Question about Supco SL400TH Temperature/Humidity/Dew Point Datalogger. SL400TH
Softwareproblem Computer dataloger software not install
We have a Heron DataLogic D130 Bar code scanner for our POS system. We have had them for 3 years with no previous issues until a day and a half ago. I just got a new computer setup with the POS softwa
Possibility is the that the engineers of your POS Software company are right, but we can definitely prove them wrong provided we test and, or check the same POS software or setup on a similar brand new computer.
Sep 05, 2014 | Datalogic Computers & Internet
Blue screen death
you don't write any details.BSOD can be two things hardware or softwareproblem.sometimes microsoft update.try to think back to then it begun,did you install any new software,or hardware.
Jun 18, 2013 | Acer Veriton Computers & Internet
Acer computer keeps crashing
Best thing to try before anything is to run your computer in safe mode.
Make sure the computer is off and not in sleep or in hibernate.
Power the computer on and click the F8 key till you see below image.
Image is from a Windows 7 - Most versions of windows will be the same Or similar. Screen defaults to 640 X 480 in safe-mode!
Choose safe mode with networking. If while running your computer in safe mode and it never blue screens - Then chances are, you have a software, driver or virus issue - Most cases. If your computer continues to crash in safe mode. Your system most likely has a hardware issue. Common: Computer Memory and/or hard drive.
Jun 14, 2013 | Computers & Internet
Softwareproblem
hello sir,
reinstall the software in your phone.re installing makes your phone works better.by reinstalling your software problem gets solved.have a great day
thank you
Jan 01, 2011 | Motorola Mobility RAZR V3i Cellular Phone
Configuring (changing) barcode reader suffix
Reset tbe scanner and again program the scanner for your required configuration.
Aug 15, 2008 | Datalogic Computers & Internet
I have a blue screen whish is a hardware or softwareproblem
It could be software only if you recently done any updates. As you boot up to the computer hit F8 a couple of times and it will take you to prompt pick last known good configuration and that should work. If not go into safe mode and remove all items starting up automatically. if it boots then its software if not it is hardware
May 27, 2008 | Acer Computers & Internet
Can i clone the configuration from another scanner?? please i need to know how to make this....
You can contact them directly at either link: http://www.datalogic.com/ http://www.scanning.datalogic.com/html/contact.htm They may have software for it that does this.
Mar 27, 2007 | PSC PowerScan RF Base Station
Supco SL400TH Temperature/Humidity/Dew Point Datalogger. SL400TH Logo
24 people viewed this question
Top Supco Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Supco Measuring Tool and Sensor Expert? Answer questions, earn points and help others
