Question about Aprilaire 4277 560 Series Humidifier Water Distribution Tray
My Aprilaire 560 humidifer is not getting any water to it I have 2 furnances and 2 Aprilaires and neither get water.
My humidifier only shows Model 560 not and other numbers like 4277 you have listed in the question
  • Aprilaire Master
  • 3,382 Answers
I would check the shut off valve from the supply line, it is probably plugged or off. If on then I would guess it is one of the tube piercing valve types which will fail. Be sure the supply line has pressure.
Posted on May 30, 2014
Humidifier does not turn on
if your saying that the voltage drops to around 4 volts at the supply transformer at anytime , then id say the load (device connected) is too much for the transformer to supply this most likely is caused by an internal fault in the load (humidifier) also since its a water appliance id say a water leak might be a factor in that as well , taking a look under the cover of the humidifier 4 signs of a water leak (or past one) would be where id start
Nov 11, 2015 | Aprilaire Model 700 Automatic Whole-house...
Eledtrical
What is the exact model number?
Jul 29, 2013 | Haier 45-Pint Dehumidifier
Looking for manual for DDR557HE
The Model Number you listed is either incorrect or has been discontinued. As it does not show up in my data base for Danby. Please check the number again and advise.
Thanks.
Jun 03, 2011 | Danby Dehumidifiers
Dehumidifier wont turn on or reset. code comes up as F2 and wont reset. Cleaned off filter. no help. any ideas you have would be appreciated.Just bought it last year. we have the hose connected to a...
To figure out what Code F2 is, I took a look at the Owners Manual for the Model # AD70USS, Strangely, the Owners Manual doesn't list an F2 Code or any codes for that matter. Because that model number humidifier, does not have an LED screen.
Never the less, to reset your unit using an alternate method. Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Wait 12 - 15 minutes before plugging it back in. Then turn the Master ON/OFF Switch to ON and the dehumidifier should have reset itself. If it doesn't check the positioning of the water bucket, to make sure it's contacting the safety switch. Eventhough, you're using a drain home, it's still important.
Hope this helps you solve the problem.
May 08, 2011 | Whirlpool AD70USS Dehumidifier
The bucket fills with water even though the humidifier is attached to a hose
Most of the units do not require the bucket to be in place, when the hose is attached. However, since you didn't list the Model Number of your unit, I can't be sure that's the case with yours. However, if you click on the following link, and enter the correct model number, you can download and print the Owners Manual for future reference.
http://whirlpool.com/custserv/index.jsp
Hope this helped you to sort it out.
Apr 21, 2011 | Whirlpool 75-Pint Dehumidifier
LHD65EBL Code CH 01
I had the same problem, and I wound up calling LG's customer support line. The rep I spoke with says that the "CH" code means that the internal thermostat is not able to accurately read the air temperature, and the unit will require servicing.
She gave me a couple of numbers for local folks, and I'll call them in the next day or so, but I'm thinking that this may not be worth the repair, unless it's pretty cheap: I bought the unit for under $100 less than 9 months ago, and I'm not eager to shell out a bunch of money to get it repaired.
Nov 02, 2008 | LG LHD65EBL Dehumidifier
Adjusting dehumidifier on furnace
This model furnace does not come with a built in humidifier. Humidifiers are normally an optional add on. If you have a by-pass type humidifier it is none adjustable. Water level is normally float controlled and operation is control by blower circuit. When ever the blower runs the humidifier operates when in the heating mode.
Jan 24, 2008 | Dehumidifiers
Aprilaire 4277 560 Series Humidifier Water Distribution Tray Logo
78 people viewed this question
Top Aprilaire Dehumidifiers Experts
Michael Youngman
Michael Youngman
J.D. Browning
J.D. Browning
Gil Shultz
Are you an Aprilaire Dehumidifier Expert? Answer questions, earn points and help others
