drive and observe the pinion gears, they should both be turning. If they are not, then you have a bad transaxle and are going to have to either replace it , use it strictly as a push mower, or replace the mower.
Oct 31, 2009 | Craftsman Garden
Require an electrical circuit diagram for countax K18
Jul 29, 2009 | Garden
Garden Logo
154 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
