Question about Samsung CLX-3175FW Multifunction Laser Color Printer
Reload correct paper
Fix reload correct paper on fax machine
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 150 Answers
Your printer papper seting is change the correct size of your papper
Posted on May 06, 2014
When I try to make a copy in My fax sharp ux-108 the paper goes out blank
First make sure the original document is loaded with the correct side facing down. If not the problem try taking out the roll paper and reload it with the other side of the paper facing up
Jan 23, 2012 | Sharp UX 108 Roll paper Thermal Fax
Check Film and Cover Open: KX-FPC95
Check for slack in film between supply and take-up rollers. Manually advance take-up roller to remove slack before closing cover.
Dec 18, 2009 | Panasonic KX-FPC95 Plain Paper Thermal...
How do you get a fax from memory
May 19, 2009 | Canon FAXPHONE L80 Laser
I have a Brother Intellifax 4100 Fax machine. I may have pulled the paper cathrudge out to abruptly because a 3/4 spring was dislodged from somewhere - I have not identified where it belongs. As a...
best guess is it belongs under the paper lift plate in your paper tray, remove the paper tray and all the paper, there should be a metal paper lift plate in the paper tray, these are typically spring loaded to lift the paper into place. lift the plate and check the underside for the location of the spring, there is usually a retainer of some sort to hold the spring in place. once the spring is in place the tray should feed correctly.
Hope this is of some help.
Ed
May 09, 2009 | Brother IntelliFAX 4100 Laser Fax
Fax double feeds sheets
This may occur if:
-the paper is too thick or too thin
-the roller mechanism is not properly aligned or has worn out
-the sheets of paper stick together
things you can try:
-unload the paper in the main tray and bend the stack of paper to loosen it up. Reload the paper to the main tray
Hope this helps!
Feb 17, 2009 | HP 1240 Plain Paper Inkjet Fax
Brother 4100 intellifax
Check the blue tab on the inside of paper tray and make sure it is on correct paper size.
Fax machine is very sensitive so try not to put too much paper in it.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Check paper reload paper
Remove the paper tray completely and make sure paper is not binding and lifting up OK.
Jun 30, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
How Can I Reprint a Fax?
Here's a trick that I used on the Canon thermal transfer years ago. First take out the thermal transfer unit and roll up the black transfer sheet to the begining of the lost fax. Then reload the paper. Next get a solid black original equal and make a copy. The result you should get a negative copy of the lost fax. Repeat this step until all the faxes are recovered..
May 31, 2007 | Panasonic KX-FC195E Plain Paper Thermal...
Samsung CLX-3175FW Multifunction Laser Color Printer Logo
27 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
